Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
I recently have had the 20 amp fuse for the tractor starting / blade engagement fuse keeps blowing . What is this fuse for and why would it keep blowing out ? Huskaverna /48"/Rider/23HP
  • salemi_geral Jun 23, 2009
    I will check this out and get back to you .
    Thanks,
    Gerald Salemi
    I will check this out and get back to you on what I find .
    Thanks
    Gerald Salemi
    Top Expert:
  • Husqvarna Master
  • 81,342 Answers
THE FUSE IS FOR THE BLADE ENGAGEMENT ACTUATOR MOTOR SOLENOID, EITHER THE MOTOR IS SHORTED OR THE WIRING TO IT IS SHORTED, GET IT UP IN THE AIR AND CHECK ALL THE WIRING UNDER THE TRACTOR FOR WEAR (BARE WIRES) AND WIRES TOUCHING/SHORTED TO METAL.
Posted on Jun 23, 2009
Even with the mower not running when i pull the switch to engage deck it blows 20 amp fuse
Kelly, ray g. nailed it, First be sure it is only to be a 20 amp fuse, The wires to the clutch that drive the deck will be broke or bare shorting out on each other or on metal, wire are quite commonly broke by the clutch plug or close by. what you can do is carefully follow the wire from switch through the system and look for damage or bare spots, pay special attention when wire runs through frame/body holes and any where it could rub on metal or moving parts. Check the attached links,instruction and guides,4th link see Randy T. reply in forum, has good test method for your problem. Good Luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Craftsman 917 273631 Fuses keeping blowing when blades are engaged
CC1042 with Kohler Keeps Blowing Fuse when PTO Engaged
Blowing Fuses
265 blowing main fuse when engaging PTO
Apr 25, 2016 | Garden
I have a sabre garden tractor that keeps blowing the fuse for the ignition i found no bare wiring anywhere.
The only reason a fuse blows is because it got overloaded(too much amps). Most lawn/garden tractors use separate soleniod for the starter and you said it blows a fuse as soon as you turn on the key. At that point the starter wouldn't(or shouldn't) have any current to it at all. A stuck on soleniod would keep the starter engaged till you unhooked one of the battery cables. Find what that fuse protects in electrical system and start looking for bare wires, maybe a wire has rubbed through where it's laying against metal
May 13, 2015 | Garden
Blades wont engage
Check for power to the clutch from the switch or could be a bad relay
Jun 16, 2013 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Why does my mower keep blowing the 20 amp fuse
could be the safety switch for the pedal
Apr 23, 2012 | Husqvarna Garden
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Starts and runs good but after an hour of cutting when you turn off.. then you want to cut again it will start just fine but when you engage the blades the fuse blows it has a 20 amp fuse is this the right...
I normally see 30 amp fuses to the deck...but it depends on which mower you have. If you place a larger fuse and it does take a 20 amp..you may burn something up. I would check the blades, spindle towers and clean all the stuff on top and inside the deck to look for something catching on the blades. www.nnyparts.com
May 27, 2010 | Garden
Have a 2005 18.5 hp poulan riding lawn mower, wouldnt start so i replaced battery and solenoid and 20 amp fuses, startyer was checked and fine. Finally got it started and now it won't mow, blows 20 amp...
most likey you have a short . how do you ingage your blades by button or lever. if the button type look for a shorted wire . look for a bad wire some times mice get in to it and chew wires .
Apr 09, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a Husqvarna Yth 180, the lawn mower shut off when I engage the blades to cut grass. I blows the 20 amp fuse near the wire harness
try unplugging the pto then start the mower next engage the blades and see if the fuse blows if it does the problem lies in the mowers wiring if not the problem lies in the pto. hope this helps
Jul 13, 2009 | Husqvarna Garden
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
FUSE BLOWS WHEN BLADES ARE ENGAGED CRAFTSMAN MODEL # 917.27686
Most probably you have a wire shorting to the frame of your mower.
Trace (follow) the wires from the switch, checking for any frayed, burned, or bare wires.
Repair as needed.
Apr 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
324 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
