Question about HP mp3135 Multimedia Projector
HP MP3135 Projector Repair
Does anyone know, where sells a replacement colour wheel for the HP Mp3135 projector?
Thanks
3 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: can i set up an xbox 360 on an hp mp3135
if your xbox has the hdmi port, you need a hdmi to m1 cable. otherwise, you'd need the hd av to m1 cable. there is no vga port on the projector.
Posted on Aug 18, 2009
  • 23 Answers
SOURCE: how do you change the bulb on a HP MP3135
Push the lever on the front of projector (below the lens) up and then pull the black part of the casing (lamp) apart from the white part of the casing (projector) separating the 2.
Posted on Jan 09, 2010
New Colour Wheel Mixing up Colors on Dell Projector
Could be just 180degrees out of phase on the motor spindle and sensor or damage caused by broken material from the old wheel.
Apr 21, 2017 | Dell M209X Ultra Mobile Projector ...
Looking at purchasing a used HP MP3135. In purchasing a HDMI female to M1-DA male adaptor, will this allow me to connect my laptop etc via HDMI cable? We also would like to connect a Wii and HD TV, how do...
HP available M1 to VGA (included )
Optional M1 to DVI (available on HP accesories)
To connect laptop via HDMI to Projector you need a HDMI to DVI adapter + Cable M1 to DVI (you get ONLY Video on DVI Output)
To connect Wii to projector you need a M1 to Composite
look the manuals on page 20-30
You can download the user guide on
http://h10032.www1.hp.com/ctg/Manual/c00063031.pdf
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | HP mp3135 Multimedia Projector
I sometimes have a vertical line of distortion in the middle of my projection on my HP3135. It most usually occurs with dark colors but not always and also doesn't happen when the menu screen is being...
most likely the dmd board on the rear of the lens assy, but the main board can't be ruled out either. you can take it apart and try cleaning both ends of the connection between the main and the dmd and then reseating this firmly, it that doesn't work unless you know which part to replace, you should have it repaired. I have been frustrated working on projectors like this before and given a good hard but controlled slap on the top of the unit and the problem has gone away, but sometimes only for a minute or so.
May 19, 2010 | HP mp3135 Multimedia Projector
The orange warning/notice light is blinking on the top of the projector for the lightbulb icon
indicates the lamp has reach 90% of life time and needs replacement. check timer in menu to verify.
Jan 12, 2010 | HP mp3135 Multimedia Projector
Can i set up an xbox 360 on an hp mp3135 multimedia projector
Aug 18, 2009 | HP mp3135 Multimedia Projector
How do you change the bulb on a HP MP3135 projector
Aug 12, 2009 | HP mp3135 Multimedia Projector
Optoma DV10 color wheel
Okay, I recently had a loud noise coming from my projector and found online meterial stating that the colour wheel had been damaged. So with a bit of guts I managed to open the projector and found the colour wheel missing a segment.
I removed the colour wheel and the broken piece of the segement and tried to contact Optoma. Optoma turned round and said they cannot sell me the the colour wheel, which got me very upset. Some people claim online that Optoma will sell you the part on a back order at £50. (if you can be a little specific on how you managed to convince them to sell you the part, would be great).
The only option I had available was to send my project to them and they would repair for an estimated cost of £125+VAT. Guess what, you can buy the entire projector off ebay for 150quid!!!
Anyways after fiddling around quite a big online I got fedup and decided to glue the broken segment together and it SOLVED the loud vibration problem. I have colour and picture.
Becareful not to tighten the colour wheel screw too tight orelse it will break another piece of segement (Like I did).
Here are instructions on how to open up the projector.
http://www.geekfest.info/DV10/dv10.html
I cannot guarantee this will work for you as it depends on how badly you have shattered the colour wheel segment, so do at your own risk. I had two piece of the segment broken and a third by tightening the colour wheel screw too tight.
This will work for awhile but the colour wheel does need replaceing one day. If anyone can tell me how you can get Optoma to sell you the colour wheel would be great.
Best of Luck
Aug 08, 2008 | Optoma MovieTime DV10 Multimedia Projector
Optoma DV10 MovieTime Color Wheel replacement
Hi guys
Your best bet on getting your hands on a Service Manual would be to contact Optoma themself.
As for changing the colour wheel , it is pretty straight forward if you were able to open up the unit and get to it.
The colourwheel is mounted with three tiny scrws to a bracket in which it sits. And the bracket in it's turn is fastenend to the body of the Projector with two tiny screws.
First unscrew the bracket from the casing of the Projector and then take off the three screws that holds the Colour wheel to the bracket. Replace and do the whole proses again - but obviously just the other way round.
This is really easy to do yourself.
Give me a shout if you need any further assistance.
Thanks for using Fixya and good luck.
May 07, 2008 | Optoma MovieTime DV10 Multimedia Projector
VP6310 Colour problem
You need to replace the color wheel sensor. I can fix it.
Dec 10, 2007 | HP VP6310 Multimedia Projector
BenQ PB6100
Hi there
If your Projector is not working in colour , take out the lamp and check if the colour wheel is broken.
If not broken you will have to replace the Mainboard.
Dec 07, 2007 | BenQ PB6110 Multimedia Projector
HP mp3135 Multimedia Projector Logo
156 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
