Question about Aiptek MPVR Digital Camera
USB cable Where can i find a replacement USB cable?
  • markko Dec 03, 2007
    need accessories in austailia
  • 4,889 Answers
Can I buy a replacement charging cable?
not sure as this speaker uses a Y usb cable
I found a cable but not sure if it is the required cable as the cable has a 3.5mm stereo cable that goes into p.c. and a usb cable that then plugs into pc on one end and a micro usb plug that goes into the speaker.
check it out and decide if it looks like the same cable. ???
Oct 12, 2015 | Genius Sp-i160 Mini Portable Usb Speaker...
I need to replace the usb cable to access the hard drive and I can't find a replacement cable. can you help?
I am not sure what cable you are looking for, it sounds like a cable that goes from a USB external hard drive to the USB port of the computer. I have seen these cable both ways A-B and also A-A, if you don't know what type of cable it is, I would first refer to the manufacture's web page. If they don't have information on it I include a picture of the type of USB ends and a place to purchase a cable once you identify it.This is a USB A connector dfish26_2.jpg and this a be connector dfish26_3.jpg here is a website to purchase a cable.
I hope this helps.
Nov 23, 2010 | Computers & Internet
Usb cable not detected
  1. Disconnect one end of the cable and then reseat it ensuring the cable is firmly seated into the USB port. If the USB cable is plugged into a hub instead of directly into the computer, connect the USB cable directly into the computer.
  2. Repeat step one to reseat the cable on the other end.
    There shouldn't be any resistance when connecting the USB cable to the device. If the cable does not easily slide into the device's port, look at the end of the connector. The shape of the connector should match the port on the device.
    Note: All USB cables will have a USB icon on one side. The side of the cable where the icon is situated is different than the other three sides.
Icon on USB Cable
Shape of the USB Connector
  1. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
  2. Make sure the correct USB cable type is being used.
Incorrect (A to A) USB Cable
Correct (A to B) USB Cable
Nov 02, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Hp deskjet 3650 printer works very slowly with win 7
tion one: Check the power supply Follow these steps to check the power supply to make sure that it is functioning correctly.
  1. Turn the product so that you can access the rear side.
  2. Unplug the power cord from the back of the product. Figure 1: Unplug the power cord from the back of the product
  3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
  4. Plug the power cord directly into a wall outlet.
  5. Print and time a self-test again.
  • If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet.
  • If the test page takes significantly longer than 30 seconds to print, continue to the next solution in this document.
Solution two: Check the USB connection
  1. Disconnect the USB cable from the back of the HP product. Figure 2: Disconnect the USB cable from the back of the HP product
  2. Disconnect the USB cable from the back of the computer.
  3. Wait five seconds.
  4. Reconnect the USB cable to the back of the product and the computer, according to the following guidelines: The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Connect the small end of the USB cable to the back of the product Connect the other end of the USB cable to the computer
  5. After you make sure that the USB cable connects correctly and securely, review the following guidelines to check other potential USB-related problems:
    • USB ports on the keyboard. USB ports on the keyboard and in the front of some computers might not be powerful enough to support the product. If the USB cable connects to the USB port on the keyboard, try connecting it to another available USB port on the computer.
    • USB cable length. HP supports USB cables less than 5 m (16 feet, 5 inches) long. However, a USB cable that is 5 m (16 feet 5 inches) long must be of high-quality. Otherwise, HP recommends using a USB cable that is less than 2 m (6 feet, 6 inches). Do not use patch cables to increase the length of an existing cable. Use a powered USB hub if you need more length.
    • Alternate USB ports. Connect the USB cable to another port on the computer to make sure that the USB port on the computer is not the problem.
    • Defective USB cable. Replace the USB cable to make sure that the existing cable is not defective.
    • Conflicting USB ports. Disconnect any other USB printers, USB scanners, USB cameras, and any other USB connected peripherals. Start reconnecting these devices one at a time to determine if one of the devices is using too much power. Consider purchasing and installing a powered USB hub if necessary. NOTE: A USB-powered hub is a device that increases the number of available USB ports on a computer and facilitates communication between the USB devices and the computer. A powered USB hub can resolve communication failures between some, but not all, USB chipsets and HP products.
  6. After checking the USB connection, print and time a self-test page again.
  • If the test page prints in 30 seconds or less , the problem relates to the USB connection. Replace the USB cable or modify the connection to meet the preceding criteria.
Solution three: Check cartridge compatibility Incompatible cartridges can cause the slow printing problem. To check the cartridge compatibility for your product, go to HP SureSupply . To identify your cartridge in a language other than English, click the language link near the globe icon (c01906983.gif ) in the upper right corner of your browser. Examine the cartridges in your HP product, and then follow these steps to check which cartridges are compatible with your product. The number on the cartridge label must match the numbers listed on HP SureSupply.
  • If the cartridges are not compatible with your HP product , replace the cartridges. You can order replacement cartridges directly from HP SureSupply.
  • If the cartridges are compatible with your HP product , continue to the next solution in this document.
Solution four: Perform a reset A reset drains the power from the product and returns it to the same settings after restarting.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product. Figure 3:
  3. Disconnect the data cable (USB or Ethernet, depending on how your product is set up) from the back of the product. USB cable Ethernet cable
  4. Unplug the power cord from the wall outlet. Figure 4: Unplug the power cord from the wall outlet
  5. Wait about 30 seconds.
  6. Reconnect the power cord to the product and wall outlet, and then turn on the product.
  7. Print and time a self-test again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Mar 31, 2010 | HP DeskJet 3650 InkJet Printer
Not recognising the device
Jul 13, 2009 | iRiver E100 Digital Media Player
Usb cable
Players use standard USB, Mini USB, or Micro USB. I believe the one in title uses Mini USB cable.
To get a replacement cable go to any computer shop or camera shop and buy a Mini USB cable, take the player with you and show it to the shop assistant to ensure you are buying the right cable.
Jul 05, 2009 | Supersonic SC920FM MP3 Player
HP F2200 all in one/ usb
As you are receiving the USB device not recognized whenever you plug in the USB cable, the problem could be either due to the corrupted USB drivers on your computer or the USB cable needs to be replaced. Try updating your USB drivers and/or replace the USB cable. I am sure that the issue will be resolved.
Nov 23, 2008 | HP DeskJet F380 All-In-One Printer
Inability to install hp psc 1310 series printer
uninstall the previous installation, restart your pc remove the usb printer cable, reinstall the printer driver donot plug the usb cable until the installation program tells you, then plug the usb cable, if it is detected its ok if not replace the printer cable with usb2.0 maybe the usb cable is defective.
Aug 06, 2008 | HP Computers & Internet
G85 USB failure
You will have to replace the main board in order to get a new USB connection. Have you tried using the parallel connection. Looks like a regular parallel connection but smaller. It takes a special cable that was originally sold with the printer. We have those cables for $15 if needed. The USB cable may be out but the parallel connection may work fine.
Jul 28, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Lost my cords during a move
753 has a special mini usb cable only from kodak-buy a 20.00 sd memory card reader and use that to download-they work great!
May 20, 2008 | Kodak Easyshare M753 Digital Camera
Aiptek MPVR Digital Camera Logo
27 people viewed this question
Top Aiptek Cameras Experts
mohamed salim shaikh
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
