Question about Rage Tumbling Mat - Ma-91000/r - Gymnastics Mats Gymnastics Mats
How to drain oil yard man model 13at604g755 - Rage Tumbling Mat - Ma-91000/r - Gymnastics Mats Gymnastics Mats
Where is the oil drain plug located on model 407577
Should be a plug on right side engine almost bottom of engine.
Apr 22, 2016 | Yard Man Yardman Riding Lawn Mower 38in...
Why does yardworks 173cc bs engine will start, run, for 2-3 seconds then stop
Bad gas. Drain gas and refill with fresh gas with Stabil. Old oil. Drain oil fill with fresh 30w oil, 16-18oz. Clean air filter and spark plug.. Relpace air filter if dirty. Saving $$$ on this simple tune up is not intelligent.
May 11, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
How to change oil
If is like mine remove the oil filler cap and tip it up over a drain pan some of the older models have a drain plug on the bottom of the motor that takes a square 3/8 extension on a ratchet to remove over a drain pan
Apr 05, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Won't start...turns over...took. Air filter off and gas and oil mixture shoots up into their once it starts
sounds like the needle valve in the carb is not seating and the fuel is draining into the oil
May 14, 2012 | Yard Man Garden
Describe your Yard - Man 160cc, 21" Self - Propelled Lawn Mower Problem i don't know where oil drain plug is
You'll find most Briggs and Statton Engines have an oil drain plug directly on the bottom of the engine. It is square and can be removed with a 3/8" ratchet with no socket on it (you just stick the ratchet or ratchet with extension right in the hole and turn it CCW. When you put it back in, make it tight, but not too tight or you'll crack the block of your engine (trust me!). Some engines such as the Honda's do not have an oil drain plug and you need to just dump the oil right out of the fill spout. Awkward. Your engine will hold between 20 and 22 oz of straight 30 WT oil; do not overfill it. Put in about 20 oz. and let it sit for a few minutes then check it on your dipstick. Hope this helps and best of luck to you.
PS: Always remove the spark plug wire before working on your engine! Turning the blade by hand could start your engine and cut your hand off!
James
Sep 18, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I need to change oil in my yard man lawn mower. Where is the drain plug? I need to change the oil
Hi, you drain it out of the dipstick filler hole by tipping the mower to that side. Remove the sparkplug cap first as a safety precaution. Hope this helps, regards Phil.
May 17, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
We have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Apr 12, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Oil change
Most push mowers, you just take out the filler plug and turn it on it's side to drain.Set the mower up on blocks so it rests 6-8" off the ground, place a large catch pan underneath for the oil.
Apr 09, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Oil change in yard man lawn mower. i am unable to find a drain plug
Some mowers are designed to drain oil out of the dipstick tube. remove dipstick and tilt the mower to allow oil to run out into a drain pan. 2/3 rds of a quart or 20 oz is what to expect.
Dec 05, 2009 | Mtd 22" Yard Machine Push Mower
My yard man mower is blowing black smoke when I crank it. Why would this be?? It was low on oil, but we filled it up and it still smokes. Do we need to change the oil? If so how? It has a honda engine, and...
Like the other guy says drain the oil out. Disconnect the spark plug wire (for safety). Place the mower onto a stable platform to work from. To remove the drain plug usually you need a 3/8 ratchet and I use a short extension so I don't skin my knuckles. Put the extension end into the drain plug and remove. Have a drain pan to catch the used oil. Clean the area around drain plug first. When oil is drained replace the drain plug and tighten. Add your new oil. ONLY ADD ABOUT 15 OUNCES. Use SAE 30 motor oil. Once you get the oil in set it on a flat surface and check for the proper level. Add if needed. Usually the push mowers only use about 16 ounces. I start with 15 because it is easier to add than remove the oil. Replace the spark plug wire, prime and start. It may smoke awhile to get the old oil burnt up.
Aug 15, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Rage Tumbling Mat - Ma-91000/r - Gymnastics Mats Gymnastics Mats Logo
88 people viewed this question
Top Rage Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Rage Baby Gear Expert? Answer questions, earn points and help others
