Question about Coffee Makers & Espresso Machines
Capresso c1000 cleaning cycle end with four blink green lights. and the clean brewing chamber light still on.
EsWorld
  • 1618 Answers
SOURCE: Jura C1000 - All red and green lights blink alternately.
Machine is not getting water.
Posted on Jun 30, 2009
  • 13 Answers
SOURCE: How do I disassemble and clean the brew unit motor
I have some good instructions I downloaded from www.kaffeestudio.com . They are in German, but with many pics. If you are technically adept, then it is really no prblem. You should put in new o'rings and lubricate with the food grade silicon grease before reassembly, otherwise it won't be long before you are doing it again. Give yourself about 3 hours to perform this task the first time. One thing to remember. The cleaning tablets tend to strip the lubrication from the brew units, subsequently binding up the brew unit, sometimes tearing the o'rings and giving the malfunction 8. Plan on this being an ongoing maintenance exercise. Plan on at least once every year or two to have to do this.
Posted on Oct 18, 2009
  • 10 Answers
SOURCE: Need an "O" ring Jura Capresso C1000
ebay has them
Posted on Nov 22, 2009
  • 10 Answers
SOURCE: Problem for Jura Capresso C1000 Espresso &
save a bundle, URNEX makes cafiza tablets, buy them by the 60 tabs or larger containers. Use them frequently and give some to friends. I've used them for years. find them online.
Posted on Apr 15, 2010
SOURCE: Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Posted on Jan 22, 2011
Hello You Coffee machine friends. I have a problem that I don't seem to find the solution.I just replaced the two large O rings and cleaned the complete machine.I left the machine in the resting position...
I've done a couple of these and it can be tricky to get the lower piston the correct height when reassembling it. Did you make sure that the entire brew group would fully cycle (the white gear travels from to to bottom) without binding before reinstalling it? It seems to me that the piston has to mesh with the gears in JUST the right configuration so that it will come to the top of its travel without biding on the housing or being to low in the chamber when it goes through the ejection phase (dumping the grounds). I don't have a fool proof method to do this other than trial and error. I'd go back and take apart the group again and make sure the lower piston is aligned correctly and that it doesn't bind when you screw the gear all the way up and down. Good luck!!!
Mar 08, 2015 | Jura Capresso C1000 Espresso & Coffee...
Mr coffee problems
You didn't indicate a specific model. So, I'm going to assume yours is relatively the same as my JWX27.
Let me start by clarifying what the red light indicates.
A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but due to be cleaned. When the coffeemaker is due to be cleaned, the red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The entire cleaning process takes about an hour and a half. And, it is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Jul 20, 2014 | Mr. Coffee Coffee Makers & Espresso...
Clean instructions
First, let me clarify what the red light indicates.
Feb 04, 2014 | Mr. Coffee JWX27 12-Cup Coffee Maker
Clean unit
After making approximately 200 coffees, the internal brewing chamber and the
brewing unit must be cleaned (of coffee oils, etc.). The display will show
CLEAN UNIT alternating with the regular message. This indicates that it is time
to run the tablet cleaning cycle
Feb 20, 2012 | Jura Capresso C1500 Espresso & Coffee...
Cant get the cleaning cycle to end dont know how to get it off
If the red light is still blinking, then the cleaning cycle has not yet been completed. The cleaning cycle is not intuitive. So, here are my instructions.
Jan 07, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
I need to clean my capresso c1000. i can't find the instructions. i put a cleaning tablet into the ground coffee area, and ran the ground coffee button a few times. is that it?
No, first push the self clean button (hold until lights come on). Then pull the grounds unit and empty it, that will turn off one red light. Fill the water tank. Then drop the tablet. Then hit the ground coffee button. Cycle through and dump the grounds each time the grounds light illuminates.
Jul 09, 2011 | Jura Capresso C1000 Espresso & Coffee...
We ran the clean cycle on the coffee maker and the clean cycle will not turn off.
First, let me clarify what the red light indicates. A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but is due to be cleaned.
The red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The process takes about an hour and a half and is not intuitive. So, here are my instructions.
May 15, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
Cleaning with tablet
Your water system is clogged with minerals. Try decac first. If that doesn't work you will have to have a pro manualy search for the blockage. www.hotncold.com
Jul 04, 2008 | Jura Capresso C1000 Espresso & Coffee...
Capresso C1000 - Coffee is going into the coffee grounds bin rather then
I had this same problem water going into the grounds disposal chamber, plus all green and red lights flashing. Was told if I could clear the lights to clean the screen and run a tablet cleaning. I was able to clear the lights tried to run the cleaning but it failed again. I have had my machine for over 4 years so instead of sending it back I decided to take it apart. The problem I found is an O-Ring that runs inside of the compression pump chamber failed, if I can find an O-ring that is the same size I believe it will be as good as new.
Dec 01, 2007 | Jura Capresso C1000 Espresso & Coffee...
Coffee Makers & Espresso Machines Logo
62 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
