Question about Beko 17WLB450S 17 in. LCD TV
Beko wall screw - Beko 17WLB450S 17 in. LCD TV
Resetting a Beko wm74135m washing machine
The only reset is to disconnect the wall plug for a few and then plug back in.
Feb 06, 2017 | Beko Washing Machines
Have a beko dfn05x10w which won't fill- -and now won't switch off? Is there a reset button??
No such button, unplug it from the wall and wait a few min's, that is the only reset.
Jan 04, 2017 | Beko Washing Machines
How difficult would it be for me to replace an heat element on a beko oven ?
1st thing is to have the unit unplugged so you have no risk of shocking yourself. Most elements are attached to the back wall with a couple screws then you should be able to pull the element forward and then the element should have male and female connectors on it that should just pull off, but hold 1 end of wire and the element connector so the wire doesn't fall back.
Jan 28, 2014 | Beko Belling Oven Cooker Grill Element...
How do I replace the rubber door seal on my beko wmb71642w?
This video will show you in detail how to replace the door seal gasket and fit the new one properly to beko wmb71642w washing machine How to Replace Beko washing Machine Door Seal
Oct 17, 2013 | Beko Genuine Washing Machine Door Gasket...
My beko dryer keeps saying water tank full when it is empty!
empty the small reservoir around the back
there's a single screw to take out and siphon the water out with a small bore pipe I used two drinking straws taped together
you will see the float go down and turn the switch off
Mar 21, 2012 | Dryers
Replacing Beko Upright Refrigerator interior bulb
Try the second screw you wont know till you try it. Im not familiar with this type but if you have tried everything take the second screw out. Let us know how it goes!! BB
Dec 15, 2009 | Refrigerators
Beko oven door - permanently detached?!
Hi - in the end I found the cheapest local oven repairers and they ended up having to do a bodge job ... they admitted that Beko was a bad brand with lots of design problems, this being just one of them. By disconnecting and opening up the back he managed to get one of the hinges back on (with my help!), but for the other he had to resort to using bigger screws coming in from the front. Recently, after less than 18 months of use, the oven and one of the hotplates stopped working on the same night. I gave the whole thing up as a bad bet and ordered a more expensive Indesit I'm now completely happy with. I think with ovens you get what you pay for. I would never touch another Beko ANYTHING with a barge pole!
Jul 28, 2009 | Ovens
Remove beko oven door
You have to look under the door seal and you will find the screws you have to remove to get at the hinges screws
May 19, 2009 | Ovens
Conection of a beko electric cooker
Pretty normal problem with Beko.
You need a Philips 2 screwdriver to get a suitable grip on the screwhead.
Good Luck!
Nov 26, 2008 | Ovens
Beko 17WLB450S 17 in. LCD TV Logo
13 people viewed this question
Top Beko Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
