Question about Moen Villeta Chrome Faucet W/ Valve & Drain L4720
How does handle come off Moen 4720 faucet?
Can't see a set screw and am not sure how to get to the cartridge?
  • 360 Answers
SOURCE: Moen Castleby T6988 Roman Tub Faucet
with screw removed (the missing one), handle should lift straight up. may need to rock the handle while lifting.
Posted on Feb 12, 2009
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
  • 19 Answers
SOURCE: how to remove the handle of a monticello 4551 moen
grab bottom of handle,(the fat part of handle closes to faucet body) and grip hard and turn counter clockwise to get to cartridge. dont use channel locks pliers or you risk damage to finish. can be done by hand and very tight grip
Posted on Jul 07, 2009
motor1258
  • 6674 Answers
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Posted on Dec 29, 2009
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
I have a Moen Ascent kitchen faucet. The chrome handle that is attached somehow to the control valve underneath has come loose. How is the handle attached to the valve and what is the remedy?
Moen kitchen faucet handles in this series are held onto the cartridge stem with a set screw. First turn off the water supply to the faucet. You need to move the handle until you can see the small plug button that covers the set screw. This is ~3/4" from the edge of the handle. Remove the plug with a small screwdriver or other levering tool and adjust the handle if needed to get it on the cartridge stem. Then find the appropriate Allen wrench to tighten the screw. (It may be a 3/32" but this isn't always true.) To test if you have it tight, turn on the water and see if the water is easy to turn on and off. Turn off the water and replace the plug button. Then turn the water one last time.
To see a parts diagram for a couple of models of Ascent faucets, see https://www.moen.com/support/Ascent/Ascent_Chrome_onehandle_high_arc_pulldown_kitchen_faucet/S71708 or https://www.moen.com/support/Ascent/Ascent_Classic_stainless_onehandle_high_arc_pullout_kitchen_faucet/S71709CSL .
I hope this helps.
(Do not over-tighten the set screw. This could damage the cartridge or handle.)
Mar 04, 2017 | Moen Plumbing
Leaky faucet
This is generally due to a loose or faulty cartridge. To fix:
1. Turn off water supply valves under sink.
2. Block the sink drain to avoid losing small parts.
3. Remove faucet handle. It is attached by a set screw, an odd size (I actually used a T9 torx screwdriver successfully, even though the set screw is hex head, since I did not have a matching allen key). The set screw is quite far into the handle, ~3cm, through a hole in the bottom of the handle. Depending on your countertop layout, you may have to actually remove the entire faucet from the countertop in order to get access to it, in which case follow the appropriate parts of your faucet installation directions in reverse.
4. Remove dome. It will come off with a gentle turn/pull.
5. Check the tightness of the exposed large hex nut. This is the piece that holds the cartridge in place. If you are lucky, it is just loose, and that's your problem; otherwise you will need a new cartridge.
6. Unscrew that nut, remove. Pull out the cartridge.
7. Replacement cartridges may be found at your local Moen dealer, or may be ordered directly from Moen +1-800-Buy-Moen. Parts are free due to the lifetime warranty. Part #1255 includes the cartridge, cartridge nut, and set screw. The nut must be changed with the cartridge (presumably due to its wear characteristics).
To reassemble:
8. If you have it, place a very small amount of plumber's silicone lubricant on the back of the cartridge, on the rubber seals around the three holes.
9. Assemble in reverse order of disassembly. The cartridge only goes in one way, due to three guiding channels on its perimeter.
Enjoy!
Oct 08, 2012 | Moen 87877SRS Haysfield Spot Resist One -...
Need to change washer faucet
Probably what you need to do is change the cartridge. You will need a Moen cartridge puller to help with removal and reinstallation. You can get these and the cartridges at most hardware stores. Shut Off Water first, remove set screw that secures handle and carefully remove handle. You may have to tap lightly on rim of handle to free it. There is a retaining clip that holds cartridge in place, it will have a small round hole on top. Carefully remove clip using neddle nose pliers or perhaps ice pick inserted in hole to remove clip.Install puller as per instructions and tighten nut to remove cartridge. Install new cartridge andclip. put handle back on and install screw. I need to back up here and say that screw is normally located under moen insignia in middle of handle. Pry cover off with screw driver or knife blade to access screw. After you have cartridge, retaing clip and handle reinstalled turn water back on and check for leaks. Hope this helps. Thanks.
Nov 11, 2010 | Moen Bathroom Sink Faucet - Single Handle...
Re: Moen single-lever kitchen faucet like the 7100. When I replace the lever, it only goes up. I can't get it to go down. I'm pretty sure the cartridge is in right, with the U-clip and the other screw-on...
The water supply should have no bearing on the working motion of the faucet cartridge or handle. On both models of Moen faucet, the handle needs to be hooked under the cartridge's top cam bearing. It is a bit tricky sometimes. Here's the parts view for 7300 and 7310 Moen Kitchen faucet. Parts view for 7100 Moen.
If you need further assistance please let us know.
Sep 16, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Water temp. regulate
Moen faucets have only one moving part. The stem slides up and down to open and close the faucet and rotates to regulate the flow of hot and cold water. Any leaking requires replacement of the cartridge.
First, turn off the water. To remove the cartridge, you'll need to remove the handle. This project can be like working a puzzle. If you have the manufacturer's instruction sheet for the faucet, you're ahead of the game. Without it, look for a retainer clip at the rear of the faucet just below the handle. Or, you may have to remove a set screw or snap-in "hot-cold" button and a handle pin or screw. On some faucets the swing spout must come off first. The retainer clip may be hiding beneath the handle inside a lift-out tube. Some cartridge faucets use two retainer clips–one by the handle and another by the cartridge. Retainer clips can be pried out with a screwdriver.
Once the retainer clip is removed, the cartridge simply pulls out. Use pliers, as shown in Fig. 6. Install the new cartridge by pushing it into place with the flat arrow, or other mark upward. If you use a lubricant on the cartridge, make sure it's silicone grease.
Check and clean the cartridge inlet ports. Before you button up the faucet turn the water back on for a minute to flush out the supplies. I had to look for this answer, hopefully this will work for you.
Jul 21, 2010 | Moen & One Handle Tub & Shower Faucet
Moen single handle kitchen faucet, Hot water and
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
How to remove the handle of a monticello 4551 moen faucet. I need to access the cartridge. After screwing the brass stem out, does the chrome ell shaped cap rotate to unscrew or is there a set screw I...
Jun 23, 2009 | Moen 4551___ Monticello Popular Two Handle...
Apr 05, 2009 | Moen Plumbing
Moen Villeta Chrome Faucet W/ Valve & Drain L4720 Logo
411 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
