Question about Music
How much do i way
I dont know how much pounds i put on
How do I fix my zoom
Its initialihzin hard disk drive so the hard disk is probably broken put in another one dont know if you need to format it but its your hard disk for shure
Oct 20, 2014 | Zoom R16 Multitrack Recorder
When I turn amp on there is a loud humming that does not stop.
try plugging into a different socket if that doesnt solve problem you may need to replace cord. sounds like a loose neutral in socket though.
Dec 01, 2012 | Fender Frontman 212R 100W 2x12 Guitar...
Keyboard stand by casio seems to have no support to hold the keyboard. The keyboard slides from side to side on the stand
Just add some adhesive Velcro (hook and loop fastener) The industrial rated for 25 pound should be good for most players, 75 pound rated minimum for Jerry Lee Lewis type players.
Set the stand at the height you want, put the hook tape on the stand leg top and then target the fuzzy strip to the piano. Be aware the pound rating is rated per square inch- so you will want to put a 10 or 12 inch strip of fuzzy on the piano, and 1 or 2 inch strips on the stand leg.
Apr 01, 2012 | Music
The power switch on my Marshall 250dfx popped out and i dont know how to fix it? any help please?
you see that your amplifier's on off switch is push to on/push to off type. what came out of the amplifier is the knob which is pushes the actual switch. try to fix that knob from out side. if you are not able to fix it, put a plastic pen into that hole & try to push the switch. by this way you can put on your amplifier.
Sep 26, 2011 | Marshall Amplification Marshall MG250DFX...
How can tou take a small bump from a Turntable Record
Place it between two very FLAT things with thin cloth padding and put weight on it for a while, say a week or so. Have it in a warm area during the time.
Two pieeces of glass or flat material like shelving material might work. Use a single layer of cotton on each side of the record to protect the record. You will need a lot of weight... say 20 pounds... stack of books for instance.
Jul 08, 2010 | Music
I dont know how to put a whammy bar on a fender stratocaster
Look near the near the highest string at the the silver part known as the bridge.There should be a hole right near the bottom of the thinnest string.Take the threaded end of the whammy bar and screw it in clockwise into the body.
Sep 20, 2009 | Squier Stop Dreaming Start Playing...
I dont know how to connect it to my laptop
I'd recommend either the UCA 202 or the UCA 222. Both are Behringer products and the 222 comes with a software bundle. Check out the energy XTC software, I downloaded it and am having fun with it already.
May 09, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have an electric yamaha but dont know what make and the tone plot came off it and i dont know where to solder the wires onto and there are also a few other wires off it and i dont know where to put them...
I can solve your problem, but you dident give enought info . You may be able to fix this. if you have the stuff and that is not much, send more info to Danforddan1@msn.com if you want. we will get you playing DFD
Feb 23, 2009 | Yamaha Electric Guitar
Music Logo
12 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
