Question about Dometic Heating & Cooling
Cycling on and off, run 45 sec stop for 20 sec
    Genius:
  • Dometic Master
  • 1,363 Answers
If it just the compressor going off and on its a safety. change capacitors
Posted on Aug 17, 2015
Speed Queen Model RWM274W-3062 top loader.Stops spin cycle after about 20 sec.When i open and close door it spins again for about 20 sec then stops. What could be the problem, thanks
Washing machines kick off when they're out of balance, like if something is too heavy and waterlogged on one side. Redistribute the laundry and it will be fine.
Mar 09, 2016 | Speed Queen Washing Machines
Infocus LP790HB Overhead Projector
first thing to do is replace lamp .When a lamp has some hours on it .It will act just as you mentioned (cycles) .Also make sure fans are running and not clogged and or crusted with dust.If fans are full of dust ,fan spins slower ,causing a shutdown...
Dec 06, 2007 | InFocus LP 735 Multimedia Projector
My maytag quite series 100 _ fills with water starts running cycle but stops after about 20 sec _ it does this 3 times then shuts completely off
Sounds like the timer could be a issue . or motor running to hot clean all under and behind make sure no dust ..UNPLUG UNIT FIRST ,....
Sep 28, 2015 | Maytag Washing Machines
The oven turns its self ON every 20 to 45 mins. The electric ignition glows and the gas comes on and burns for about 30 to 60 secs then turns off. The oven control knob is turned OFF. There are no aut
Seems to me you have a defective control panel board.. Ovens should never do this. Time for the Serviceman right away, this could be dangerous if you are not home.
Nov 24, 2014 | GE Kitchen Ranges
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
Apr 23, 2014 | Vitapur Energy Star Bottom Load Water...
My MLE2000 washer will start to spin and then
more likely an itntermitent lid switch problem as the washer strats it's spin cycle the motion is causuning the lid switch to open making the washer think some one has opened the lid and it shuts down to be safe check the switch make sure it hasn't come loose and check the actuator on the lid sometimes a plastic piece near the front of the lid that goes into sort of a key hole Good Luck
Oct 16, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Maytag neptune top loading washer with spin problem. spin cycle starts, runs about 5 secs,stops for about 20 secs, runs again for about 5 secs and code of uC pops up on panel. model 6800. Any ideas??
Hey bob_marianne ,
Common problem with the FAV6800AW/FAV9800AW. If you have basic mechanical skills you can fix. It’s just a tight work area to work on the Clutch in this machine. See this post for the details and you can get your $1K machine back in service. Sorry to say a lot of these machines get tossed for a $50 dollar clutch. Let me know if you have any questions after you read the post.
Rich
Jul 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Need help asap, please!
Turn your timer to spin cycle ( doesnt need any water)and turn it on.Now if its starts spinning and than shuts off immediatley turn it back on, if there is nothing happening when you try this >>>Replace your motor.There is a 15% chance that your timer is broken and is sending improper current to the motor.First change motor.If you have been running this on a extension cord or when your community is using alot of electricity it would be the reason your at this problem.Dont run Appliances on super Hot Days ,use them in the evening and your motor will run at a low temperature. Please Rate This !!!
Jul 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Heating & Cooling Logo
47 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
