Ratio 15 to 55 - Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
In simplest terms, 3 to 11.
Posted on May 11, 2014
Diff ratio. On a 1994 toyota 4 runner v6 petrol ??
4x4, 4 cyl, 4.10 ratio, ABS 4x4, 4 cyl, 4.10 ratio, w/o ABS
4x4, 4 cyl, 4.56 ratio, ABS 4x4, 4 cyl, 4.56 ratio, w/o ABS
4x2 (3.90 ratio), 2 wheel ABS 4x2 (3.90 ratio),
4 wheel ABS 4x4, 6 cyl, 2 wheel ABS, 4.30 ratio
4x4, 6 cyl, 2 wheel ABS, 4.56 ratio 4x4, 6 cyl, 2 wheel ABS, 4.88 ratio 4x4,
6 cyl, 4 wheel ABS, 4.30 ratio 4x4, 6 cyl, 4 wheel ABS, 4.56 ratio
4x4, 6 cyl, 4 wheel ABS, 4.88 ratio there are a few options. you will need to figure it out or look at the code panel in the truck. if you want to figure it out. you will need to remove the cover from that axle and count the two ring gears and then divide the numbers to get the gear ratio. for example if one is 40 and the other was 11. would be 3.72. so here is the trick to counting the gears. they are covered in oil so have a pan ready when you pull the cover. and use a marker or crayon and mark a tooth on the gear ring. then count the gears and you will know where to stop when you get back to your mark. the little gear will be harder since its in the back. you might have to turn the wheels and you will need it in neutral and jack the rear end up. as always use jack stands to prevent damage to you or the truck..
Mar 20, 2015 | 1994 Toyota 4Runner
How to fig out planetary gear ratios .between sun gear and ring gear and planetary .it has multi gear sets
The ratio is determined by the relationship between adjacent gear circumferences. The circumference of a circle is expressed as Pi D, so the ratio between adjacent gears is the ratio between their diameters. The overall ratio for the multi gear set should be the product of the ratios of all of the gear sets.
Mar 17, 2015 | Cars & Trucks
Please explain how you do ratios
A ratio can be simplified by dividing both sides of the ratio by the Highest Common Factor (HCF). The highest common factor is the largest number that goes into both numbers of your ratio. In example 1 you are asked to simplify the ratio 6:8. Here the HCF is 2 so divide both sides of the ratio by 2 to give 3:4.
https://www.youtube.com/watch?v=cbjQWf411O8
Mar 04, 2015 | The Learning Company Achieve! Math &...
What is the ratio of 400
A ratio involves two numbers.
The ratio of 400 to 1 is 400 to 1. The ratio of 400 to 2 is 200 to 1. The ratio of 400 to 10 is 40 to 1. The ratio of 400 to 1000 is 2 to 5.
Jul 03, 2014 | Office Equipment & Supplies
I dont know what a ratio is
A ratio is a division of two quantities that may or may not be of the same nature.
Same nature
You can for example have the ratio of the perimeters of two similar triangles. ratio=perimeter1/perimeter2
Different nature
If an automobilist travels at a constant rate (notice the root RATE, RATIO), the rate of travel is expressed as the ratio of the distance travelled (d) to the time taken to travel the distance. That ratio is called the speed v
v=d/t
Since the ratio involves two quantities of different nature, the speed has a unit derived from the unit of distance and the unit of time; Example v=65 km/h
Other examples:
There is a ratio of 1.45 US $ to 1 Euro. This is usually referred to as the exchange RATE.
The odds of something happening is 7 to 2.
What is really meant when a ratio is involved depends on the context. But what you should remember is that a ratio involves the division of two quantities.
Proportions: The equality of two ratios is called a proprtion.
Feb 08, 2012 | Office Equipment & Supplies
What years and makes of fords are interchangable with the rear end on a 1990 ford f-150
Depending on which rear axle assembly your 1990 F150 has....
Please indicate which is most applicable to your vehicles current axle assmembly.
ABS, 2.73 ratio
ABS, 3.08 ratio
ABS, 3.55 ratio
ABS, 4.10 ratio
w/o ABS; (Canada mkt), 2.73 ratio
w/o ABS; (Canada mkt), 3.08 ratio
w/o ABS; (Canada mkt), 3.55 ratio
w/o ABS; (Canada mkt), 4.10 ratio
Sep 28, 2011 | Cars & Trucks
Need a list of rear axles that are compatible with a 2000 Chevy silverado 4x4 1500
FBB}A}}435}937737" checked="checked" type="radio" name="userInterchange" />4x2, 3.08 ratio (opt GU4)
FBB}B}}435}937738" type="radio" name="userInterchange" />4x2, 3.42 ratio (opt GU6)
FBB}C}}435}937739" type="radio" name="userInterchange" />4x2, 3.73 ratio (opt GT4)
FBB}C}}435}937740" type="radio" name="userInterchange" />4x4, 3.73 ratio (opt GT4)
FBB}D}}435}937741" type="radio" name="userInterchange" />4x4, 4.10 ratio (opt GT5)
you know since it's a 4x4 the front and rear axle HAVE to be the same.
Aug 26, 2011 | 2000 Chevrolet Silverado 1500
94 caprice classic rear spider gears shot 12 or 16 possi what other rear ends are compatible for this 5.7 liter
. Axle Code >>>>>>>>>>>Standard
2YN Gear Ratio >>>>2.56<<<<< Ring Gear Diameter 8.5 Standard 2GA Gear Ratio 2.73 Ring Gear Diameter 7.6 Standard 2GB Gear Ratio 2.73 Ring Gear Diameter 7.6 Standard 2GH Gear Ratio 2.73 Ring Gear Diameter 8.5 Standard 2LW Gear Ratio 3.08 Ring Gear Diameter 8.5 Standard 2LR Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 2LY Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 2LT Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 6YF Gear Ratio 3.23 Ring Gear Diameter 8.5
Axle Code>>>>>>>>> Limited Slip
2LQ Gear Ratio >>>>>>>>2.93<<<<<<<<<<< Ring Gear Diameter 8.5 Limited Slip 2YG Gear Ratio 2.93 Ring Gear Diameter 8.5 Limited Slip 2LX Gear Ratio 3.08 Ring Gear Diameter 8.5 Limited Slip 2ND Gear Ratio 3.23 Ring Gear Diameter 8.5 Limited Slip 2LZ Gear Ratio 3.23 Ring Gear Diameter 8.5 Limited Slip 2LS Gear Ratio 3.23 Ring Gear Diameter 8.5
Nov 28, 2010 | 1994 Chevrolet Caprice Classic
The ratio of a to b is 2 to 5 and the ratio of b to c is 3 to 4, what is the ratio of a to c
To solve this, you need to multiply the ratios together.
(2/5)*(3/4) = A/C
So (2*3)/(5*4) = A/C
6/20 = A/C
You can reduce that be dividing both sides by 2
3/10 = A/C
Here is an example:
Let X = 3
The problem states that A/B = 2/5
So let A = 2X & B = 5X
A = 2*(3) = 6
B = 5*(3) = 15
Now check the ratio: 6/15 = 2/5. The same as what was given.
Now lets look at the ratio for B/C. The given ratio for B/C was 3/4
Using the value of B that we just solved we get:
B = 15
C = (4/3)*15 = 20
Check the ratio.
15/20 = 3/4
Now we have the values for each of the variables
A = 6
B = 15
C = 20
The ratio of A/C is 6/20
6/20 can be reduced to 3/10 be dividing both numbers by 2
Aug 22, 2010 | The Learning Company Achieve! Math &...
What is the gear ratios on a 1990 heritage soft tail 5 speed
Here are the stock gear ratios:
Gear Ratio (1): 10.11
Gear Ratio (2): 6.96
Gear Ratio (3): 4.95
Gear Ratio (4): 3.86
Gear Ratio (5): 3.15
Dec 21, 2009 | 2005 Harley Davidson FLSTC - FLSTCI...
14 people viewed this question
k24674
jasbo
jasbo
