Question about SonicWALL Computers & Internet
Makes beeping sound on sonicwall 100/200
3 blinking lights
3 Suggested Answers
SOURCE: HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS
I already fixed it by following your suggestion. Guess what. It worked. Thanks to you all. I really appreciate it. Have a Happy New Year.
Posted on Dec 27, 2008
ginko
  • 19396 Answers
SOURCE: engine light came on 100,200 miles vehicle seems
Hi.
There are many different faults that can result in check engine light turning on and fuel consumption higher than normal. Common fault is for example one of the O2 sensors gone bad.
The easiest way to find the cause of the problem is doing an OBDII code scanning. In US this can be done for free at the nearest Autozone, otherwise code scanning is done at the dealer place or at any local garage for a small fee.
Posted on Dec 18, 2010
My haier 6000 btu AC unit will beep when you try to turn it on and will also have all of its lights blinking on and off.
Have you checked the troubleshooting section of the owner's manual? If you do not have the original it can be downloaded from the manufacturer's website.
Jun 29, 2016 | Haier Heating & Cooling
Blinking lights router
The POWER lamp should be green, 100% of the time.
The WIRELESS lamp should blink, as it "pools" many times per second, chatting with (or looking for) wireless devices.
The INTERNET lamp should blink, whenever any wired/wireless device tries to access the Internet.
For each WIRED device, the lamp should be green, 100% of the time, whenever the device is responding (maybe even when the device is "sleeping").
Jul 15, 2014 | SonicWALL TZ100 UTM Appliance
No beep sound,orange ligth remian on does not go off dell optiplex 360
Believe it or not it is probably your Power Supply. Just because it lights makes the system lights up does not mean it is working properly. Sometimes it has enough power to make the light glow, but not enough power to make the fan in the power supply start or any other functions.
You can also try the things below to see if they work, if not replace the power supply.
When you plug in the power cord is there any lightswhatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the Memory or Video Card when you hear beep tones or blinking lights. Notice the pattern of the lights and blinks. Do you get 1 Long Blink or Beep? Maybe you get 1 Long followed by 2 Short Blinks or Beeps.
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Memory Chip might be bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Apr 22, 2012 | Dell Computers & Internet
Engine light came on 100,200 miles vehicle seems
Hi.
Dec 18, 2010 | 2003 Mazda Mazda6
My friends computer just stopped working while she was using it. The screen froze and than she shut it down. When she tried to turn it back on all that happened was that the caps lock, the scroll, and the...
There are a number of things that can cause this to happen. Try taking the battery out of the notebook, disconnect the AC adaptor (if in use) press the power button a few times. Re-install the battery, reconnect the AC (if needed), press and hold the power button for about 2 seconds. This is a hard reboot and should correct you issue. When the notebook powers up, make sure you remove any cd's in the cd-rom drive.
Good Luck,
C2Solutions
Jan 05, 2010 | HP Compaq Presario V2000 Notebook
SonicWall 5060 will not reset to factory default
hi,
there is notch on sonicwall to reset it.
Mar 07, 2009 | SonicWALL Pro 5060F Firewall
HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS.
4 beeps & 4 flashes mean problem with the power supply. For my experience, most of the time the PSU is good, it is just overloaded.
For more LED and Beep messages, check this link:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00067072/c00067072.pdf
Dec 26, 2008 | HP Compaq d530 PC Desktop
if it is a long beep then check ur ram, try cleaning ram. if not solved then there may be problem with ur ram try changing ur ram.
if it is short beep and if you have a display card installed check the display card
No picture, no sound?!?!
This could be a number of things. Your lamp could be bad or it needs to be reseated to the ballast. The lamp is trying to light and it will make the ballast flicker (that is the clicking sound) or your ballast is bad and it needs replaced (it will flicker and click too). Or your color wheel is broken and it will make a clicking sound when turning. If the color wheel is not spinning or broken it will not light the lamp. No lamp no picture.
Dec 12, 2007 | Samsung PCN5425R 54" Rear Projection...
Computers & Internet Logo
143 people viewed this question
Top SonicWALL Computers & Internet Experts
Raymond Ramirez
Raymond Ramirez
Frank Zabroski
Frank Zabroski
Steve P
Steve P
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
