Question about Alba Watch Alba Ladies Sports Sapphire Crystal AXT927X1 AXT927
Alba crystal sapphire - Alba Watch Alba Ladies Sports Sapphire Crystal AXT927X1 AXT927
Usually,which kinds of material can be used as optical components?
Sapphire, Fused Silica, Crystal Quartz, Silicon, Germanium, BK7, CaF2, BaF2 and all kinds of Color Glasses, Non-Linear Crystals and Laser Gain KTP, KTA, BBO, LiNbO3
For more: http://antyco.com/
Oct 12, 2016 | ATN Optics
What are materials can be further processed in Fuzhou Antyco Optics?
Our most competitive materials are: Sapphire, Fused Silica, Crystal Quartz, Silicon, Germanium, BK7, CaF2, BaF2 and all kinds of Color Glasses, Non-Linear Crystals and Laser Gain KTP, KTA, BBO, LiNbO3
Oct 08, 2016 | ATN Optics
How can I changw the glass for this watch?
In order to replace the crystal on your watch you are going to have to remove the entire movement and use a watch press to remove the crystal.
this is not an easy job and should be done by a professional
First you will need to get a watch back opener to unscrew the back of your Tag. The three slots should fit into the back of the watch. tighten the opener until it is firmly on. then turn counter close wise until back of case comes off.
Next you will need to remove the watch hand and crown. Becareful doing this for pressing to hard will break your set leveler. You will need a thin pin pusher and look on the back of the movement for an arrow pointing toward a hole in the movement. Push down and at the same time pull the stem and crown out of movement. turn the watch right side up and the watch movement should fall out. Place movement on a very safe spot so not to damage movement or dial
now you will you be ready to remove crystal Since it is a friction crystal you will need to do use a watch case press . find two die that fit exactly the watch and crystal use a scooped side and place it on the bottom side of the watch press. Next use a flat die to place on top of the case press. place the watch face down. you will be pushing the watch crystal out from the top. Press down on the level and check to see if the crystal came loose, keep doing so till the crystal comes out.
finally you will need to measure the thickness and diameter of the crystal and find the exact size. I believe this watch has a sapphire crystal so you will need a sapphire crystal too.
Once you buy the proper crystal it is time to put the it in the watch. Place the watch face up in your watch press. and slip the crystal in through the top making sure its perfectly even all around. Slowly push down on the leveler until proper pressure is applied and the crystal snaps in.
Now you have new crystal . Clean crystal thoroughly and the inside of the case. Place watch upside down carefully place movement back in. slide spacer in . Now slide watch stem and crown back in push down again on the set leveler with pin pusher.
Place case cover on back and tighten properly to prevent water or moisture from entering and you are done.
This repair should be done by a professional especially on such a nice watch. Any watchmaker can do this job and will have the tools to do it properly
Jan 27, 2012 | Tag Heuer Carrera GMT WV2113.FC6169 Wrist...
The crystal is scratched, can I fix that myself?
Thanks for contacting FIxYa.
  • Use a jeweler's loupe to identify all scratches on the watch crystal. You do not have to remove the watch crystal from the watch.
  • Use a polishing cloth to remove dirt, grit, lint or any debris on the watch crystal. Squeeze a small amount of standard toothpaste with abrasive properties onto the watch crystal. Gently brush the toothpaste into the crystal for five minutes. Wipe clean the watch crystal. and repeat another five minutes.
  • Use the jeweler's loupe to inspect your progress. Repeat application if necessary. Apply Brasso polish once the watch crystal is wiped clean. This will polish the crystal to a clear, bright shine.
  • Apply Autosol or Polywatch to the watch crystal in the same manner as toothpaste if you prefer to use a product specifically designed for watch crystals. These products will provide the same results as toothpaste. You may also apply Cerium Oxide, a glass scratch remover used specifically in the window manufacturing industry.
  • Apply a small amount of 3-micron diamond paste using your finger or a Kleenex if removing scratches from a sapphire crystal. Rub the paste in for about five minutes. Remove paste with cloth. Buff the sapphire crystal with one-quarter micron buffing diamond paste for finishing.
  • Use a toothpick to remove excess polish and gunk that may accumulate between the crystal and the bezel that secures the crystal in place. Gently work the toothpick around the diameter of the bezel. Wipe the bezel clean with a cloth.
  • Buff the watch crystal with a polishing cloth.
  • OR..take to a local jeweler/watchmaker.
    Best regards. Jewel
    Sep 10, 2010 | Relic Watches
    Watches T Touch Stainlesssteel case and bracelet sapphire crystal 30m water resistant men watch Watch for Men: Very interesting sites., ...
    Link
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
    Please feel free to browse above link for your desired watches.
    Thank you.
    May 17, 2010 | Tissot T Touch Stainlesssteel Watch
    Glass that covers the face of the watch is shattered-$ to replace
    I am not sure about prices in US, but over here in England we charge £15 - £25 for mineral glass (depending on size, thickness, e.t.c.) and £50 - £120 for sapphire glass. As for today: £1 = 1.60$. Doesn't matter how you name it - glass or crystal, both are right.
    Jan 11, 2010 | Bulova Watch
    I have a ladies Philip Stein, w, double movement. Tried to buff crystal. Now neither movement is working. Batteries are OK
    If the stems are in the time positon and the batteries are ok what probably happened is extreme heat. You tried to polish a mineral crystal and it got hot. The only type of crystal you can polish is acrylic. Most of these models come with mineral crystal or scratch proof sapphire crystal. I recommend going to a watch maker/technician and having the movements replaced. A reputable watch maker/technician will be pretty reasonable.
    Sep 19, 2009 | Philip Stein Teslar Small Case Diamond...
    Alba Watch Alba Ladies Sports Sapphire Crystal AXT927X1 AXT927 Logo
    63 people viewed this question
    Top Alba Watch Exercise & Fitness Experts
    Howard
    Howard
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you an Alba Watch Exercise and Fitnes Expert? Answer questions, earn points and help others
