Question about Traulsen Commercial 2 Door Cooler / Refrigerator
Does anyone know how much energy the traulsen urs48dt should be using per day/month or year? Note that the compressors in my case have moved to the garage which I assume impacted efficiency. I love the traulsen, but it seems like it is using way too much energy now to sustain it.
  • 1 more comment
  • joy_lohrke Jun 23, 2009
    hi thanks. they were originally factory mounted on top of the cabinet but when the tech moved them to the garage, he had to replace each with 3/4 compressors.
    richard - I am sure you are right about both items - oversized compressors and replacement of cap tubes with TX valve ..... ill need to check it out and see what to do next. thanks again for your help. joy
  • Richard Johnson PE
    Richard Johnson PE May 11, 2010
    Was your traulsen factory configured for remote condensers or were they factory mounted on the top of the cabnut?
    Scholar:
  • 91 Answers
Ok, next question, when he replaced the compressors, did he modify the evap sections with TX Valves and remove the cap tubes? Per Traulsen specs, all remote units are factory set with TX valves while local units are equipped with cap tubes. If this modification was not done, it may be your cause of excessive electical consumption. Then again, re-reading your recent post, the compressors were changed to 3/4 hp? From Traulsen specs your unit came with a 1/6 fridge compressor and a 1/3 freezer compressor, is that correct? Electrical consumption on these are URS48DT 11.2 Amps 1/6 HP & 1/3 HP (1288 watts) at full load, while a 3/4 compressor is 14.9 amps 3/4 HP (1713.5 Watts) at full load X2 = 3527 Watts, or about 3 times original. I may be off target, but from what I can assume, I am beginning to think your compressors are over sized, drastrically and that the evap units may not have been modified to TX Valve. Let me know if this helps or if there is any additional information you can provide. Current compressor model numbers, previous compressor model numbers, complete unit model/serial number would all be a help in determining your exact specifications.
Thanks
Richard
Posted on Jun 23, 2009
    Richard Johnson PE Jun 23, 2009
    Any other questions, you can reach me here or via my company at www.emshvac.com or if there is any other issues you need help with.
    Thanks
    Richard
What does a feezer comp cost for a traulsen freezer model URS48DT
Fixya does not sell Traulsen freezer compartments.
May 04, 2018 | Traulsen Freezers
Have a Whirlpool gold conquest 26ft, i want to know if has it good energysave system?
It uses between 505-683 kwhr per year according to the Whirlpool site. That's around $500 mark at 0.30 cents per kwhr for a year.
http://www.whirlpool.com/digitalassets/GI6FARXXY/Energy%20Guide_EN.pdf
Aug 16, 2014 | Refrigerators
How much power does a
Since 2011 the FTC has required that every TV display a yellow and black Energy Guide label estimating how much it costs to run for a year. The label assumes a price for electricity (11 cents/kWh) and a baseline usage (5 hours per day).
The cost is tiny. A typical label can read anywhere from $6 for 32-inch LEDs to $38 for 65-inch plasmas (PDF). Per year. That's from 50 cents to $3.18 per month.
Aug 15, 2014 | Televison & Video
I have a 1995 24.5 cu. ft. GE Profile refrigerator. When it shuts off there is a loud clunk. I think it could be the compressor turning off. Other than that it seems to be working fine. Is this a serious...
The compressor is sitting on springs inside a metal case. When it stops, the centrifical force is absorbed by these springs. If one or more springs become weak or break, the compressor hits against the outer case a time or two. (CLUNK CLUNK clunk) There is really nothing you can do about it, short of replacing the compressor. (read big bucks) NOTE: If you take a new compressor and give it a shake, you will hear the same clunk. If the noise is really bothering you, I'd say after 15 years, it's time to move that refrig to the basement and get a new energy star model for your kitchen. (the old one most likely has several more years worth of clunking before it truely dies)
Sep 25, 2010 | GE Refrigerators
6) If two lights of capacity 80W replaced by 20W, which run for 6 hours per day. What will be energy savings per month (30 days) in KW/hr?
For the 80W bulbs you'll be using 2 x 80 x 6 x 30 = 28800 W/hr = 28.8kW/hr.
For the 20W bulbs, it's 2 x 40 x 6 x 30 = 7200 W/hr =7.2 kW/hr.
The monthly saving is 21.6 kW/hrs, a saving of 75%.
Sep 04, 2010 | Office Equipment & Supplies
I have a Traulsen Refrigerator Freezer in a home installation with a separate comressor skid installed in the garage. I am havinf difficulty with the frezer compressor. Should I repair the freexer...
at the end of the day its all down to costs
first ask yourself how old is this compressor?
how much to fix it and re-gass it?
if you pay to fix it, how much life is left in the old girl?
how much for a new compressor?
now,,,how much life will be in that one???? years!
not a hard choice,,but all down to costs!
Jun 05, 2010 | Traulsen UR48DT-6 Refrigerator/Freezer -...
My refrigerator is about 15 years old and has made a clunking noise when it shuts off since I moved into my home many years ago, but has always kept food cold/frozen. Recently, the clunk noise is getting a...
Oct 12, 2009 | Refrigerators
Leak to under ice cube tray causing drawer to freeze shut.
May be your freezer evaporator drain hole is frozen. If this is the case, you can try to install a low heat drain hole heater into the drain hole and connect the wires with the defrost heater.
Jul 04, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
Traulsen 30 x 80 two door refridge- runs loud
this is bad. you have one of 2 things going on if the noise is a rattleing in the compressor that is like viborating it,s probably a broken or unhooked support spring no fix could be also the oil left when it was on its side fi thats the case its still in the system run it and hope it comes back befor the compressor sets up one last thing did you check to see if its just a fan blade hitting somethig? dan
Jul 16, 2008 | Traulsen Refrigerators
Traulsen freezer URS48DT
Turn cold control to Max. This keeps your compressor running for this troubleshooting exercise. Find and manually advance the defrost timer with a screwdriver or something similar. This will shut the compressor down and bring the defrost heater on. If this happens then you will know that your timer is bad.
If it is not that, the next thing to look at is the defrost heater itself or the thermal overload on your defrost heater. This keeps your defroster from overheating.
Jan 20, 2008 | Traulsen 7 cu. ft. / 198 liter Commercial...
Refrigerators Logo
371 people viewed this question
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
