Question about Microlife Premier Value Digital Blood Pressure Monitor
Where can i find what the readings mean on the NQ1-DPV
I connected my dpv-sr210p to my 32"inch emerson flat screen tv and nothing wont show up on the channel that is for the movies
Are you sure whether the input selection done with the TV is correct? Refer the user manual to your TV for more details.
Electro help
Nov 15, 2014 | Televison & Video
How do I access the battery
The Bladefish doesn't have just one battery. There are several. I can only speak for the bladefish 3000. It has 5 batteries. They are 3.7 volt LiMg high drain batteries that have and expected life of 2 to 3 years whether you use the bladefish or not. You should not attempt replacement of the batteries if you do not have some experience in electronics repair. The batteries are bonded together in one group of three and one group of two. There are about 10 wires that are soldered directly to the batteries so experience with soldering is mandatory. That being said, they are accessed by removing the screws around the front cover and removing the foam pieces under the cover. Then you have to remove the nut on the front of the propeller blade and remove the drive belt and the small drive gear from the motor shaft. once that has been done you can slide a putty knife under the edge of the clear cover and slowly pry it open slowly as you work your way around the unit. I've read that this is almost an impossible task but I did all of the above in about 30 minutes. The real difficult task is to do the physical replacement of the batteries. This requires real skill with a soldering iron and attention to detail. You cannot risk making a mistake in replacement of the wires. Battery polarity is critical. If you get on battery wrong you risk serious damage to the electronics of the Bladefish. When done with the battery replacement you need to be sure to put silicone grease on all of the seals then slowly press it back together and re install the hardware. Any Questions
Aug 25, 2014 | Bladefish 5000 DPV Sea Scooter
Diagrams schematic
The manufacturer will not release the schematic diagrams. I have tried to get them.
Don't charge. when plug on the red light never blinks and never gets green. What should I do?
There is no customer service for it in any country. The Bladefish is no longer made and has been replaced by a more modular model that is more easily repaired. Sorry for the bad news.
Jan 08, 2014 | Bladefish 5000 DPV Sea Scooter
Can I get a repair manual for a blade fish scooter model 5000
If a repair manual exists, the manufacturer will not release it. I have tried.
Jul 07, 2013 | Bladefish 5000 DPV Sea Scooter
Running a Vanguard 23 Hp on my Mud Motor.\r\nQ1: developing a hard starting problem, seems like starting on 1 cylinder, after the first tank of fuel this fall. Fuel filter, spark, and plug OK. Looking at...
It sounds like your valves are out of adjustment. Your starter will bog down if it is out of adjustment and stop at the compression release.
So just take your valve covers off and set your valve lash to
.006 intake
.008 exhaust
Oct 04, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Microlife Premier Value Digital Blood Pressure Monitor Logo
Top Microlife Health & Beauty Experts
Colin Stickland
Colin Stickland
Steve
Are you a Microlife Health and Beauty Expert? Answer questions, earn points and help others
