Question about Dell, Inc Dell XPS 18
Xps 18 not charging on stand
I have tablet on stand, charging cable plugged into stand base but tablet is not showing a charge
My lg tablet is on the charger and says its charging but every couple of seconds it stops charging while on the charger. My battery percentage has been at 18% for almost four hours.
It is possible that the battery in the tablet has gone bad, but it is MUCH more likely that you have a bad charging cable. Try charging another device with the questionable cable and see if the problem continues or buy a new cable and see if that solves the problem.
Jun 20, 2017 | LG Tablets & eReaders
My nextbook 10.1 is not charging. Shows power is connected but is not charging
Could be the connector the cable or the battery itself that's bad.
Sep 08, 2016 | Nextbook Tablets & eReaders
How can I restart my tablet it has just gone black not even showing signs of charging
plug in usb cable an power up /down til it asks to recover it, maybe
be sure charger is working touch to tongue :P
Oct 19, 2014 | Tablets & eReaders
Why my tablet turns on when charging?
My ASUS Windows 8RT tablet is what I am basing this on, but it does the same thing. It's actually pretty common for the device to remain ON (standby) while charging. If you look at the battery icon, does it show anything different than usual?
May 17, 2014 | ASUS MeMO Pad ME172V-A1-PK 7-Inch 16 GB...
JW2VY
chances are the charger you got is not compatiable with the Dell XPS or the charger is broken. Recommend that you go to dell and get another charger
Mar 31, 2014 | Dell XPS 18 Stand
It will not charge
Try to charge your tablet pc with your laptop or desktop pc.
if it will show the charging then your charger may be out of order.
if it will not charge with your laptop or desktop then your tablet's charging circuit not working.
Feb 15, 2014 | Ematic 7" Tablet Computer
Will 18 volt black & decker charger over charge battery
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
Oct 04, 2011 | Black & Decker & Cordless Drill
How do I know if it is charging
On your stand there are blue lights that show when it is charging the vacuum. If plugged up with out the vacuum on the base the lights do not show. Once you set the Vacuum on the base the blue lights indicate that it is charging.
Dec 21, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
My phone is not charging up when I plug it into the charger
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 17, 2010 | Motorola Mobility C118 Cellular Phone
Dell, Inc Dell XPS 18 Logo
156 people viewed this question
Top Dell, Inc Computers & Internet Experts
Joseph Hoffmann
Ken Lynch
Level 1 Expert
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Dell, Inc Computer and Internet Expert? Answer questions, earn points and help others
