Question about X-10 Dimmable Remote Lamp Module Lm465
Fix LM465 flashing
After working 5 months 40W incandescent bulb stared flashing when when module is turned on. A different AC outlet, different bulb and different table lamp did not fix. I can open it and make repair if you know what is wrong.
Yamaha vstar 650 2007 turn signals stays solid on and does not blinks after front turn signal replacement to led's.
flashers work buy a set current flow
flasher bulbs are 20 watt or better
by replacing the bulbs with LED ( virtually no current flow ) the flasher will not get enough current to make it flash
you have 2 options
go back ti normal bulbs
get an electronic controlled flasher unit that compensates for the lost current
best talk with an auto electrician as to what you need to fix the problem
Oct 07, 2016 | 2007 Yamaha V Star Custom
How to flash a generator
Get two short extension cords and cut the FEMALE end off each one. Strip back the insulation on that end. Connect the two green wires to each other, and connect the two white wires to each other.
Connect one black wire to a light switch, and connect the other black wire to a 20W appliance-type incandescent light bulb. Also run one short black wire (from a cut-off end) from the second terminal on the light bulb to the second terminal on the switch, like so:
plug -- black -- switch -- black -- bulb -- black -- plug
plug -- white ----------------------------------- white -- plug
plug -- green ---------------------------------- green -- plug
Turn the switch to the OFF position.
Start the generator. Plug one plug from your new rig into an outlet on the generator. Plug the other plug from your new rig into a wall outlet supplying 120V. With the generator running, turn the switch to the ON position.
The bulb should flash for a short while, then become steady. When it's steady, that side of the generator is flashed. Repeat for the other side of the generator if it makes 240V.
Jul 22, 2014 | Electrical Supplies
Cannon penncraft cannon work
Jul 12, 2014 | Electrical Supplies
How do i flash my generator to get power again
Jul 10, 2014 | Electrical Supplies
Wired in new directional on sportster wont flash
From your description, it sounds like the new bulbs (that won't flash) are LED bulbs.
When you replace the stock Harley incandescent bulbs with LEDs, you NEED to add a LOAD EQUALIZER to make the bulbs flash:
http://www.jpcycles.com/product/381-877
The amp draw is different with LEDs, and they won't flash without the equalizer.
May 06, 2014 | 2001 Harley Davidson XLH Sportster 883...
On sa 210, when timer off (either from program or manually switched off) correct "bulb off" status is displayed on the indicator, but the power doesn't go off from the outlets. this problem...
Most digital timers can be restored by resetting timer and then reprogramming.
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
http://waterheatertimer.org/pdf/Sylvania-SA-210-Manual.pdf
Sylvania tech support: 888-548-4484
www.hardwareinnovations.com
Sylvania timer has 1 year limited warranty.
Sylvania timer can be used for 1000W incandescent Loads and Motor loads up to 1/4Hp
All outdoor timers are susceptible to power surge from nearby lightning.
Timers are also affected by line noise and incorrect outlet polarity.
Test outlet with circuit analyzer. Use timer to control different Load on different outlet.
If more than one timer has same problem, then suspect can be line noise and outlet polarity.
Heavier-duty Intermatic HB8800RCL timer has limited lifetime warranty, and controls 1800 watts and 1/3 HP.
http://www.amazon.com/Intermatic-HB800RCL-Seven-Outdoor-Digital/dp/B001KBZUNK/ref=pd_cp_hi_2
Aug 05, 2011 | Sylvania SA210 15 Amp Zip-Set Digital...
Indoor timer 0155671 it wont turn on or off after programing
Utilitec 0155671 7-day digital programmable timer is sold under different brand names and numbers
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Read instructions on following link.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
There are 7 general things to look for if digital timer is not working correctly.
1) 0155671 timer is considered incandescent light bulb timer (tungsten) and not necessarily made for motors loads, TVs, CFLs etc. Try using timer on table lamp with incandescent bulb. Turn lamp ON, and make sure bulb is good.
2) Outlet is wired wrong: test outlet with circuit analyzer, and try timer on another outlet, and with different load. For example if outlet polarity is reversed, or if load has interference.
3) Timer is programmed for ON times but not for OFF times.
4) Programming has conflicts, for example program1 ON is for 8am Mon but program1 OFF is for 11am all-days-of-week.
Or program1 and program2 ON-and-OFF times conflict.
5) Timer is not set in AUTO mode, and timer is in random or countdown mode.
6) Timer is defective: 6-8% of all timers arrive defective.
7) If timer is older, the internal battery may be fading. Battery is not replaceable. These timers have 1 year limited warranty.
Jul 11, 2011 | Hardware & Accessories
The dimmer switch will turn on and off but wont dim the lights on a chandelier. model 6681-w. tried 2 different ones with the same results.
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
http://www.google.com/products/catalog
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
http://www.amazon.com/DIMMABLE-COMPACT-FLUORESCENT-LIGHT-SPIRAL/dp/B0014B84ZM
Oct 31, 2010 | Leviton #L11-06681-00I Ivory 600 Watt Push...
Cannot find Nexxtech model 6102691 mini timer manual. Would also like to purchase remote modules for the above timer.
This looks like the module you are looking for.
http://www.homesecuritystore.com/p-575-lm465-x10-lamp-module.aspx?affiliateid=10054&zmam=55691497&zmas=1&zmac=4&zmap=LM465
Mar 11, 2009 | NexxTech (DR30G0) System
X-10 Dimmable Remote Lamp Module Lm465 Logo
52 people viewed this question
Top X-10 Home Security Experts
Lawrence Oravetz
Are you a X-10 Home Security Expert? Answer questions, earn points and help others
