Question about Ovens
Smeg uk80mfx1 - main cooling fan wont come on. Replaced with new part still wont come on. Everything else seems fine. Power across terminals. Any thoughts please ?
  • 4102 Answers
SOURCE: Smeg dual fuel cooker model number UK80MFX1
it sounds like you have a problem with the thermostat that tells the oven to switch off when it gets to the right temperature if the temperature exceeds the setting you choose then the oven will shut down as a safety feature you can get these replaced but because of the age i wouldnt know where to get them from if you get somenody to come and replace it for you it would be cheaper than buying new cooker then this should get your cooker working nrmally i had this problem but on a different make and model but doing this dolved the problem the only problem i did have was locating the right part number but after i got it it only took repair man 1 hour to fit it and done it for less than 50 quid hope this is some help ..................................
Posted on Nov 05, 2007
SOURCE: Oven Over Heat
Not sure if this is relevant but, have you set the clock correctly?  The oven will cut off if it's cooking on a timer.
Posted on May 19, 2009
barkencoa
  • 3463 Answers
SOURCE: smeg fan assisted oven not heating up , top oven
So long as fan is working o/k, then all you need to do is replace the oven element at rear of oven
Please rate my solution.
Thanks
Posted on Nov 10, 2009
walesarumi
  • 6993 Answers
SOURCE: My Smeg oven does not
the fault is from the heating element of your oven. I don't want to believe that the heating element is defective.
It is possible that the wire connected to the heating element has loosed contact. This can be caused by the heat of the oven. The heat can melt the wire or maybe the wire got disconnected for one reason or the other.
Find a way to disassemble the oven. I don't mean the whole oven, but the heating element part. Check if the wires are connected properly.
This I believe is the step to take to fix the heating problem. But if all the wires are intact, then it means the heating element is defective, that's why the oven is not heating. You can get the heating element replaced in this case.
Good luck.
Posted on Nov 28, 2010
  • 417 Answers
SOURCE: fan has stopped working in main oven,element is
It is usually better to have a new fan fitted than to try to repair it unless it is something simple like a broken wire.
Posted on Dec 19, 2010
Smeg duco8css cooler fan not working
IT IS POSSIBLY THE FAN OR ITS RELAY IS BAD BUT I WOULDN'T JUST GO OUT AND BY EITHER UNTIL THEY WERE CHECKED WITH METER
Apr 21, 2014 | Smeg DO8C Electric Double Oven
Nov 05, 2007 | Ovens
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
Smeg oven UK80MFX1 troubleshooting
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Nov 30, 2011 | Smeg Ovens
Oven fan working. just no heat.
Most common problem will be a faulty oven element. Also check the wiring at the oven element terminals, it could be burnt off.
Feb 17, 2011 | Smeg SE280X Stainless Steel Electric...
Hi My power box just tripped and my oven turned off, prior to this happening it was working fine. I have a smegg oven model se378mfx5. It now wont heat up, it turns on ok but wont allow me to set the...
Feb 16, 2011 | Smeg Ovens
Oven Over Heat
May 01, 2009 | Smeg SE280X Stainless Steel Electric...
Fan oven element
The test is fairly straight forward: Make sure the unit is off. Generally, there is a screw which holds the element in place near the connector. Remove it and the element will slide out. Now, use a resistance (Ohm) meter and measure the resistance across the terminals. If the unit is visibly damaged or you get no reading (use the 1 K ohm scale), change out the element. If the unit tests good, suspect the control or the wiring from the control to the element.
Dec 31, 2008 | Ovens
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
SA999X wont turn off & smells
suspect your electrician wired it up wrong
Feb 20, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
