Question about Stihl HT101 Pole pruner
Attaching line from gas tank - Stihl HT101 Pole pruner
  • Stihl Master
  • 1,807 Answers
Posted on Mar 07, 2015
How do you remove gas tank from craftsman lawn tractor 917.20390 ?
First, drain the tank. Then pinch the clips attaching the gas line (you'll need needle-nose pliers) and slip off the gas lines. There will be some gas spillage - it's unavoidable. There will be some bolts holding the tank to the mower chassis. Loosen and remove them. If you have a manual, consult it at this point. If you don't, just think logically and you'll be OK. NOTE: YOU DO NOT WANT TO ATTEMPT THIS IF THE ENGINE IS STILL HOT AS IT COULD BE VERY DANGEROUS.
Jul 26, 2017 | Craftsman Garden
How do I run new hoses from gas tank to carburetor?
There is a slightly easier way of getting the lines in which attaching a tag wire to end of the taper tubing and pulling the line thru the tank openings. Most time you don't even need to lube the lines and if you use the regular two fuel mix.
Here is picture of the wire is attached.
Nov 04, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
How to replace a fuel pump on a1997 Chev Venture
  1. Properly relieve the fuel system pressure and install a pressure test gauge according to the tool manufacturers instructions.
  2. Turn the ignition switch to the ON position for 3 seconds, then turn to the OFF position for 5 seconds. Repeat this procedure two or three times to pressurize the system. Again turn the switch to the ON position.
    1. On TBI equipped vehicles, the gauge should read a static pressure of between 9 and 13 psi (62-89kPa)
    2. On SFI equipped vehicles, the gauge should read a static pressure of between 41 and 47 psi (248-325kPa)
    3. If not, check for a clogged fuel filter, a kinked fuel line, or an inoperative fuel pump.
  3. On TBI equipped vehicles, the fuel pressure will drop after the fuel pump stops running due to a controlled bleed in the fuel system. Use of the fuel pressure gauge will determine if the fuel system pressure is enough for the engine to start and run.
  4. No fuel spray from the injector indicates a faulty fuel or ignition system or no PCM control of the injector.
  5. This test will determine if the ignition control module is not generating the reference pulse or if the wiring or PCM are at fault. By touching and removing a test light to B+ on CKT 430 (purple/white wire from the ignition system), a reference pulse should be generated. If the injector test light blinks, the PCM and wiring are OK.
If the pump tests bad...
Disconnect the negative battery cable.
  1. Relieve the fuel system pressure.
  2. Block the front wheels and raise and support the rear of the vehicle safely. Make sure the rear is high enough to accommodate the removal of the fuel cell.
  3. Loosen the fuel filler neck connecting tube clamp at the tank.
  4. Wrap a shop towel around the fuel filter neck connecting tube and slowly remove the fuel filler neck connecting tube from the fuel tank.
  5. Position a siphon hose into the fuel tank through the fuel filler opening. Place the other end into an approved container with enough capacity to hold the fuel in the tank. Siphon the fuel.
  6. Raise the vehicle to gain access to the fuel tank. Make sure the vehicle is safely supported.
  1. Disconnect the tail pipe hanger attaching bolt.
  2. Remove the muffler hanger attaching bolts and remove the muffler hanger.
  3. Loosen the converter hanger attaching nuts.
  4. Remove the two heat shield attaching screws and note the position for reassembly.
  5. Support the exhaust and move the heat shield to gain the access to the right side of the fuel tank retaining strap attaching bolts.
  6. Remove the in-line fuel filter body clips.
If the nylon fuel feed or return lines becomes kinked, and cannot be straightened, they must be replaced. Do not attempt to repair sections of the nylon fuel lines.
  1. Disconnect the quick-connect fitting at the fuel filter, and return line fitting.
  2. Disconnect the fuel tank electrical connector.
  3. Disconnect the vapor hose at the fuel tank.
  4. Disconnect the vent hose at the fuel tank.
With the aid of an assistant, support the fuel tank, remove the left and right tank retaining strap attaching bolts, and remove the tank.
  1. As necessary, remove the fuel sending unit (which includes the fuel pump), as outlined, in this section.
  2. Then you can change the pump:
  3. Remove the fuel sender assembly.
  4. Disassemble the fuel pump strainer and the fuel pump: Note the position of the strainer in relation to the pump.
  5. See Figure 3
    Fig. 3: Remove the fuel tank locking ring with a non-sparking (brass) punch.
    1. Support the fuel pump in one hand, and grab the strainer in the other hand.
      1. Rotate strainer in one direction and pull off pump. Discard strainer.
      1. Remove deflector.
    1. Disconnect the fuel pump electrical connector.
    2. Loosen the two connecting clamps, if equipped.
    3. Place the fuel sender assembly upside down on the work bench.
      1. Pull the fuel pump downward to remove it from the mounting bracket, then tilt the pump outward and remove it from the connecting hose or the fuel pulse dampener.
    4. It is recommended to replace the hose and clamps, if equipped.
    To install:
    1. Push the fuel pump assembly into the attaching hose. Attach the pump electrical wires and fasten the hose clamps to the attaching hose and around the pump body, where equipped.
    2. Place the fuel tank sender and pump assembly into the fuel tank. Use a new O-ring seal during assembly.
    3. Then put the tank back in:
      1. If the fuel tank is replaced, transfer the fuel feed and return lines from the mounting clips, the vapor hose from the mounting clips and the vent hose from the vent hose fitting.
      2. Check the fuel filler neck for cracks and holes and replace as necessary.
      3. Install the fuel sending unit.
      4. With the aid of an assistant, position and support the fuel tank and install the left and right tank retaining strap attaching bolts and tighten to 18 ft. lbs.
      5. Connect the vent and vapor hoses.
      6. Connect the fuel sending unit electrical connector.
      7. Connect the quick-connect fittings as outlined.
      8. Position the fuel sending unit electrical connector and fuel return line under the in-line fuel filter bracket.
      9. Install the in-line fuel filter and new body clips.
      10. Reposition the heat shield as noted during removal and tighten the retaining screws to 18 lbs. ft.
      11. Tighten the converter hanger attaching bolts to 20 lbs. ft.
      12. Install the muffler hanger and attaching bolts and tighten to 18 lbs. ft.
      13. Install the tailpipe hanger attaching bolt and tighten to 20 lbs. ft.
      14. Lower the vehicle, add fuel and install the fuel filler cap.
      15. Connect the negative battery cable.
      16. Turn the ignition switch to the ON position for 3 seconds, then turn to the OFF position for 5 seconds. Repeat this procedure two or three times to pressurize the system. Again turn the switch to the ON position and check for leaks.
Mar 09, 2011 | 1997 Chevrolet Venture
Removal of gas tank
Fuel Tank Assembly Removal & Installation Single Tank To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section
  2. Relieve fuel system pressure (See: Fuel System Relieving)
  3. Disconnect the negative battery cable
  4. Raise and support the vehicle
  5. Drain the fuel tank in an approved container
  6. Remove or disconnect the following:
    • evaporative emission (EVAP) canister Disconnect fuel lines for single tank gm_trk_sub15_fuel_line_rem_singl_tnk.gif
    • Chassis fuel lines (B) at the fuel tank (A)
      1. Cap the fuel and EVAP lines to prevent possible fuel system contamination
    • EVAP vent line at the fuel tank clip (E) Disconnect vent hose and filler hose gm_trk_sub15_vent_filler_hoses.gif
    • Vent hose and filler hose clamp (D, B)
    • Vent hose and filler hose from the line
  7. With the aid of an assistant or a suitable jack support the fuel tank
  8. Remove or disconnect the following:
    • Fuel tank strap attaching bolts
    • Fuel tank straps
  9. Carefully lower the rear of the fuel tank slightly
  10. Remove or disconnect the following:
    • Fuel sender and the fuel pressure sensor electrical connectors
    • Fuel tank
  11. Place the fuel tank in a suitable work area Fuel lines at the tank gm_trk_sub15_fuel_lines_at_tank.gif
  12. Remove or disconnect the following:
    • Fuel feed and return lines (C) from the fuel sender and the retaining clips
    • Fuel pump assembly from the fuel tank
    • EVAP line from the fuel tank roll over valves (B, D) and the retaining clips (A)
    • Fuel fill hose and the vent hose from the fuel tank
    • Fuel tank
To Install:
  1. Install or connect the following:
    • EVAP line to the fuel tank roll over valves and the retaining clips
    • Fuel pump assembly to the fuel tank
    • Fuel feed and return lines to the fuel sender and the retaining clips
    • Fuel fill hose and the vent hose to the fuel tank; torque hose clamps,
      1. Torque to: 22 lb-in. (2.5 Nm)
  2. With the aid of an assistant or a suitable jack support and partially raise the fuel tank front end first
  3. Install or connect the following:
    • Fuel sender cover
  4. Fully raise the fuel tank
  5. Install or connect the following:
    • Fuel tank straps
    • Install the fuel tank strap attaching bolts;
      1. Torque to 30 lb-ft. (40 Nm)
    • Fuel fill hose and the vent hose to the lines;
      1. Torque hose clamp to 22 lb-in. (2.5 Nm)
  6. Torque the vent hose clamp,
    • Torque to: 22 lb-in. (2.5 Nm)
  7. Connect the EVAP vent line to the fuel tank clip
  8. Remove the caps from the fuel and EVAP lines
  9. Install or connect the following:
    • chassis fuel lines at the fuel tank
    • EVAP canister
  10. Lower the vehicle to the ground
  11. Fill the fuel tank with clean fuel
  12. Install the fuel filler cap
  13. Connect the negative battery cable
  14. Use the following procedure to inspect for leaks:
    • Turn the ignition on for two seconds
    • Turn the ignition off for 10 seconds
    • Inspect for fuel leaks
  15. Install the engine sight shield
  16. Road test the vehicle to check performance
Feb 12, 2011 | 2000 GMC Sierra
Which fuel line "port/inlet" on the Walbro wt-380 goes to the fuel tank? It's on a Craftsman 25cc Gas "Weed Wacker" Line Trimmer purchased in 2002. It has Walbro WT-380 carburetor with external primer...
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Jun 25, 2010 | Craftsman 25cc Gas Line Trimmer
Replacing a 2000 chevy blazer fuel pump and help
the gas tank will be needed to be dropped to gain access to the top of the tank to remove the sender with the attaching fuel pump on it. basicly you disconnect all lines first then the tank straps. the tank will be lighter if no fuel is in it too
Feb 13, 2010 | 2000 Chevrolet Blazer
Replace gas lines cant get fileter inside tank and gas line throug to engine
While accessing the inside of the tank thru the fuel cap hole,try attaching the hose to the filter and place it in the tank, then use a coat hanger bent enough to allow you to push the other end of the hose thru the small opening in the tank. Pierce the end of the hose that you pushing thru the tanks small hole. You'll waste about an inch or two of hose while pushing the coat hanger thru, so make sure you have extra in your overall length of hose you purchased. You did not mention what type of blower, so i'm guessing this trick will work for you. It's not easy to do, but it has always worked for me in the past. Good luck.
Jan 17, 2010 | Garden
WHERE IS THE FUEL PUMP ON A 1994 TOYOTA CAMRY
Fuel pump is located inside the fuel tank and is attached to the sending unit. Do not smoke or have any open flame in the work area when removing the fuel pump.
REMOVAL OF FUEL PUMP:
  1. Disconnect the negative battery cable.
  2. Relieve fuel pressure
  3. Remove the rear seat cushion.
  4. Remove the floor service hole cover .
  5. Disconnect the electrical fuel pump wiring at the fuel pump assembly. Check for any fuel leakage while in there.
  6. Remove the gas cap, this will prevent any fuel gas spilling out of any high pressure lines.
  7. Use a fare nut wrench to disconnect the outlet.
  8. Remove the pump bracket attaching screws
  9. Disconnect the return house from the pump brackets, then pull ou the pump/bracket assembly.
  10. Remove the nut and spring washing, then disconnect the wires from teh pump bracket.
  11. Remove the sending unit attaching screws then remove the unit from the bracket.
  12. Pull the lower side of the fuel pump from the bracket.
  13. Unplug the connector to the fuel pump
  14. Disconnect the hose from the pump.
  15. Separate the filter from the pump. Use a small screwdriver to remove the attaching clip.
  16. Inspect all the lines, houses and fittings for any sign of corrosion, wear and damage to the surfaces. Check the pump outlet hole and the filter for restrictions
  17. When reassembling, ALWAYS replace the sealing gasket with a new ones. "Also replace any rubber parts showing any sign of deterioration".
To install:
  1. Install the pump filter using a new clip. Install the rubber cushion under the filter
  2. Connect the outlet hose to the pump and pump bracket.
  3. Engage the connector to the fuel pump. Install the fuel sending unit to the pump bracket. The remainder of the installation is the reverse of the removal.
  4. Start the engine and check carefully for any sign of leakage around the tank and lines. Road test the vehicle for proper operation.
Dec 15, 2009 | 1994 Toyota Camry
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Primer pump rotten need replacement show parts page
The hoses run through a hole into the gas tank, they are fitted with a filter inside the tank. Drain the tank, and manipulate the hose end to where you can grab it throught he filler hole, Remove the filter, run new gas lines into the tank and through the filler hole to replace the filter, reattach to the carburator. The primer bulb should have 4 small screws attaching it to the carburator. Remove the screws, place in new primer bulb, and you should be back to trimming asap.
Jul 06, 2009 | Garden
Stihl HT101 Pole pruner Logo
104 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
