Question about Canon PIXMA™ iP4300 InkJet Photo Printer
Mine too!! this morning when i got to work it wouldn't recognise the paper. it printed a printer 'test' print but nothing else. no ideas!
  • leah_klugt Jun 23, 2009
    thanks for your help. i have reinstalled the driver - -we'll see if that works!!!...
    ... nope. :( damn!
    still making the sound. i can't see a little stick that detects the paper.
    it's a work printer, it was on when i got here this morning. me thinks someone has stuffed it!! grrrr
    Scholar:
  • 41 Answers
There may be a little stick in the back of the paper tray that detects if paper is in the printer. When paper is placed in the tray, it pushes the stick down, and sends a message to the printer that paper is ready. If that stick is broken, or is not being pushed down fully, it could cause the printer to think that there is no paper.
Not all printers use this method for paper-detection, so there may not actually be a stick in your printer. Make sure you're putting in the paper all the way, and if nothing else works, you could try reinstalling the print drivers, as well as updating the printer's firmware.
Posted on Jun 23, 2009
My Canon Pixma MX882 is not printing though lots of ink. Paper goes through when I press print on my PC but nothing is printed
Print a test sheet to see if the printer is OK. If tthe sheet prints fine has this printer worked on this computer before? Did you change anything or update anything? You may have the wrong driver installed or the cable could be defective if it has worked before.
Feb 02, 2015 | Canon PIXMA Office Equipment & Supplies
Prints clean sheet - not printing anything on the paper
mine did that too, no text on page, we had to change the defeat setting from the router.
Mar 20, 2014 | HP LaserJet Pro P1102W Printer
Printer was working fine, until it's outflow was accidentally obstructed. Obstruction removed, but now error light comes on immediately, and printer won't print. There is nothing blocking the paper path,...
Try this troubleshooting prodedure. Turn on/off, unplug, plug in2_bing.gif, should reset configs.
Take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck preventing from accepting paper.
Go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
Go to web site of printer model and check site for trouble shooting if this does not work above. Hope this helps and good luck
May 31, 2010 | Brother HL-2170W Laser Printer
My x4650 is not recognising when I refill the black 36XLA cartridge. Just keeps telling me it is empty. There is not a problem with the cartridge itself just the failure to recognise it has been refilled....
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats. or take cartridge out and put back in to insure in securely.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Lexmark X4650 InkJet Printer
Epson R220 won't print. Paper feeds through OK, print head moves as if printing but no ink comes out. Tried several sets of cartridges and this makes no difference. Cartridges are recognised fine and no...
Nothing at all? Problem with micropiezo (micro pump) at head. But you said, replaced print head. So it might just lost electricity to head (problem with board).
Jun 10, 2009 | Epson Stylus Photo R220 InkJet Printer
Print heads and test prints fine......will not print ay documents
I subsequently discovered that only black would not print - the other colours did. The following solution should work for any colour
Turn on the printer
Lift the front cover so that the ink tanks line up at the front
Move the grey arm to the right of the yellow upwards
Remove the ink tanks (in my case 4)
Carefully lift out the plastic holder for the ink tanks, this I believe holds the print heads
Clean the head(s) using cotton buds and injet refill ink cleaning fluid. I get mine from Tescos with my refill inks.
Replace everything and hopefully your printer will be o.k. Mine was
Jun 05, 2009 | Canon BubbleJet i560 InkJet Printer
Printing problems
plz check whether the driver is installed, go to printers on control panel and try for a test page print, if test is printed, then could be ur software is looking that printer.
Aug 18, 2008 | ASUS Eee 4G Notebook
No ink on paper
You need a new print head.....if your pixy is 3 years oldish...only thing that worked for mine try ebay or states.
Mike
Mar 03, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
MFF6550 Printing nothing but white paper.
I unplugged my printer for 10 minutes and then plugged it back in. It went into an initialization mode and was fine after that.
Nov 15, 2007 | Canon imageCLASS MF6550 All-In-One Laser...
Canon PIXMA™ iP4300 InkJet Photo Printer Logo
old marine
old marine
