Question about Samsung CLX-2160N All-In-One Printer
Same problem This seemed to start after I emptied the waste toner container. I didn't realize you were supposed to buy a new waste container. How do we fix this problem now?
    Brigadier General:
  • 4,090 Answers
I seem to recall that the waste container is viewed by some optical scan eye that is sensitive to color. Remove the waste container and wash it out to be as clean as possible and reinsert it
The closer it is to the new color -the dark stains of the toner the better
Posted on Jun 23, 2009
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
My samsung cop-365w says there is an error and I need to replace or install waste toner container - all my toners have high percentages - how can i make it work?
The sensor seems to send light through 3 small, clear "windows" on the left side of the waste container. I emptied the small amount of waste into a plastic bag for disposal and then used compressed air (outside) to blow out the remainder of the container, making sure the windows were clear. Presto! All good in the hood.
Mar 20, 2013 | Samsung Clp-365w clp-365w laser printer -...
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
When I go to print it starts beeping and telling me to check waste toner box?
The waste toner box is located on the right hand side of the printer. There is a door/cover that opens up on the right side. It is a milky white plastic container. Check to make sure it is there and installed properly and the door is fully closed. If all that is correct it my be full.
There should be a new waste toner container in the toner box (along with a toner). The toner and waste toner are normally replaced at the same time.
If you don't have a new waste toner container you can tray emptying the one that is in the printer BUT be very careful. The toner is a fine powder and can get all over if spilled. If you ever spill toner never use water or any other liquid to try and clean it, that will just turn it to a liquid ink.Brush it off your cloths and vacuum it up.
If you do try and empty the container and the machine continues to tell you it needs to be replaced it can be because there is still toner on the inside of the toner container and the sensor is seeing it there.
I hope this is helpful,
Shawn
Jan 29, 2011 | Kyocera Mita FS-3820N Laser Printer
Hi, I have kyocera km c850D. Please could you explain why machine keeps saying replace waste toner box although it is quite empty. please advise if tere are any other parts of the machine to clean or...
Are you using a new waste toner container or did you empty the one that was already in the machine?
The machine uses a sensor that looks at the container to determine if it is full of waste toner. If there is toner on the inside sides of the container were it looks for toner it will indicate that it needs to be replaced even if you have emptied the toner out.
It is a good practice to replace the waste toner container with a new one, that is the way the machine is meant to be used.
If you have correctly installed a new waste toner container and the message hasn't cleared you may have a faulty sensor.
I hope this information is helpful,
Shawn
Jan 26, 2011 | Kyocera Mita (km-c850d) All-In-One Printer
Error massage : Waste toner near full
either empty and completely clean out the waste toner container or buy a new container. they are usually included with a new OEM toner.
Aug 19, 2010 | Kyocera FS-1118 Printer
Replace waste toner tank Does it mean that the toner is already used
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Jul 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Mar 04, 2009 | Samsung CLX 3160fn All-In-One Printer
Waste toner disposal procedure
It's not recommended to empty this as it contains 4 colored toners and you would heve to ensure that the light sensor sees completely clear in the view area. Replace the bottle with type 155 waste toner bottle (about $25) from on line supplier. To do this is simply a matter of opening the right side cover and sliding the green lock lever to the unlock position. Then remove the bottle and replace. Don't forget to slide the green lock lever to the lock position and close the cover.
Nov 18, 2008 | Ricoh Aficio CL2000 Laser Printer
Emptied toner waste and now I'm supposed to do an Sp 83 or Sm 83 to clear the counter?
ok, you need to enter service program as follows Press 7 key.Press 1 key.Hold down the stop/clear key until you see "." in the upper left corner of the display. Release the clear/stop key. press the clear/stop key again. Press the lighter key. The number "5" will now flash in the display.Enter "96" using the number keys.When you have enter the code,Press Print, cut copier off then on.
May 12, 2008 | Office Equipment & Supplies
Samsung CLX-2160N All-In-One Printer Logo
165 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
