Question about Microwave Ovens
The turntable stopped on my sears microwave. how do i fix it?
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 95 Answers
There is either a direct drive motor under the platter, in the center of the microwave, or there is a motor off to the side, either on top of or under the cavity., that has a rubber belt, like a rubber band that drives the turntable...belt is broken, or there is not power to either kind of motor...use a mutimeter if you have one or a light bulb made to light with 110 volts...hope this helps...if the motor is burnt up replace it..if there is no power to the motor leads...then the main control board if probabley bad...
Posted on Jun 10, 2014
SOURCE: frigidaire microwave gallery series turntable is not turning
This co. has one for $19.99
http://microwaveglasstrays.com/shop/microwave-turntable-motor-st16fe-ex73saaa3-p-214.html
I am also looking elsewhere
Posted on Apr 27, 2009
  • 574 Answers
SOURCE: Microwave turntable.
Is that the only thing that doesn't work? If so it could be a coupler or a belt, possibly the motor it self.
Posted on Sep 17, 2009
SOURCE: GE Spacemaker microwave turntable no longer turns.
This is a common problem the turntable motor has failed, it can be replaced.. but Microwaves are VERY dangerous. Due to the enormous energy stored in the main Capacitor, this MUST be discharged to earth B4 attempting any repairs. apart from that though should be easy enough. I do recommend a reputable service center/man tho.
Posted on Jan 26, 2010
neutronrace
  • 66 Answers
SOURCE: The turntable on our XL1400 stopped working. Is
the diskmotor is defect?
mesure the resistor of the motor with reduction under the plate the value must be bethween 60 and 100 Ohm.
if not the coil is burnd and you have to replace the motor.
Posted on Feb 15, 2010
  • 6771 Answers
SOURCE: microwave turntable stopped turning. Can I fix this?
The turntable motor will need to be replaced, this type of repair is tricky not to mention the lethal voltages it carries. I strongly recommend a professional for this job.
Posted on Jun 25, 2012
This problem is very common.
The turntable motor is defect or its gear mechanism worn out.
You'll need to have the turntable motor unit replaced.
May 10, 2014 | Microwave Ovens
Microwave turntable stopped turning. Can I fix this?
Jun 24, 2012 | Emerson Microwave Ovens
Microwave turntable has stopped rotating can I fix it?
microwave turntable has stopped rotating can I fix it?
Mar 07, 2010 | Microwave Ovens
Sears Kenmore Microwave Model 401.80086700
Hello
Youcan see that turntable at the down side there is a screw which is missing because i m also having a same problem but now once you change that screw which is losse it will work
Thanks & Regards
May 24, 2009 | Kenmore 80412 Microwave Oven
Frigidaire microwave gallery series turntable is not turning
Mar 04, 2009 | Frigidaire FMT116E1B Microwave Oven
My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Nov 29, 2008 | Kenmore 63792 Microwave Oven
Grinding noise from turning platter mechanism - Kenmore #63252
If yours sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
Sep 23, 2008 | Kenmore 63252 Microwave Oven
Noisy turntable
I has this problem with a Sears unit. The repairman simply removed the glass tray, cleaned all the wheels and the 3 toothed driver wheel in the middle and it became quiet. He explained that if any buildup keeps the plate from properly seating on the gear, it gets very noisy.
Mar 25, 2007 | De Dietrich DME112X Microwave Oven
Turntable roller rest
It's called either the turntable coupler or the turntable support, depending on your model number. You can visit the Sears parts Web site at http://www3.sears.com/ and enter your full model number and see exploded view diagrams, parts lists, and order the part. Or you can call Sears parts at 1-800-252-1698.
Mar 24, 2007 | Kenmore 62463 Microwave Oven
Microhood turntable not working
You can find an exploded view of your microwave at http://www3.sears.com (yes, the 3 is there). Ref # 3009 on the drawing is the turntable motor. I would grab it by the shaft and gently try to turn it. If it's locked up or grinding, that's a sign it's bad. It runs $24.49 plus shipping: Part Description: Quantity: Part Number: Model Number: Price: TT MOTOR 6549W1S013D 721.64663300 $ 24.49 $ 24.49 Be sure to unplug the oven before you work on it. Hope this helps!
Dec 01, 2006 | Kenmore 63763 Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
