Question about Wolff Sunquest Pro 24RS 220 Volts
How many amps does it draw - Wolff Sunquest Pro 24RS 220 Volts
Amp draw on #SMA-64140A
At which voltage?
If you have 120V to it, 4,000 watts is 4000 / 120 = 33.333A.
If you have 240V, 4,000 watts is 4000 / 240 = 16.667A.
Dec 11, 2013 | King Electric Heater. 4,000-Watt Fan...
Ice-O-Matic Electrical Problem
Have you checked the amp draw? sounds like it is pulling too many amps. machine may need a good cleaning. check compressor amp draw and condenser motor amp draw to specks. and how long is the cord the longer the cord the lower the voltage go's and amp draw go's up.
Jul 22, 2013 | Kitchen Appliances - Others
1994 dodge caravan se 15 amp ignitation off fusedraw still draws 00.04 amps
Milli-amps is the measure for draw of the computer memory, clock, and radio pre-sets. So, .04 amps is just a little more. Would that be like what a glove box light might draw? Try either pulling a few fuses and see if you still have a draw, or take the battery negative post off overnight, and see if battery is still good and hot the next day.
Good luck.
Mar 02, 2012 | 1994 Dodge Caravan
WHAT IS THE MAX AMP DRAW?
Max amp draw refers to the total amp draw of a unit , example : Compressor RLA 25 Amp, blower motor FLA 5 Amp, and condenser fan motor FLA is 1.5 amp , you add all three and get 31.5 Amps
which is your max amps, this is used in determining wire gauge and breaker size for unit.
This should help.
Jul 27, 2011 | Heating & Cooling
Air compressor starts fine,but trips the thermal reset ,motor seems hot. It does it in every receptacal I've tried.
With no air in the tank and amp meter connected to one leg of line, start compressor and note amp draw thru cycle. It should draw low amps at first then reach rated amp draw close to end of cycle(most likely 12-15 amps). If amp draw is normal then replace thermal breaker. Older compressors have thermal breaker incorporated within winding and may not be easily replaced (but not impossible). If amp draw is higher than rated, check capacitor for proper rating and make sure that the in-tank check valve is not leaking pressure back to pump. Good holidays
Dec 29, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Start up current draw
Lock motor Amps ( LMA ) is the current draw when the compressor starts.This draw of current is less then 1sec.The amp amount shoud be on the compressor Name Plate.This amp draw is also the amps used when the compressor goes bad and locks up then the overload kicks out.
May 21, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
What is the amp draw on a Liebert A/C Unit (FH245AUA00 - 480V 3 Phase) ?
amp draw will be 6.9 amps per leg cutout switch will be rated for 30 amp locked rotor per leg fan runs 5 amp draw continuous here is the web page it's pdf format. Liberty A/C Unit (FH245AUA00 - 480V 3 Phase http://www.rvii.com/bspdf/20x20x38.pdf.
Mar 17, 2010 | Heating & Cooling
Kenmore series 90 dryer kicks breaker often. Draws 20.9 amps
Well do the math.... 5000 watts divided by 220 volts =
22 amps
Feb 06, 2009 | Kenmore 63942 Dryer
Model fgf334bgwj gas range oven will not operate. I removed the oven bottom plate and deflection plate , the glow bar turns on but no gas flows to ignitor? Is it the gas safety valve?
When the ignitor glows brightly and the oven doesn't light it is usually a defective ignitor. The way to know if the ignitor is good or bad is to read the amp draw of the ignitor with an amp or watt meter. The gas valve and the ignitor are wired in series and for the gas valve to draw the current the ignitor has to draw 3.5-3.8 amps.If the ignitor is drawing 3.5-3.8 amps the new gas valve is defective. If it is drawing less amps the ignitor is defective.
Jan 25, 2009 | Kitchen Ranges
Power draw on start up
When the compressor first starts up it can draw as high as 15 amps but for no more then a second or two. After that it should run at 1-1.5 amp and will draw less as it continues to run. After 10 minutes it should pull anywhere from .5-1 amps.
Nov 04, 2008 | Haier White 2.7 Cu. Ft....
Wolff Sunquest Pro 24RS 220 Volts Logo
Top Wolff Health & Beauty Experts
Steve
NOEL
NOEL
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
