Lcd cable connection
I have 12inclcd cst1220 compney name cyberscan technolagy. model no lm-tgt220. i lost this lcd vga cabel now new cabel not avalabel in market. it has no power suply cabel conector (no dc or ac in put pin)it has only one conector whic have 25pin one side and 25 pin other side (total 50 pin in conector)just like 50 pin Amphenol female connector but i not sure. now i want make acbel for this.i need this lcd female conector conection data.
jemmyrash
  • 180 Answers
SOURCE: Missing VGA Cable for LCD Monitor - Help?
It should be 15 pin connector VGA .It should work.
Posted on Apr 19, 2008
chinna_1977
  • 65 Answers
SOURCE: LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Posted on Nov 17, 2008
  • 3 Answers
SOURCE: july 1, 2009- I need to replace my burn-out ac
Try website. - http://www.lcdpayless.com I placed my order on Thursday and went out of town for the 4th and I checked my mail today (Monday) and it was there. I plugged it in, the power came on and the tv works perfectly....plus the new cord doesn't have an annoying fan.
The cord is pricey at $117, but it beats buying a new tv. The company accepts returns minus a 20% restocking fee and shipping, so I figured worse case scenario I would only be out of $40+bucks if it didn't work and I had to send it back. Hope this helps!!!
Posted on Jul 07, 2009
poole72
  • 71 Answers
SOURCE: DC Jack pin is broken on my Toshiba satellite p25 S607
you have to strip down the laptop so you can access the underside of the motherbord then you need to desolder the solderd connectors and remove the DC jack
then put the new DC jack in its place and solder back in place
please note this is quiet a big job and requires knowlage of laptops
Posted on Dec 02, 2009
SOURCE: lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Posted on Sep 06, 2010
I am not sure how to connect my gifted LG 295 LM Monator to my PC
so it has power ?
is p.c ?vga display output ?
https://en.wikipedia.org/wiki/VGA_connector
is monitor vga input ?
or is p.c only hdmi output ?
https://en.wikipedia.org/wiki/HDMI
if vga on both you need a vga cable
if hdmi on both you need a hdmi cable
if pc is VGA and the monitor is hdmi then an adapter is needed
if p.c is hmdi and monitor is vga then an adapter is needed
suggest figure out video cable standards and then decide on what you need
as shop will need to know what standards are used VGA or HDMI ?
Jan 18, 2017 | LG Computers & Internet
Delll monitor Model 1503F has power but locks in power save mode
Open your computer case and clean vga card and rams. If then will not be changes, put out four cabels/ near the CPU/ from motherboard and put in. It will work.
Feb 28, 2013 | Dell 1503FP 15" LCD Monitor
Screen blank with white dot
Problem with;
1) Video cable:
A) Video cable connection on motherboard side is loose, and/or on back of LCD screen.
B) Video cable is damaged.
2) screen Inverter:
screen Inverter is bad.
3) LCD screen:
LCD screen is bad.
4) Graphics chipset:
Graphics chipset is bad.
Suggest you connect a VGA monitor to the VGA port (Connector) on your laptop.
See if the problem is the graphics chipset, Or video cable, Or display assembly.
You didn't state what manufacturer and Model Number of laptop this is.
All I can do is state generic information.
This is an example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
The VGA connector will be on the side, or back of your laptop.
For the VGA monitor you can use a CRT type monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
Laptop OFF, monitor OFF, connect the external VGA monitor to the laptop.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
IF not;
There are at least 3 display options.
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
(For an example HP's usually use the F4 key for a Display Toggle-Over key)
Display shows the same on the external VGA monitor?
You have a bad graphics chipset.
[ Some laptops have been erroneously stated as having a graphics card, when in fact they do not.
The GPU (Graphics Processing Unit) is soldered directly to the motherboard.
This is Integrated Graphics.
http://en.wikipedia.org/wiki/GPU
There is no changeable, replaceable graphics card. Therefore the solution is motherboard replacement ]
IF, the display is good on the external monitor, you have a problem with the Video Cable, and/or in the Display Assembly.
After diagnosing with an external VGA monitor, post back in a Comment.
Also post the manufacturer name, and model number of the laptop.
Regards,
joecoolvette
Apr 22, 2012 | Computers & Internet
In my dell inspiron 1525 laptop function key not working and i want to attached LCD TV with this. so how can i enable function key
only if your Fn key is not working then may be its not a hardware but a software problem. then you just have to replace the keyboard.
And to connect your LCD, you just need a VGA cabel or HDMI cabel. this laptop has got both the port use either of them to connect your LCD.
Dec 31, 2010 | Dell Inspiron 1525 Notebook
I have a Laptop and an Acoustic Solutions Tv. But what i want to know is how to connect my laptop to the tv? What cables do i need? My laptop has the vga connection but the back of my tv will. i...
I believe the number that you have sent me is the serial number, Your TV should have a name and model #. For example (Sony Bravia model #00000) Yours would be RCA ? #?. The model number should be on the back of the TV. Is the TV an LCD flat screen? If it is and is fairly new it will have a special place to plug a PC into it. With the model name and number of your TV I can look for the manual and lok at the connection set up for your model.
Dec 28, 2010 | Televison & Video
The screen flick when connected to Samsing Sync
Hello there!
Screen flickering can be caused by instability of cable you are using, or it can be also caused by difference between power input, so check your power plug ,where your monitor and pc are plugged, make sure they are ok for your region, and check those cabels. Also check settings on monitor for what input you are using DVI or VGA or both at the same time.
Sinecerly
Aleksandar Adzic
Apr 16, 2010 | Computers & Internet
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Display PIN settings
take 15pin connecter 2 nos and cable wire to make cable
make wireing 1 to 1
yourr cable will be redy
ashok
Jan 19, 2008 | NEC LT 17u 17" LCD Monitor
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
