Question about Craig Televison & Video
How do i add a local channel by craig remote - Craig Televison & Video
What is the code for the Craig digital converter box to access channels
The remote that comes with your converter box will not work with your VCR/DVD recorder. You'll need a seperate universal remote - See more at: http://www.dtvusaforum.com/threads/3309-I-need-help-to-find-the-CODE-for-CRAIG#sthash.60Q0ehJJ.dpuf
Dec 31, 2016 | Craig Televison & Video
How do I program a craig tv remote. I have a TTXXX126-2D craig remote that I want to program to work with my craig CLC503 TV
If you have a Craig remote you are trying to use with a Craig TV, it should work without need for "programming". The codes are stored in the remote.
Sep 22, 2014 | Redi-Remote CRAIG Replacement Remote...
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
I cannot change the channel with the remote, and batteries are working...what do I need to do?
Look at the input or video select button. Change it once and attempt to change channels, if the problem persists continue to change the input selection until you can select channels.
THANK YOU AND PLEASE RETURN FOR ADDITIONAL HELP IF NEED BE.
Jan 09, 2011 | Craig CTV-41331 13" TV
Hello - two channels on my Panasonic TV (CT-27E13) have no audio. The rest are fine. Any Ideas? Craig
On the original TV remote press the SAP button on the top right of the remote. Keep tapping until the TV says stereo and this should fix the problem.
Good Luck and please rate this solution....
Jan 08, 2010 | Panasonic Televison & Video
Sanyo DS31350 31" TV problem
you need to buy the sanyo remote from www.sanyo.com
Dec 14, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
13 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
