Question about Balboa Instruments Duplex Digital Panel 2 Pump
I have an f6 code on my vl460u balboa screen - Balboa Instruments Duplex Digital Panel 2 Pump
My Spa has a Balboa 500z Top side and control panel. It was running at 104 degrees and then one day it just shut down. The Circ pump won't start up at all and when I first turn on the power, I hear the...
Turn breaker power off. Verify now power to unit with volt meter. Most systems have in line over temp over current to protect circuit board and motor. Also the water level switch must be made to complete interlock condition. Check the heater coil for continuityas it may have opened. Check heater for continuity to each coil set. There is an interlock that is for diagnostics on start up that will prevent unit from starting. Look for any melted wires or components too. Always know and verify breaker settings. Verify your meter with known voltage reading first. Be safe my friend.
Jun 04, 2017 | Balboa Instruments Pool & Spa
Vasco de balboa
This is not anything to do with cars and trucks. Just check below.
· NAME: Vasco Nunez de Balboa
· OCCUPATION: Explorer
· BIRTH DATE: 1475
· DEATH DATE: January 12, 1519
· PLACE OF BIRTH: Jerez de los Caballeros, Extremadura, Castile, Spain
· PLACE OF DEATH: Acla, near Darien, Panama
· FULL NAME: Vasco Nunez de Balboa
· AKA: Vasco Balboa
· AKA: Balboa
BEST KNOWN FOR
Explorer and conquistador Vasco Nunez de Balboa became the first European to see the Pacific Ocean.
Dec 10, 2013 | Cars & Trucks
Error codes
Here is a link showing the most common error codes for hot tubs using Balboa Instrument spa packs.
Balboa Direct Factory Direct Balboa Water Group Bath and Spa...
Rod
US Parts Center
Nov 16, 2013 | Qca Spas Majestic Series Aruba Xl Hot Tub
Whirlpool 6 sense f6
Normally the F6 code means a shorting cook relay. That can be repaired for $39.95 in most cases.
But it would be best if we knew your full model number from the cooking cavity or elsewhere on the oven.
Jun 09, 2013 | Microwave Ovens
Error code "OHH" displayed when
OHH code means "Overheat" condition
The spa has shut down -one of the sensors has detected 118 ° at the heater. Check it and replace it if go to bad.
Hope helps.
May 25, 2011 | Balboa Instruments Duplex Digital Panel 2...
Im getting a f6 code on my digital control topside pack. what is this and how can i fix it
F6 typically doesnt indicate an error. This is usually a programming code that tells you spa to filter every 12 hours.
If it is a FLo code that just looks like an F6, then you need to either replace the filter, replace the flow switch , or make sure the pump is pushing enough water.
Mar 18, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
When I put power to my unit. A Sn code appears. Great Lakes spa 1996 260E balboa wiring
If the SnS or Sn Message is Alternating with the Water Temperature on the Display, it is a Possible Sensors Out of Sync Message.
If the SnS or Sn Message is Blinking or Flashing OFF and ON without showing Water Temperature, it is a Verified Sensors Out of Sync Message.
http://service.balboa-instruments.com/ErrorCode/ for code info
Dec 06, 2009 | Balboa Instruments Garden
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Balboa Instruments Duplex Digital Panel 2 Pump Logo
43 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Mister Danger
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
