Question about Garden
How do i get my lawn mower to start, it starts for a 2nd and then cuts off
My lawn mower starts up for a few seconds and then cuts off
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
SOURCE: my craftsman rotory lawn mower 6.5 hp self
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
Posted on Aug 13, 2009
mrrichardlbo
  • 59 Answers
SOURCE: Troy built 6.5 21" lawn mower won't start
take the carb bowl off it may have water in it , that will make it not run
Posted on Aug 16, 2009
SOURCE: lawn mower will start when primed but will only run for few secon
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Posted on Jul 06, 2010
hunter19_46m
  • 7482 Answers
SOURCE: My lawn push mower will
Check to make sure you are getting fire/spark at the plug, if so then do the following:
Check/Clean/Replace your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 16, 2011
MTD Chipper 242-641-000 will crank and run for a short period of time, then cut off. I can spray engine start and it will run for a few seconds.
sounds like the carburetor needs cleaning OR your gas tank Vent is clogged. Try the easy thing first. loosen the gas cap and see if the mower will keep on running.
Sep 11, 2013 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Weed eater starts but only runs for a few seconds and cuts off. prime it and starts but only runs for a few secounds and cuts off again
check gas line in gas tank. See if Stone filter broke off of gas line.
Very common with this new crappy Ethanol gas
Aug 23, 2013 | Garden
Mower will start but won't stay running as it cuts off in a few seconds
how do i replace the primer bulb on my yard machine thanks 21 in cut 6.50hp 190cc
Oct 01, 2011 | Toro Lawn Mower With Toro Power Tools
Lawn mower ran out of gas, after refilling it will start, run for a few seconds and cuts off. There is no primer button for this model.
It would be best to take this machine into a dealer like www.arcolawn.com and have the thermostat checked out. There were some early autochoke thermostats that would stick and cause problems.Best wishesJoewww.barter-joes.com
May 18, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Toro lawn mower
ethaanol in fuel...happens when gas sits too long...especially in a gas can in the garage
Apr 10, 2010 | Toro Lawn Mower With Toro Power Tools
Troy bilt mower won't stay running to cut lawn
Jim
May 29, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Poulan Pro riding mower jerks in forward and the blades engaged
This is a lawn mower catagorized as a chainsaw. We don't answer lawn mower questions ands you don't cut down trees.
Mar 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
