Question about Garden
Mulching block is in place eliminating a side discharge trail. However, the mulching process leaves a trail beneath the mower, which requires a second pass to eliminate the cut grass trail.
  • frakes342 Jun 23, 2009
    2009 Troy Bilt Pony lawn tractor w/installed mulching block.
    The problem relates to the necessity to go over the already cut grass to mulch it, instead of getting the mulch effect on the first pass.
  • 520 Answers
They make a very strange looking blade that fits this machine that eliminates the need for double passes. Often referred to as a heavy mulching or a single pass mulcher. They are a bit pricey though. They resemble the letter S. Keep in mind when you use mulching equipment that you need to go a bit slower to let the machine do its job to its best. Post back and let me know how this works for you.
Posted on Jun 24, 2009
  • 1 more comment
  • Chris  Jones
    Chris Jones Jun 24, 2009
    With these blades there is no need to double pass. The blades do all the work. I have been using these blades for two years now. As long as I keep them sharp they do all the work in one drive around the yard.
  • Chris  Jones
    They also make a bagging system for the pony that costs $361.90 that would bring you up to full speed and you could use the compost to start a compost pile for rich soil. The part number is 190-180. Just in case your interested.
  • Chris  Jones
    Basically what I was saying in the first post was that the blades that you are using now may not be ideal for your application. You may want to step them up to a more professional series that will do a better job for you on your lawn.
  • 241 Answers
Peat moss can be used as mulching material, because its resistance to soil compaction is good, it looks very attractive, excellent resistance to wind blowing, easy availability, no fire hazards and universally available.
For mulching coarse grade is good. If added to compost bin, it speeds the composting process, reduces odour, controls air and water in the compost pile.
Compared to compost, it decomposes very slowly over several years. It is environmentally friendly. It is free of insects, weed, seeds, salts and chemicals.
Supplementing your lawn with a thin layer (top dressing) of peat moss with an equal portion of well-shifted compost is very good. It saves your time and money in the long run by clearing up diseases and amount of water your lawn requires.
While transplanting trees and shrubs the best way to do so is to mix in right amount of peat moss. For vegetable and flower gardening peat moss creates ideal growing conditions.
There is no single material currently available that provides all the advantages of peat, although there are many alternative products like coir fibre that are satisfactory in specific uses.
The Peat Research and Development Centre, Shippegan, New Brunswick, conducted research comparing performance of sphagnum peat moss, coir fibre and green compost as amendments in sandy and clayey soil, and its effects on the growth of tomatoes and impatiens.
Research found that while compost and coir in various blends with sandy or clayey soil, performed nearly as well as peat moss under certain conditions, none worked as well as peat moss under all conditions.
Remember one important step, before you till dry peat moss in to the soil, is that it must be well soaked, because dry peat moss will repel water.
So, fill the bag with water and let it soak overnight. Dig one-inch of peat moss into the top six inches of soil to condition the area of existing plants or new transplants.
Traditionally green manure crops are sown and allowed to grow, until the land is needed again. At this point, they are cut down, dug in to the soil and are left to decompose, releasing vital plant nutrients back into soil, which are then used by the next crop. You can use green manure crop as a mulching material too.
Posted on Jun 23, 2009
    Genius:
  • 1,689 Answers
What is the brand and model of your mower?
During mowing grass will gather underside of deck leaving 2 streaks on r and l if you turn deck off grass will fall out of deck before restarting u need tgo move or mower will stall from grass build up...
There are a couple of things going on here. First, the blades are likely worn out and need replaced. As they wear and loose some length they can leave a trail. Second, if you have regular blades on a deck configured (by having discharge plugged) for mulching and you are using regular blades, then you can have a problem with build up. Third, you can have clumping problems if the grass is not dry when you are mowing.
I hope this is helpful for you.
Aug 24, 2011 | Ariens 48" Riding Lawn Mower Blade ...
I am looking for the instructions on how to install a mulching kit
It is usually a fairly simple conversion. The discharge are on the deck will have to be completely covered with a plastic cover which should have 2 attatchment point. The regular blades will have to be changed out and the new (or used) "mulching" blades installed in their place. The design of the blades is different. That about covers it.
May 21, 2011 | Ariens Zoom 42 In Grass Mulching Kit ()
This is my second mower. First one damaged after hitting a rock. My replacement mower will not discharge grass out of the side discharge. I have the mulching attachment in and the discharge chute as...
it could be a low lift blade on it. try to get gator blade for mulching..... or a high lift blade. lol, size does matter!!! this may fix the issue. there is so many blades out there now, experiment till you find what your looking 4......
Sep 21, 2010 | Worx 19-Inch 24 Volt 17 Ah Mulch/Bag/Side...
I have a model 944-604810 riding lawn mower and find that it leaves a trail of cut grass even though it is equipped with a mulching blade and a new mulching cover. It would appear that the grass is not...
yes that is most likely the cause of it, also, you have to cut more often when mulching, and the higher the cutting deck, the more likely the grass will blow out without getting mulched enough. More than likely, the blades are dull, and/or the grass is too high, or possibly even wet if it is high.
Aug 23, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
To mulch my grass clippings, do I have to use the side discharge or can I simply remove the bag and insert the rear plug?
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Jun 10, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
What type mulch kit do I get. One says stamped deck zoom 34
Mulch kits are a waste of money. If you have high lift mulching blades you keep the grass in the deck long enough to do the desired cutting. Open the deflector and block it open with a bungee strap and let the blades spread the grass,so you get no streaking or wind rowing.
CAUTION
Always discharge away from PEOPLE and Buildings and automobiles. I cut an acre here that looks like any golf course with NO MULCHING KIT. MULCHING BLADES ONLY.
Oct 19, 2009 | Garden
I would like to buy a petrol lawn mower, i have found out there are mulching lawn mowers on the market, what are your views on this type of mower
Mulching mowers are great if you dont have the time to rake the excess grass or the means ( time or ability) to dispose of te collected remains. The mower will mulch te grass right back over te top of the cut grass with minimal apperance of grass being left behind, if you kep up on the cutting schedule that is. Better for larger areas where "lines" would usually remaine with a non mulching mower.
Aug 11, 2009 | Black & Decker Black and Decker Mm575 18"...
Can a mulching blade work in a non-mulching mower?
True Mulching mowers have a specific deck design to them, but I would say yes to your question.It's been quite a few years, but I have done this little conversion myself - replace regular blade with a mulching blade. Just make sure the mulch blade does fit your mower. Also, use something substantial in terms of strength to close the discharge opening. There can be a good deal of force placed at the opening from flying debris. You'll also want to make the cover removable, so you can mow damp grass without the cover.
Jun 02, 2009 | Garden
Craftsman 6.5 lawnmower
The bag return on the 6.5 sits on two hooks. Standing to the left of the mower you should be able to grab the back handle with your left hand and then left the metal protective flap with your left hand so you can raise the bag assembly still in your right hand up and out of the two hooks. You'll then need to put back into the mower the mulching kit which blocks the rear discharge and makes the underside of the mower a complete circle so the mulching effect works. Obviously the mower will physically work without the mulching kit because the metal protective flap will cover the rear eject but it will NOT effectively mulch the clippings and you will get longer pieces that clump.
Hope this listing isn't too late to help.
sean
Apr 28, 2008 | Craftsman Computers & Internet
Saw your post about Black and Decker MM525 Lawn Mower
Most lawn mower mfgs offer a mulching kit which usually consists of a metal plate to block the discharge opening and a mulching blade which just has a longer sharpenned cutting edge.
With a little labor you can make your own.
Johnww1422@aol.com
Apr 19, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
