Question about RCA L32HD32D 32 in. LCD HDTV
Rca serial #1445-42LA45R-B105890 back light
Tv turns on but no picture. can change channels and has sound. when I shine a flash light on the sceen I can see the picture.
SOURCE: When I turn on my tv, I get a black screen that says unusable signal. I change the channel, same thing. I try to use the DVD player or another add on and it is still black. My TV is an RCA 37in flat s
Thank you ryolkowski!!!! We just tried your solution and MAN it worked like a damn. We were all ready to make a trip to the city to get a new tv, an expense we just didn't need right now. You made our day. I can't thank you enough. jabo
Posted on Aug 02, 2009
  • 308 Answers
SOURCE: RCA L32WD22 with no picture.
The backlight has failed. May be the power supply for it, the inverter board or the lamps. Not something you can fix unless you are a tech.
Posted on Mar 10, 2010
eagle338
  • 4889 Answers
SOURCE: I have a rca model
The tv is entering what is known as a protect mode. This happens due to failure or the components that control the amount of voltage entering a particular circuit. EX; Resistors, Voltage Regulators etc.,
The location is most likely to be the power supply board. How good are your electronics soldering skills? I would not want someone with out prior experience in working on electronic circuits to attempt it and hurt themselves.
Posted on Nov 08, 2010
  • 608 Answers
SOURCE: Picture & sound shuts off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
  • 905 Answers
SOURCE: I have a 2 yr
Your backlight controller is probably faulty. Check for bad capacitors. It may be one or more inverter transformers which is faulty, inwhich case it is usually easier to replace the whole backlight
controller board.
Posted on Mar 16, 2011
My 46 RCA flat screen has standby light but goes out when tv is turned on and I have no picture or sound so I replaced power supply board and no change any advice would be great
If the image is present on the screen when a flashlight is shined from the back then the problem may be the Timing control board.
Feb 03, 2017 | RCA Televison & Video
When I turned on my vizio vo37om this morning, there was no picyture, screen is black. Sound is fine
Dim the lights in the room, turn on the set. Shine a bright flashlight on the screen, do you see a faint picture?
Feb 11, 2013 | Vizio VO370M LCD TV
TV Flashing from Channel to Channel Non-Stop. Problem with the RCA F32689 32" TV My TV started jumping from channel to channel non-stop. There's no picture or sound - only channel numbers changing...
If still under guarantee take it back.
If not this sounds like a workshop job. If more than five years old (the TV, not you!) and you can afford it, junk this set and get a new one.
Sep 21, 2011 | RCA F32689 32" TV
"32" rca tv about 3 years old was on & it went black- power light is on"
sounds like the sceen is dead, if you are receiving nothing on screen, then it sounds like either a component and/or screen is gone... however, check the tv input to make sure it wasnt acidentally switched to an input channel with nothing selected... if that does not work, call local tv repair or mfg customer service tech. if under warranty, have repaired or replaced. without physically seeing tv, it is hard to diagnose issue outside of information given. could be simple board replacement or could be screen.. but check input first, if a dvd player plays, then it could be just component or input on wrong selection
Oct 17, 2010 | RCA 32V550T 32" TV
I have sound and no picture
You do not state your TV is plasma/LCD or the older tube TV.
Anyway, if your TV is plasma, the problem comes from Y-board.
If it is LCD, use flash light shines to the screen you will see pictures moving there. This case the invertor fail.
The old one have many components involved. It is hard to tell without details.
Aug 13, 2009 | Televison & Video
Picture flashes off but still have sound
You may want to change the lamp. It may be on the edge of failing totally.
Hope this helps,
Skyassoc
Jun 28, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Picture wont come on
No reset button, you may have a bad lamp. Look in you owners manual and which light is flashing it will tell you if the lamp is a possibility.
Mar 01, 2009 | RCA P52926 52" Rear Projection Television
My Sharp LCD 26" TV shows most black and shadow colours as vivid blue, I have tried resetting the colour to factory reset but that didn't seem to help at all. It occurs on all channels and on 3...
the problem with LCD tvs are that they have back lamps that shine thru the LCD sceen. the job of the screen is to block the light of the different colors to make the picture. the problem is that the very thin screen can not block all the light. if the set has a back lamp setting turn down the back lamps and adjust the brightness control it should help a little. you my notice that the blacks and dark sceens look better when the room is fully lit and look much worse in a darken room.
May 27, 2008 | Sharp Televison & Video
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
RCA P46922 No picture, good sound
This is due to the screen will not get the exact grid voltage. Without getting the proper screen voltage black current section will not allow to flash the channel continuously. This can be solved by adjusting the exact G2 voltage. More the deflection area is free from dust and moisture to avoid the same problem infuture.
Sep 14, 2007 | RCA P46922 TV
RCA L32HD32D 32 in. LCD HDTV Logo
37 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
