Lines in words
When the paper is printed out it has lines going through some of the words on certain parts of of the paper.
  • Office Equip... Expert
  • 398 Answers
This is called ghosting usually caused by a worn drum unit or fuser
Posted on Jun 23, 2009
Wording of printing not fit with the paper using.
I'm having some issues figuring out exactly what problem you are describing, but I think you have a page length issue. You can change that under emulation, page format.
Oct 10, 2016 | Printronix Line Matrix P5215 Printer
My Xerox Phaser 6128MFP printer flashes a red light with a "Load paper in Tray" message, when the specific paper size and type are already same in the tray.
If the paper size is correct in the printer and the printer and it's possible to print off a test print in both the printer control screen or directly from the print driver utilities if that works then the only thing I can suggest is the item you want to print is defaulted to a different size. i.e. Check that the word processor your using is set to the size you have in the printer. Imperial size pages will look very similar on screen as does the A4. Printers don't automatically fix paper print sizes you just have to check and recheck for differences. Removing the tray only reafirms to the printer that the size might be incorrect and your going to fit the correct size.
As for the red light all printers behave differently in certain error conditions. Have you also tried to print out something you printed at a time the printer was working correctly. In other words try printing out a different file. Maybe, trying to print off a test print of one line of the alphabet, and then go from there.
Good luck,
Apr 02, 2015 | Xerox Phaser 6125 Laser Printer
Printing custom sizes on hp deskjet 3015
In MS Word, go to page setup then modify the paper size of the document.
Next, Press CTRL P to open the print dialog box, then select properties. Modify the paper size of the printer.
Hope this helps.
Apr 25, 2014 | HP LaserJet 3015 All-In-One Printer
I bought a new imac. OS X version: 10.9.1. I'm having trouble printing to my HP Office Jet 5610. Not all the words or images are being printed. Sometimes its an entire area of a page. Sometimes it
Before printing, you can choose the page setup option (either above or below the 'print' & 'preview' selection) to make sure paper size & type of paper(usually legal is default setting) selected. Also make sure the drivers for that printer is up to date. What kinds of images are you wishing to print out? Most pages have html which prevents certain images or words from being captured/printed
Feb 01, 2014 | Apple 21.5" iMac Desktop
It will not print Word documents. it pulls a blank piece of paper through. It will print in notepad
there is something wrong with your Word printer setup. Go to Word, then from the File menu select the Print option and when the print window opens see if the HP deskjet is selected as default printer. Then, in the upper right quadrant theres a button called Advanced Settings, or Prefferences (depending on your Word version). Click that button and check to see if the HP printer is set as On Line, and is set to print odd and even pages. Also, check the margins of the paper. Ink Jet printers cant print over the full page, there's always a need of some margin on each side of the paper, so you'll need to set the margins from all sides on at least 0.5 inches
Jan 18, 2011 | HP Deskjet F2210 InkJet Printer
Brother mfc-8480dn no paper error I have a new brother laser printer and it is telling me there is "No Paper" but the paper tray has paper. I have tried removing the paper and reloading the tray...
Open the file you are trying to print, go to "file", "page setup", "Paper" and choose "Default tray" under paper source. It may give you an error message that the margins are outside of the paper. Click on "Fix this", then you can print. I had the same problem.
Jan 12, 2011 | Brother MFC-8860DN Printer
When printing I get a "thicker" run blob line ( on the left side of the paper) no mater if I print word or excel. I have changed print cart. Any help?
Thi is certainly due to a piece of paper stuck in the paper path, or it needs the cleaning wire on the underside of the toner cartridge sliding back and forth to clear it. Take the cartridge out, and you will see a wire that goes the full length and it will have a plastic lug attached to it. Slide this back and forth a few times then refit it.
My first reaction is that there is a small piece of debris in the path that will cause this problem. Have a good luck inside. Unplug the printer before you do this :-).. Good luck
Jul 18, 2010 | HP LaserJet 1320 Printer
I am trying to print onto pre-printed forms which have a dark blue band at the top. My printer isn't recognising that the band is there so is starting to print too far down the page. Help please!
This type of problem can usually be resolved simply by adjusting the margins from within your word processing program. Depending on which word processor you are using you can go into the page setup and make these changes. For Microsoft Word go to the "File" tab at the top then to page setup. The first tab that comes up will allow you to change the margins on the page. If the print is too far down try reducing the top margin from one inch to 0.5. If that is not enough reduce it some more. Print test pages on regular paper, then hold them up to the light against the paper with the pre-printed band to see how the print lines up. That way you don't waste the expensive paper!
May 20, 2010 | HP Photosmart C5280 Printer
HP 1210v all-in-one not printing...
1. try to do the cleaning utility
2. try reinserting & shaking the cartridges
3. try to print to see if there would be any improvements & redo number 1 until you get a good printout
Jul 22, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 2355 Truncated lines
Try cleaning the paper rollers and the print head.
Use a wet cloth to clean the paper rollers.
Use a little amount of water and some alcohol (Isopropyl alcohol) to clean the print head. (You may not need to do this if your printer cleans it automatically through software utility.
This may be also have caused by the low ink level. Replacing the cartridge should solve this problem.
Oct 19, 2007 | HP PSC 2355 All-In-One InkJet Printer
325 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
