Question about Refrigerators
GE tbx22qa Not cooling properly, eneither fridge or freezer
SOURCE: GE fridge
Replace the ADC board. That is the problem i had.
Posted on Jan 13, 2008
SOURCE: Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Posted on Aug 04, 2008
  • 531 Answers
SOURCE: GE side by side fridge not cooling enough Freezer side was still
check see if you have frost build up in the freezer back wall you may have defrost problem
Posted on Apr 06, 2009
Sea Breeze
  • 4655 Answers
SOURCE: not cooling properly GE TFX20JR
Your refrigerator has a defrost thermostat inside the fresh food section behind the light cover and control panel. Need you to turn it clockwise slowly until the compressor stops. Leave it like that and after 30 minutes or less it does not restart you will need to replace the timer. The defrost timer is part number WR9X489
You should hear sounds from freezer with door open like sizzling or crackling. That would be the defrost working. If there is no defrost during this time. let me know so we can look into the defrost element and defrost thermostat as possible problems. Visit my site and enter the model or part number into search feature. That takes you to your model. Any questions or help from me, just let me know, Thanks, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
Posted on Jun 18, 2009
heatman101
  • 43501 Answers
SOURCE: fridge and freezer not cooling properly. bottom s...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
68rjszndh
Posted on Sep 29, 2010
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Ge tv239461 freezer is cold but refrig is warm
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 27, 2011 | GE Refrigerators
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
FREEZER WORKING FRIDGE NOT COOLING
Jul 20, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
I have a ge refridgerator gss25k side by side. thefridge/freezer are not cooling. the bottom of the fridge freezes and the top is warm.
There is an air duct that connects the fridge to the freezer. A fan circulates air to cool the refrigerator.
The inside fan has stopped working or is blocked by ice.
Defrost the freezer. If the fridge starts to work properly then you have an auto defrost problem. If the fridge still does not work then there is a faulty fan.
A technician can help you there
Apr 03, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
My ge side by side not cooling, freezer act like fridge
Sounds as tho your compressor is bad if it is still under warrenty take it to the place of purchase.
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
