Question about Mcculloch 16" Electric Chain Saw Mcc3516f
No oil to bar everything is clean tried cleaning tank with gasoline rinse where could the obstruction be
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
Oiler ! Have you taken it apart to see, if working ? Maybe you need a new one .
Posted on Jul 03, 2016
How to fix bar oiler
try cleaning the bar and all the oil gallaries in the bar and chainsaw body. Rinse the oil tank with varsol to clean dirt fron the oil intake strainer, reassemble and test. to test the oil pump leave the side cove, bar and chain off, start the saw and see if oil sqirts out when you rev the motor
Sep 29, 2015 | Echo PPT-265ES Pole Pruner
Not getting oil on chain
Try cleaning the bar and all the oil gallaries in the bar and chainsaw body. Rinse the oil tank with varsol to clean dirt fron the oil intake strainer, reassemble and test. to test the oil pump leave the side cove, bar and chain off, start the saw and see if oil sqirts out when you rev the motor
Sep 21, 2015 | Garden
Chain oil is not flowing through to lube the chain
Remove the side case on the chain clutch, remove the bar and chain, clean then oil ports thoroughly, clean the chain bar completely. Empty the chain oil tank and flush it with gasoline, there's a filter in the tank the gas will clean it, put it all back together and it should work fine. I've used Stihl for 25 years and never had any other problems with the chanin oil system.
Aug 20, 2014 | Stihl Garden
Chain saw will not pump oil to chain and bar.
Try the easy fixes first, remove the guide bar and chain, clean out the bar groove and delivery hole, clean any debris away from the bar pad on the machine, drain the oil tank, re fill with a suitable cleaning fluid, rinse the tank out well to release any dirt in the tank, now try again.
Jun 21, 2011 | Poulan Pro Chain Saw 46cc 20"
Poulan PRO chainsaw -- oil is not getting to bar...what could be the problem?
You need to remove the bar and chain, clean out all the oil delivery holes in the bar, if no better drain the oil tank, fill with a suitable cleaning fluid and rinse out the tank, this will help to clean any dirt from the pick up filter, now try again, if still no better, you will have to remove the clutch and sprocket to gain acess to the oil pump itself
Apr 20, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Oiler not oiling
If you have not already done so remove the bar and clean out the the oil delivery hole, drain the oil tank, fill with a suitable cleaning fluid and rinse the tank out, this may clean any blockage in the tank filter, if still no better you will have to remove the oil pump, clean and check the worm gear, the pump is normally behind the clutch and sprocket, this will mean removing these components to gain acess to the pump,
Apr 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No oil to bar
Drain the oil tank, now will witha suitable cleaning fluid, rinse the tank out several times, this will help to remove any dirt in the oil filter screen, remove the bar and chain, clean out the bar rail and oil feed, now try again.
Mar 05, 2011 | Poulan 14" Chainsaw
Can't get oil to chain saw bar, tried blowing out where the oil comes onto the bar.
There may well be a blockage in the oil filter in the tank, drain the chain oil out, now fill the tank with a suitable cleaning fluid, rinse the tank out three or four times, this will help be clean any dirt build up in the tank, if this does not help the problem may well be with the pump itself, to acsess this you will have to remove the clutch and sprocket, the pump will be situated behind these components.
Feb 11, 2011 | McCulloch Garden
Saw revs but chain runs slower then rev of motor then motor stalls out?
This is possibly because the mahine is not oiling the bar and chain, the chain is probably seizing in the bar rails, try removing the bar and cleaning the bar groove and delivery hole,if this does not help you need to go deeper into the oil pump and pump drive system, or oil delivery pipe and filter in the tank, try rinsing the oil tank out with a suitable cleaning fluid and try again.
Feb 05, 2011 | Poulan Garden
The oiler will not work i took the bar and chain off cleaned everything but it will not oil the chain
Most machined will have an oil filter in the tank, drain the chain oil out and fill the oil tank with a suitable cleaning fluid, rinse the tank out a few times, this will help to clean the filter if it is blocked.
Feb 04, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Mcculloch 16" Electric Chain Saw Mcc3516f Logo
48 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
