How to change the typewriter so that small caps m does not prin the Pi sign
  • 3,594 Answers
Most likely you have a bad print wheel.
DickyO
Posted on May 12, 2014
The print hammer is not moving in my typewriter
most likely cause is a worn out hammer bumper( a small rubber cap on the end of the hammer solenoid ) it is replaceable
Feb 11, 2015 | IBM Wheelwriter 6 Typewriter
Area of circle
(pi)R squared (Fixya won't let me use the sign for Pi)
Area of a circle=pi*radius^2 or pi times radius times radius
example: suppose the radius of a circle is 10 inches, then the Area of the circle would be pi times 10 times 10 or 100*pi
pi represents the circumference (distance around) of a circle / diameter and for any circle is constantly the same number which is approximately 3.14
so in my example 100*pi=100*3.14 or 314 square inches
Jul 03, 2014 | Computers & Internet
Olivetti PT 505 types the letter pi when small caps m is selected. How do you reset this
If you are using a daisy wheel it will be an International daisy wheel or,check settings to see if it is set at International settings.If it is an international daisy wheel or a PS wheel change them for a standard 10" or 12"
May 10, 2014 | Office Equipment & Supplies
The Return key does not work
Take the cap off, make a small spitball, push it down the hole that the cap goes into, if one doesn't do it try two this only a temp. repair it needs a new contact sheet.
DickyO
Mar 17, 2014 | Swintec Refurbished 8014-s Typewriter W/90...
My typwriter loose the letter printer. no words can print even do the theirs a ribbon.
It's very hard to understand your question. Try printing on a multipart form if it prints on the copies OK the problem is the ribbon, if it prins bad or not at all be sure the printwheel is properly installed.
Is the ribbon feeding and lifting?
DickyO
May 09, 2011 | Olympia Mastertype 3 Typewriter
The caps lock on my Swintec 2410 typewriter suddenly won't lock anymore. Suggestions?
I don't know if tou are talking about shift lock ir caps mode. If it is shift lock gently pry the S.L. keytop off, push down thu the small hold in the middle of the stem if that makes it work make small spitball and push it down the hole, replace the key top. if this dosen't work you need a new contact pad in the keyboard.
DickyO
Nov 09, 2010 | Swintec Office Equipment & Supplies
I cannot figure out how to type a @ on Brothers 100 typewriter. Can you help, please?
That character is normally available as a SHIFT lettr "2". If this doesn't prin and you get something else, you may be in a language mode. (int) . Check the printwheel to make sure that it matches the PITCH setting you have selected.
Dec 23, 2009 | Brother Office Equipment & Supplies
Symbols & number OVER Number Keys
The typewriter is in the keyboard ll position, hold down the code key while touching the KBll key (5)
Jun 03, 2008 | Nakajima AE-710 Typewriter
How to clear the TAB SET?
Thats the beep for the right margin. Move the right margin to the right, Lawrence
Feb 14, 2008 | Olympia Supertype 330 Typewriter
k24674
jasbo
jasbo
