Question about Toshiba Satellite L355D-S7813 Notebook
Toshiba RTC battery is low - Toshiba Satellite L355D-S7813 Notebook
4 Suggested Answers
  • 624 Answers
SOURCE: Toshiba 6100
Unfortunately it is a fairly involved procedure, one of the more complex I?ve seen for a newer laptop. If you don?t have prior experience, tools and some nerve I?d suggest you take it to a shop. Some of the more challenging parts you are going to remove are the keyboard, the top half of the case, the wireless card and some of the wiring harness. -Remove the battery pack, any PCMCIA cards, the optical drive and the hard drive. -Open the laptop and carefully pry the keyboard holder (thin piece of plastic at the top of the keyboard. Toshiba has a special tool for this but in times past I have been able to successfully remove other Satellite Pro series keyboards with a plastic probe. Once that is off remove the two retention screws at the top of the keyboard, carefully disconnect the cable and remove the keyboard. -With the keyboard removed you will see the wireless card torx security screw at the top just to the left of center. Remove it, the cover plate and the card underneath. In order to remove the card you will also have to disconnect the white and black coax leads. When removing and reassembling note that these connectors are really small and fragile. -Flip the laptop over and remove all 15 screws. There are three different types so mark down where they go for reassembly later. -At the rear of the computer you will find 2x screws, one to the right of the VGA connector and the other in-between the serial and lpt1 port; remove them as well. -You will have to disconnect several leads and wire harnesses in order to lift off the top half of the case. -Once the case is removed the RTC battery is in the lower right hand corner. -Now all you have to do is reassemble the laptop and test. Good luck and don?t forget to rate this post.
Posted on Apr 16, 2007
  • 461 Answers
SOURCE: change rtc battery in a toshiba satellite 2415-s205 notebook.
Thanks for the link. At this level of disassembly if you haven't seen the battery, it is not many steps to get to it.
I did notice something green toward the lower left of the base in step 19 that may be it - if not it's just a matter of removing the remaining motherboard screws and connections as it would be on the bottom of the board.
Shame the battery did not need replaced at that time.
Posted on Jan 06, 2009
SOURCE: rtc replacement
Recently while at Geek Squad at Besy Buy I asked them the same question in regards to replaceing my Satellite A55-S106 computer. He (Geek Squad) explain to me they do'nt sell the lap top batteries but you can purchase them online and you can go to Toshiba direct and I know for sure they have them availble there. I cant spell today sorry,
Posted on Feb 28, 2009
I want to update the bios on toshiba satellite a10
Go to Toshiba support website and enter your computer model no. to get new driver, there may be a Re flash of Bios available.
Oct 10, 2012 | Toshiba Satellite A10-S100...
Rtc battery is low or cmos checksum is inconsistent
The RTC battery is a rechargeable Li-ion "clock" battery that's buried underneath the keyboard - it keeps date and time going when your computer is turned off. If you're getting this message, you should go follow the screen prompt, hit F1 to enter Setup, and set the date and time, leave the computer on for several hours to charge it (the clock battery recharges only with the computer turned on) and it should go away.
In the rare event that your RTC battery is bad, it's really up to you as to getting it replaced or not - it's a lotta work, and not all the battery vendors out there is competent enough to sell you the right kind of battery (installing a non-rechargeable Lithium battery will kill the thing outright, and there are actually people selling these....). Not having a working RTC battery doesn't really interfere with the workings of the computer - you'll just have to set date and time every time you start it, and you can do so manually or by downloading some freeware such as Atomic Clock Sync to automatically do it for you.
Sep 19, 2011 | Toshiba Satellite A45-S151 Notebook
Where is the RTC-battery locted in a Toshiba SA50-543 laptop
not sure on yours, but most toshibas tuck the rtc battery somewhere near the rear ram panel or the panel that hides the modem/network card or the hard disk.
Mar 07, 2011 | Toshiba Satellite 5005-S504 Notebook
On start up my computer says rtc battery is low or cmos checksum is inconsistent. Press (f1) key to set date/time. I press f1 but nothing happens. blank screen. I can press ctrl alt del and it will restart...
Your RTC battery or CMOS battery is either dead or too low to keep the correct settings, windows will not operate correctly without the proper date and time kept. This battery has to be replaced for your system to operate. Below is the service manual that will advise you of the proper procedure to replace the battery. Once the battery is replaced, reboot the laptop, go to the BIOS screen and reset the date and time, then reboot as normal. In the case of your particular laptop, the laptop has to be disassembled down to the lower case and motherboard. The included service manual has the procedure for this.
http://tim.id.au/laptops/toshiba/satellite%201400%201405.pdf
Nov 11, 2009 | Toshiba Satellite 1410-S173 Notebook
**** RTC battery is low or CMOS checksum is inconsistent **** Press [F1] to set Date/Time
Hello
Please reset cmos to factory defaults.
Then enter the bios setup and configure it and save changes.
Apr 20, 2009 | Computers & Internet
Toshiba Portege R100 CMOS/BIOS PROBLEM at startup.
I'd look at trying to replace the BIOS battery...
Check out this guide for dis assembly instructions :
http://www.irisvista.com/tech/laptops/Toshiba_Portege_R100/remove_system_board_1.htm
Feb 22, 2009 | Toshiba Portege R100 Tablet PC
CMOS or RTC battery for this laptop : can it be replaced
Hi AshishB, Yes, Toshiba does refer to the CMOS battery in their literature as the real time clock battery. Your retailer is half right, the battery is on the motherboard but its attached via a connector and it can be replaced. Here are links to a couple of venders that sell the RTC battery for your laptop: - Http://www.sparepartswarehouse.com/Toshiba,Satellite,L15-S104,Laptop,Batteries-Backup-RTC.aspx - http://cgi.ebay.com/Toshiba-Laptop-motherboard-battery-cmos-L15-S104_W0QQitemZ170060189842QQihZ007QQcategoryZ3666QQrdZ1QQssPageNameZWD1VQQcmdZViewItem Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 18, 2007 | Toshiba Satellite L15-S104 Notebook
Toshiba Satellite L355D-S7813 Notebook Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
