Question about Toshiba 55SL412U LCD TV
Can you use a external hard drive on a toshiba 55sl412u
4 Suggested Answers
gpetti2009
  • 92 Answers
SOURCE: reformatting an external hard drive
Id you have a xp disk when it loads it will ask you how do you want to set up the drive even though you have and external drive on your computer in the my computer icon Right click and open manage open disk management and you should see your usb drive right click on the drive and you should see format it has a dropdown menu check quick format and click ok and it will start to format the drive make sure you chose ntfs in the drop down menu .good luck
Posted on Apr 08, 2009
  • 5 Answers
SOURCE: can't access or play games on my toshiba external hard drive
What does it say when you run it?
Posted on Jun 08, 2009
lock123
  • 6831 Answers
SOURCE: Toshiba 320gb external drive is not detected by any laptop...
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
TOSHIBA 55SL412U wont turn on
If fuse should blow up, surely there should be a resown for that. You must first check out the reason, and then insert an other fuse of same rating. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts. Check for damaged component/s at its main power supply regulator board.
Dec 22, 2013 | Toshiba 55SL412U LCD TV
Toshiba 593400-e external hard drive problems
Hi.
my external hard disk not supported in my laptop after install new os for window 7 professional 32 bit so pls give the solution
Oct 16, 2012 | Toshiba Canvio Plus 320 GB 2.0 Portable...
How unlock tv toshiba 55SL412u
if you don't have a manule i would type in the model number and you will be able to down load one but becarefull thier are alot of scamers that try to get you to download a viras try the manufacture site
Oct 20, 2011 | Toshiba 55SL412U LCD TV
Toshiba external hard drive 640Gb appears on my laptop the USB connects perfectly ,it opens but doesn't take in any file .
hello, i would advice you to format your external hard drive by write clicking on it and click on format and click on start to begin, if this does not allow you to still put files on your external hard drive,then insert it on a friend laptop and see whether you can move files to it. I hope this helps. Regards
Feb 08, 2011 | Toshiba 640GB USB 20 Portable External...
I cannot connect my external hard drive through the sata port
Install the external hard drive into an USB hard drive adapter case. You can then connect this into the Toshiba's USB port. The Toshiba will see this as an external storage device.
Jan 08, 2011 | Toshiba Satellite Pro M300-S1002X Notebook
I have an external Toshiba 1TB hard drive that begins to power up but shuts down after about 4 or 5 seconds. Can the cover be removed for an alternative to using the external cabinet?
Yes it can be removed. External hard drive enclosures will either be screwed together or just snapped together with clips. You just have to look around
Nov 25, 2010 | Toshiba Desktop External - hard drive - TB...
Toshiba 55SL412U LCD TV Logo
14 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
