Question about Whirlpool Refrigerators
Whirlpool wrf989sda e01 ice forming at top of refridgerator
Turned off ice maker and still getting buildup
  • 90 Answers
SOURCE: Broken ice maker
Make sure icemaker cycles. If it is most likely bad water valve
Posted on Jan 05, 2008
TheMobilian
  • 8220 Answers
SOURCE: Ice Maker not working
Start by cleaning the condenser with a brush and a shop vac. Then get some nickleguard ice machine cleaner and wash the units plate's down going by package directions, then retry before calling a tech. It may start working but if it does not then it may save you some money by having the unit clean before the tech gets there. Ice machines are not a DIY repair. Sowwy
Posted on Mar 01, 2009
SOURCE: Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
Posted on May 07, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 20, 2009
SOURCE: Ice dispensor
Make sure that the "flapper-door" closes about 3 seconds after the ice dispenser button is released. Mine had a habit of catching and staying OPEN. This allows warm air to enter the dispenser / freezer compartment causing your problem.
If it is stuck you have to take the dispenser apart to loosen / lubricate the flapper door cam to allow for free movement.
This is the worst ICE system I've ever seen for a variety of reasons.
Posted on Jun 22, 2009
Whirlpool refridgerator with top freezer. Water leaks and pools at bottom of refridgerator under crisper. How do I fix the leak?
Here is a Utube video that will do the trick. Might not be your model, but same gig.
https://www.youtube.com/watch?v=VHD556AQ894
Dec 22, 2014 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer on top works (lots of ice buildup), bottom (refridgerator) does not work.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 24, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer is very cold but fridge area is warm. what is up.
Sometimes the defrost drain pan stops up. Instead of the water goin outside is pools up between the compartments. This forms a slab of ice and blocks the air flow from freezer to fresh food. Of course the other thing that comes to mind is the freezer fan could have quit or stopped due to an ice buildup.
Feb 13, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a Whirlpool model # ET1CHEXVB00 refridgerator. I just (few minutes ago) replaced the ice maker valve because water was no longer getting to the icemaker. Very shortly after I plugged the...
Sounds like the fill tube at the ice maker is either out of alignment or has a crack in it.
The water supply line from the water inlet valve enters the rear of the freezer and releases the water into a large diameter fill tube. The fill tubes hangs above the fill cup which funnels the water into the ice mold. If the fill tube and fill cup are improperly aligned, water may spill out instead of going into the mold.
Nov 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
Ice maker flooded top freezer compartment
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool side by side refridgerator model GS6SHE*N*O, icemaker won't produce ice. Watter line is okay. This is only 6 months old.
make sure your ice maker is turned on and if it is a new install than it will take about 24 hours for the first bin of ice witch you will need o throw away because it is like the first snow the first ice that comes out will have the dirt and things that are in the line.filter and ice maker.
Aug 22, 2008 | Whirlpool Refrigerators
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
