Miele W723 front loader - How do you change the carbon brushes?
3 Suggested Answers
  • 225 Answers
SOURCE: How to cahnge carbon brushes
The brushes usually "come complete with brush-holders", which is a way of selling you something extra that you don't need. Easiest way is to disconnect the machine from the power and the water, turn it onto its front on an old cardboard box and remove the motor from its mountings on the washer. You can usually get acces to one of the brushes really easily and the other is guaranteed to be a real pig, so keep it simple. The brush-holders are usually fastened to the motor casing with either self-tapping screws or small bolts.
I buy my brushes from Ebay sellers and always send them a digital photo of the old brush together with the make and serial number off the motor itself, just to be sure. Brushes can look similar and be that silly millimetre too short, or long, or wide.
Did that answer the question? If not, add a comment and I'll expand further as necessary. Cheers, D.
Posted on Jul 22, 2008
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
Programme won't move on - rinses flashing and programme won't continue
Hi dear. Regarding your information, I would say 3 factors play up with it.
1- Tacho generator or it's plug faulty on motor
2- Motor Carbon brushes worn out or
3- Power/control unit faulty.
I can advised to contact your local Miele center to diagnose your machine.Thanks.
Apr 17, 2016 | Miele 300 Front Load Washer
Miele w911 washing machine Main Wash light flashing. Replaced carbon brushes. Machine needs kick start or ???
carbon brushes r black as, well, carbon. They need replacing when they r worn not blackened.
try something else
Feb 18, 2015 | Miele Washing Machines
Hi i just want to check to see if belt is ok, but dont know where to look, i have a drum wont turn
Its probably your motor carbon brushes. If the machine electricals work OK and it pumps water in and out then the carbon brushes have just worn out on the motor. I had the same problem with my Bosch front loader. Easy fix and you can get help visually on youtube. If you are looking for the belt to see if it has come off, undo the screws that hold the plate on the back of the washing machine to access and sight the belt. Also this will give you access to the motor if you need to change the motor carbon brushes. Hope this helps Sue
Aug 09, 2011 | Bosch Washing Machines
10 year old miele 300 washing machine jumps to
Most likely brushes. Fit carbon brushes part no.4297411 as they are less then half the price of the brush module Part no. 4229779.
Jun 15, 2010 | Miele 300 Front Load Washer
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
May 21, 2010 | Miele W865 Front Load Washer
Our Hotpoint front loader wont work We managed to get the clothes out, but it wont start new cycle We need a technician in the western sub's Melbourne to fix bridgey@austar.com.au
hi try changing motor brushes (carbons).... if they ok check pump filter and test with volt meter on heating element on contonuity test.it should be in curcuit..
Jan 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
The washer runs through entire cycle but when it gets to the spin cycle the motor clicks on but does not spin
Hi there....you havent stated whether its a top loader or a front loader.....top loader 1st.....
usually caused by a defective drive clutch..this will require the drive mechanism to be removed and a relacement clutch fitted
front loader 2nd...this is usually caused by failed spin windings in the motor..worn carbon brushes in the motor.or a failed programmer....
regards Sir Galahad
Aug 16, 2009 | Washing Machines
Washer fills and drains but does not agitate or spin.
all front loaders have two motor brushes, The motor brushes are carbon and generally have a life span of 4-5 years with daily use. When these carbons wear down they make less contact with the motor armiture and need to be changed. For a service engineer this takes approx 15-20 mins and the parts cost approx €30-€60 in europe depending on the model. Melee and Beko tend to be the most expensive (But Melee brushes are far superior quality)
May 07, 2009 | Washing Machines
Jul 22, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
381 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
