Question about Casio CTK-810 61-Key Digital Keyboard DISCONTINUED
How to fix usb error? - Casio CTK-810 61-Key Digital Keyboard DISCONTINUED
How to fix a write protect usb flash drive
make and model? usualy has a switch or jumper if it has write protect
How To Fix Write Protection Errors On USB Stick
Jun 03, 2015 | Electronics - Others
Tip
How To Fix Usb Device Not Recognized in Windows
Sometimes, when you plug a USB device to your computer you may receive a Usb Device not recognized or usb port not working pop up message. If your USB device is not detected, then we will show you how you can troubleshoot usb not recognized error.
Follow Quick Steps To Resolve Usb Not Recognized Error Windows:
Press "Windows" + "R",a run window will open
In the "Open" box of the run window type "devmgmt.msc" and press "Enter"
This will open theDevice manager
Click on the arrow besides "Universal Serial Bus controllers"
Right click on each USB port and then click on "Uninstall"
Restart your computer and wait for Windows to re-installs USB controllers.
Try to connect yourUSB deviceagain.
How To Fix Usb Device Not Recognized In Windows 7 8 1
on Jan 28, 2015 | Computers & Internet
Tip
How to Fix USB Device Not Recognized Error
One of the most common errors in Windows is the USB Device NotRecognized malfunction. Thankfully, this is not in any way poses athreat to the security of your system though sometimes it may causeyour system to "hang" or experience delays. The USB Device NotRecognized error simply means that your computer cannot distinguish theUSB device that is inserted in one of the USB slots of the computer.
There are different reasons why one's system gets this error. Asidefrom the attached devices at the USB slots, it is also possible thatthere is a malfunction in the host controller hardware. Moreover, thecomputer may not support the USB 2.0 that's why this error pops up atthe screen. There are also some system configurations or hardware thatare experiencing glitches as well.
But you can try different ways to resolve this error so that youwould not have to deal with the pop up message "USB Device NotRecognized".
If there is any connected USB device, gently unplug it from theslot. It might be loose that's why the error appeared. Wait for acouple of seconds before you plug the device again. Make sure that itis secured at the port.
You can also use the Device Manager so your system can scan and lookfor the new hardware. Open the Start menu then choose Run. Typedevmgmt.msc at the box then clicks Enter. Once the Action menuappeared, choose Scan for Hardware Changes. It will allow your systemto look for newly installed devices.
But if these techniques didn't resolve the error, you can tryunplugging the USB device from the port before shutting down thecomputer. Don't open it again immediately and wait for at least twentyminutes or so. However, if you still can't seem to fix the USB DeviceNot Recognized malfunction you may need to update your driver instead.You should know the website of the manufacturer so you will check outthe latest about the driver information. It would just take a couple ofminutes before you can get the updated driver information so you canstop the error from appearing from time to time.
on Jun 30, 2010 | Computers & Internet
I purchased a desktop computer with Windows 7 and need to install a wireless USB adapter. I've purchased two wireless adapters and both came with a small CD from Realtek Semiconductor supposedly with
Download available to fix realtek usb driver errors. Recommended: To repair realtek usb driver errors, use this software package: RegCure Pro. This repair tool has been proven to identify and fix realtek usb driver errors and other Windows problems with very high efficiency.
Download Now
File Size 5.6MB Requirements Windows XP / Vista / 7 / 8 Downloads Over 500,000 Download Time Broadband: 6 sec / Dial-Up: 3 min End User License Agreement
Uninstall Instructions
Apr 17, 2014 | Realtek Semiconductor Computers & Internet
How do I fix the msi motherboard windows 7 USB error 43?
How to Fix a Code 43 Error
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
    Depending on the changes you made, some solutions might include:
  3. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a possible solution to a Code 43 error.
    Important: If a USB device is generating the Code 43 error, uninstall every deviceunder the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Properly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Sep 16, 2012 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
My CDA-9886 usb error
I just got an A-male to A-female USB extension cable to hook up to the back of my Alpine CDA-9886 headunit and connect to my 32GB USB. All of the songs are MP3 and works with my brother's headunit. But when the USB is plugged into my headunit, it says error. How can I fix this?
Dec 25, 2009 | Alpine CDA-9886 Car CD/ MP3 Player
Code error -180
Check your USB cable.  I was getting the exact same error and I found out I was using an older USB 1.0 spec cable.  When I switched to a USB 2 cable it began working fine.
Todd
Oct 27, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
Car cd player with usb port getting error 12 message
I just have this problem: the tuner is working well, but the USB and CD stopped giving sound after it was working well at first time.
I JUST PUSH THE RESET BUTTON, SITUATED NEXT TO USB AND AUX PLUG ON THE FRONT PANEL. EVERYTHING WORKS WELL NOW. PAGE 3 ON THE MANUAL
CLAUDE
Feb 24, 2008 | Car Audio & Video
Casio CTK-810 61-Key Digital Keyboard DISCONTINUED Logo
11 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
