Question about Ergoguys HS-BTV60S-BL Hip Street yak Wireless Bluetooth Car Hands-free Kit - LCD Display - Solar Charging, Caller ID, Echo Reduction, Noise Cancellation, Redial, Voice Dial, Call Switching - Blue 628905009418
My pc & laptop are asking for a pairing code for my headset ,ididnt get a code with them
B-370 bluetooth headset
How do you pair bluetooth wireless headset to a 2016 UHD series 6 Samsung TV?
Tip & How-To about Miscellaneous
Pairing Bluetooth Devices Posters often ask "How do I pair my Bluetooth ???" Insert whatever device you have at the question marks.
Generally, you need to read the instructions for the camera, headset, speakers or whatever the Bluetooth device is.
Roughly speaking though.
Settings - Bluetooth - Search, on the Android, iPhone, Windows phone, Smart Television, whatever.
With camera, speaker, headphones or whatever the Bluetooth device is, you have to press a button on that device to send out the signal. On my Bowers and Wilkins T6 Speakers, there is a button on the top with the Bluetooth symbol on it. This is the part people usually don't do and ask for advice, thinking it will do this automatically.
When the Android device recognises it, click Pair, and if it asks for a code, the Default is '0000', (four zeros, no quotes).
Posted by Andrew... on Nov 19, 2016
Jan 09, 2017 | Samsung Radio Communications
Pairing code for dell wireless 370 bluetooth mini-card
Normally when pairing with any device, any pairing code can be applied (4 digits),and then when asked on the other system, the one applied on the first system, will be required to put in. In most of the cases, it is pre defined as 0000
Jul 06, 2012 | Computers & Internet
What's the access code to activate bluetooth on laptop hp6530b?
If it asks for a code for the bluetooth it is the device pairing code, so if its a phone or something similar you enter the code on it and then on the PC.If its a headset or similar, the manual will tell you the pairing code for the item.
May 17, 2011 | Computers & Internet
Is there a driver that i can download to make the h390 work with my pc? i want to use it as a microphone. i just installed the dell truemobile 355 bluetooth+EDR in my laptop.
Push your power button on the headset toward the microphone. The light should be solid blue for pairing mode. On your laptop open up your bluetooth control center (if you're not sure where it is, give us your exact model of pc and your version of windows.
The first time you pair the headset, it might ask you for the security code. It is supposed to be 0000, but try 1234 if that doesn't work (or what ever you made it if it was changed).
Once it successfully pairs you should be able to use it like a microphone.
Please leave feedback if you found this helpful. Thanks.
Mar 25, 2011 | Motorola Mobility H390 Bluetooth Headset
Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
Is h350 compatible with windows vista? i try installing one, i easily paired it with my compaq laptop windows vista os without asking any passkey. the problem is it would'nt work. i downloaded a bluetooth...
I've successfully paired this headset with Vista but only for Skype. In Control Panel set the Bluetooth discovery and it should pair OK but then you need to run Skype which will find the headset and ask if you want to use it. The solution is a bit temperamental because the microphone volume is usually either low or there is too much background noise.
Feb 01, 2011 | Motorola Mobility H350 Wireless Headset
I am trying to pair my I phone to a motorola T215 bluetooth device,I do not have the instructions, therefore I do not know where the pin number is located on the device. Please hel Rendella
Bluetooth headsets have their passkey (or PIN or pairing code) hardcoded by their manufacturers. The most commonly chosen codes by them is '0000' (four zeros), which happens to be your case. Anyway, feel free to download your headset's Quick Start Guide from this location, where you will find more detailed informations about the pairing process.
Hope you are able to sort your problems out soon.
Regards, Carlos
Aug 18, 2010 | Motorola Mobility Bluetooth Hands Free...
Bluetooth Pairing
the pin code reuired is the one set up by your bluetooth headset manufacturer. Check your user manual for the headset for the correct code to use.
Nov 11, 2007 | Motorola Mobility RAZR V3
My bluetooth headset Motorola HT280
Have you paired it with the Pocket PC yet? If you haven't.. press and hold the left-side M emblem for about 3 seconds until it starts blinking. This will put it in pairing mode. I'm not sure how to work Bluetooth on the Pocket PC, but wherever Bluetooth settings are, you need to turn on 'Find me' or something similar to that. Allow them to find each other, and they will ask for your approval, and then automatically pair. Hope that helps, goldfinger
Jun 19, 2007 | Motorola Mobility HT820 Wireless / Cable...
Ergoguys HS-BTV60S-BL Hip Street yak Wireless Bluetooth Car Hands-free Kit - LCD Display - Solar Charging, Caller ID, Echo Reduction, Noise Cancellation, Redial, Voice Dial, Call Switching - Blue 628905009418 Logo
79 people viewed this question
Top Ergoguys Electronics - Others Experts
Are you an Ergoguys Electronics - Other Expert? Answer questions, earn points and help others
