Question about Canon PIXMA MX922 Inkjet Multifunction Printer - Color - Photo/Di
Brand new trying to set up error code 2800 won't go away
I take the paper supply unit out and reinsert both parts. It fits but error code won't clear and I can go no further with set up. Help!
3 Suggested Answers
glporter
SOURCE: I replaced the clear ink tank on mx7600 and the
Yeah, me too. I fiddled with cycling the power, removing and reinserting the tank, doing maintenance tasks like cleaning the jets, yadda, yadda, no dice. New full Canon tank displays empty. Boo.
I figured "What the heck, I'll try printing anyway" and sent a test page on plain paper. It warned me the tank was empty, then did a bunch of those cartridge moves it likes to do (you hear the carriage moving around cleaning or something). After like 90? seconds of cleaning noises, it figured out that the tank was full, the status went to full, and it printed the page fine.
So my advice is, try printing a page anyway.
Posted on Dec 18, 2010
SOURCE: no paper jam but error 5110 won't go away
Have you tried unplugging the machine, this might reset it.
Posted on Mar 14, 2013
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
I replaced the clear ink tank on mx7600 and the message "the clear ink is empty" will not go away nor will it print in black. The brand new Canon brand clear ink can be seen on the ink tank itself and in...
Oct 20, 2010 | Canon PIXMA MX7600 Multifunction inkjet
Error 2200
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO.
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off the AIO and remove the power supply from the back of the unit.
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Feb 06, 2010 | Lexmark P6350 All-In-One InkJet Printer
Error code E000002-0000
Get in the service mode *28* and there under function, clear, err.
If not replace the fixing film unit
Jan 02, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Hp laserjet P4515n printer
you'll probably need a replacement paper tray.The sliders are fitted with small teeth to prevent them from moving.These teeth can break off meaning the paper size slider moves around too much and the paper sits back away from the feed roller and it doesn't get picked up correctly by the fed roller so resulting in a paper jam error
Oct 12, 2009 | HP Office Equipment & Supplies
Lanier 5235 sc900-01
Hello sir; You may try to reset the machine follow the steps; Press "clear mode" "107" and hold down "clear/stop" key for 3 seconds, turn power off and back on .
Sep 19, 2009 | Ricoh Aficio 1035 Copier
Ricoh MP 2510
Fuser installation error. Fusing unit set error. Remove the fusing unit out of the machine and reinsert it. It isn't seated in there properly. Once you do that the error code will go away.
Sep 15, 2008 | Ricoh FT5832 Copier
Canon imageRunner 105
Hello PE. I will tell you what the code means and although we can reset the code, if the PROBLEM still exists I am afraid the code will of course return when the copier performs a diagnostic. By telling you the reason for the failure perhaps you can fix the problem and therefore MR. COPIER wont be pissed. :-) This code means that the paper supply referred to as tray "B" has a problem.The lift motor for that paper supply could not (or the copier believes it could not) successfully lift the paper to the correct paper heighth required to feed the paper. This explanation may help you correct the problem.Now to clear the code. On the operator control panel next to the nine key pad is a button that says "additional functions". That button will be part of a 3 step process. Press the the additional function button>>>> next press the numbers 2 and 8 together at the same time>>>> then back to additional functions button.This is a 1,2,3 process that should be executed in a smooth but timely fashion. This will bring up a new window on the screen. Ther will be several "blocks" on the screen and one will say COPIER. Press copier.Then a new screen appears with several tabs across the top. One of those tabs will say FUNCTION. Press function.The screen will be filled with an assortment of blocks and one will say CLEAR. Press clear, and a new set of blocks will appear.One of the new set will say ERR. Press err and then in the lower right hand corner you will say a block saying "OK". Press ok. Now unplug the machine and wait a few seconds and plug it back in.You WILL have successfully erased the error code and the machine will perform its power on diagnostic as if nothing was ever wrong. However if the problem still exists the copier will see it and the code will return. If it does, you can perform the process again but this time pull tray "B" out so the copier cannot run a diagnostic on it. This is merely a workaround and will allow you to use the copier and its remaining paper supplies. As to what specifically the problem with paper tray "B" is could be several things, all of which would require a tech to come out. I must assume that is what you are trying to avoid (as would I ....$$$$$) I hope this helps you and I wish you the best. SPINAL
Jan 18, 2008 | Canon imageRUNNER 8500 Copier
Toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Nov 06, 2007 | Canon imageRUNNER 400S Copier
Canon PIXMA MX922 Inkjet Multifunction Printer - Color - Photo/Di Logo
63 people viewed this question
old marine
old marine
