Question about Samsung Computers & Internet
Samsung NP-QX411-W02UB WON'T RECOGNIZE INTERNET CABLE PLUGGED INTO NOTEBOOK
Samsung Notebook will recognize wifi network but not broadband cable connection
  • 196 Answers
SOURCE: Connection Issues Occur When I Try to Connect Through a Broadband Network Adapter
To resolve this issue, remove the network bridge. To do so, follow these steps: 1. Click Start, and then click My Network Places. 2. In the left pane, click View Network Connections. 3. Look for any connection that is bridged. 4. Right-click the bridged connection, and then click Remove From Bridge. 5. Repeat step 4 for each connection that is connected with a bridge. 6. When the bridge is removed from each network adapter, right-click Network Bridge, and then click Delete. 7. Click OK. When the all the bridged connections and the network bridge are removed, the broadband hardware is automatically detected.
Posted on Feb 16, 2006
  • 3 Answers
SOURCE: DIR-300 router and broadband ISP connection,is NAT possible?
With a cable broadband connection, the cable line comes into the cable modem. The cable modem does the work changing the cable signal to a network connection and sends an I.P. address to the computer. With some cable internet providers you can hook the network cable into the in port on a router, wireless or wired, then hook up computers to the router. At this point the router gets the IP from cable and uses it's own IP routing for your internal network. Some broadband providers control your access by the computers mac address which registers with the vendor. If this is the case then the easy way to make it work is to get a router which can clone a mac address so the vendor still sees the same mac address.
Posted on May 29, 2009
  • 11 Answers
SOURCE: emachine notebook doesn't recognize my wireless network.
Try running the Microsoft updates or getting updated drivers for your wireless NIC. It's even possible that the wireless card in the laptop doesn't support WPA security. Unlikely seeing as how the board is fairly new, but possible. You might also want to try getting a PCMCIA wireless card and popping that in.
Posted on Jun 19, 2009
knatcal
  • 53 Answers
SOURCE: won't recognize home wifi, though it does recognize cafe wifi
To check to see if wireless is enabled, go to start, settings, network connections. That is where its at in Win XP, if thats not where it is on your computer, go to start, search, then search for network connections. In WC you should see a wireless adapter listed, it will either say enabled or disabled, if its on, disable it and reinable it. To check your router settings, you will have to open internet explorer and type in the ip address of the wireless router. Instructions on how to do this are included with the router. If you no longer have instructions, it will often list how to do it on the manufacturer website.
Posted on Sep 11, 2009
SOURCE: how do i setup my internet on the samsung nc10?
Local area connection is meant for wired LAN connection. you can connect the internet using a straight clable wire.
on how to make a straight cable,below is the link
http://www.ertyu.org/steven_nikkel/ethernetcables.html
But as you have said you can connect using wireless,then in wireless adapter setting,
Assigned your IP address Plus Subnet Mask address.
Set your wireless access point IP address as your Default Gateway Address.
In Primary DNS address as provided by your Internet service provider.specify secondary address too,it available.
If DHCP server is available then you don't need to configure anything.
If you are trying to browse internet through a proxy server than Go to internet Explorer,Click "Tools", Select "Internet options ", Select Connection, Tick Proxy server and specify the IP address of your proxy server and the port.
you will be able to browse Internet now.
Rate this answer.
Posted on Dec 27, 2009
0xc000000e windows failed to start no windows installation disc
Fixing Error 0XC000000E manually is a difficult process and it is not recommend unless you are an expert in this field. mostly all of the fixes you need a installation disk. you may have to, take it to a qualified person for this problem. unless you can get a windows installation disk. and do a complete reboot of windows 7. Good-Day!
Jul 06, 2014 | Samsung Np-qx411-w02ub Core I5-2450m...
How to reset
If you are refering to a Restore/Recovery? You can find Samsung Support info here: http://www.samsung.com/us/support/owners/product/NP-QX411-W02UB
Jan 26, 2013 | Samsung Np-qx411-w02ub 1tb Hard Drive 14"...
Who to connect wifi
SETTING UP A BROADBAND CONNECTION
First you need to decide what type of broadband and Internet service you require and these are -
1. DSL that uses your existing telephone line.
2. Cable that uses a cable service and can include a cable TV service.
3. A wireless 3G network uses the mobile/cell phone network and can be separate or combine with your cell phone account. This type of Internet connection uses an USB wireless device shaped like an USB memory stick.
Note - Combined services generally offer discount pricing and may include a modem/wireless router.
If you use a wireless router with the DSL or Cable Internet service then your laptop with a wireless card can then connect to the Internet. You can also connect to a free WiFi hot spots like McDonalds, Star Bucks, the Airport etc. using the wireless card in your laptop.
If you use the wireless 3G wireless broadband service, then you can access the Internet anywhere where your ISP has 3G wireless coverage. You need to check the service coverage area where you need Internet service.
Once you decide what type of broadband your require, then you need to check with the various Internet Service providers to see if they can offer and the cost of the various plans.
Note the download limits and the associated additional costs if you exceed the monthly download limits. Once you sign up with a Internet Service provider, their documentation will include setting up instructions and/or installation CD.
Nov 12, 2012 | IBM ThinkPad T42 Notebook
How could i setup a new windows when boot manager not work properly
You can boot and setup windows using either of the following ways:
a) If you have a boot able CD/DVD of Windows, then go to your BIOS setup and set CD/DVD as your First Boot Device and then save setting and exit. Place the CD/DVD of windows in your CD/DVD Rom and setup shall start.
b) If you don't have a boot able CD and have a backup on your hard disk or any place else, then you can create a Boot able USB easily. Follow the link below for getting a free utility and how to create a disk like it.
http://www.megaleecher.net/Make_Bootable_USB
Oct 24, 2012 | Samsung Np-qx411-w02ub Core I5-2450m...
How to set up wifi
Your Dell D610 may have a built-in wireless card, if so the install the wireless driver.
First you need to decide what type of broadband andInternet service you require and these are -
3. A wireless 3G network which uses the mobile/cell phone network and can beseparate or combine with your cell phone account
Note - Combined services generally offer discount pricing and may include amodem/wireless router.
If you use a wireless router with the DSL or Cable Internet service and yourlaptop has a wireless card then you can also connect to the Internet at WiFihot spots like McDonalds, Star Bucks, the Airport etc.
If you use the wireless 3G wireless broadband service, then you can access theInternet anywhere where your ISP has 3G wireless coverage. You need to checkthe service coverage area where you need Internet service.
Once you decide what type of broadband your require, then you need to checkwith the various Internet Service providers to see if they can offer and thecost of the various plans.
Note the download limits and the associated additional costs if you exceed themonthly download limits. Once you sign up with a Internet Service provider,their documentation will include setting up instructions and/or installationCD.http://www.fixya.com/support/r6165994-setting_up_broadband_connection
Jul 22, 2012 | Dell Latitude D610 Notebook
How to get wifi
First you need a WiFi wireless card or an USB WiFi adapter.
This will allow you to connect to a free WiFi hot spot location such as MacDonalds, Starbucks etc.
If you want to setup your own wireless network at home the you need a wireless router and then configure the wireless card/adapter in your computer with the router's wireless settings.
Jun 10, 2012 | Computers & Internet
Wifi for b130
Jun 02, 2012 | Dell Inspiron B130 Pentium M 1.7ghz...
I turned on my wireless button but I cant figure out how to connect to the WIFI
First you need to decide what type of broadbandservice you require and these are -
If you use a wireless router with the DSL or Cable Internet service and your laptophas a wireless card then you can also connect to the Internet at WiFi hot spotslike McDonalds, Star Bucks, the Airport etc.
Feb 24, 2012 | Averatec 3200 Notebook
Computers & Internet Logo
22 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
