Question about Home
How to keep fresh dill - Home
The message am getting is battery charging fault. i managed to book the car in at one of the renault dealerships. Please advise if it is safe to drive the car as the car keeps beeping
If you have a battery charging fault, do not drive the car as it will cut out at a stage when the battery gets too low and leave you stranded. Wait dill the dealer can do the repair
Aug 17, 2015 | Renault Cars & Trucks
Need recipe to make pasta
Tips for Optimum Pasta
The dough should be evenly kneaded, and slightly moist to form a soft malleable dough. The dough should have the consistency which is not too dry or too moist.
The dough is too dry if it has a powdery, grainy consistency and breaks into small chunks. Add more liquid (water or vegetable juice) by the teaspoon until it has formed a smooth, malleable dough that is not sticking to the sides or the kneading spiral.
The dough is too moist if large lumps of dough remain stuck to the kneading spiral. Add flour by the teaspoon until it has formed a smooth, malleable dough that does not stick to the sides or the kneading spiral.
If you add a little bit of olive oil to the pasta dough, it will slide better through the outlet openings of the pasta attachments.
For the pasta dough, you can use both normal household flour as well as wholegrain flour, gluten free flour, or flour made from durum wheat semolina. Different types of flours will require a different amount of liquids. Reserve some liquid and add it slowly for best results. Document your process so you can repeat it in the future.
Vegetable juices made, for example, from spinach, carrots or tomatoes are ideal for adding color and nutrients to your pasta.
Sprinkle flour on your pasta directly as it emerges from the outlet opening and place it down separated on a smooth floured surface to dry. This will prevent the pasta from sticking together.
Cooking time for fresh pasta is much shorter than for dried pasta from the supermarket; 2-4 minutes is usually sufficient. Thinner pastas, however, may require an even shorter cooking time. We recommend you check the pasta at regular intervals until the pasta is "al dente".
Fresh pasta can be kept for 1-2 days in the fridge and frozen in the freezer for as long as 6 months. To stop the pasta from sticking, you should lay the pasta out to dry for 1-2 hours before you store it in the fridge or freeze it.
Pasta recipes
GARLIC PASTA
Add 2 cloves of garlic (crushed or pureed) to the liquid in a full load of pasta. Cook and serve with sauce and cheese.
TWO MINUTE CLAM SAUCE FOR LINGUINE
Pasta: Linguine or Spaghetti
3 Tbsp.
Olive oil
2 Tbsp.
Garlic - finely chopped
1 can
Clams with juice
3 Tbsp.
Oregano
1/2 cup
White wine (optional)
1/2 cup
Prepared pasta sauce (optional)
Fresh ground pepper (to taste)
Crushed red pepper
Saute garlic and clams in olive oil. Add oregano, pepper and crushed red pepper to taste. If desired, add white wine and/or prepared pasta sauce. Pour over pasta, garnish with minced parsley.
FETTUCCINI & CHICKEN
Pasta: Fettuccini (with 2 Tbsp. olive oil or butter)
4 large or 6 small pieces of boned chicken cut in chunks
2 Tbsp.
2 Tbsp.
Italian seasoning
2 Tbsp.
Parsley
Olive oil
Salt & pepper
Bake or saute chicken in olive oil with garlic and seasoning until done.
Place chicken on freshly cooked fettuccini and serve hot. For variety,
add sauteed mushrooms and/or bell pepper. Add Parmesan cheese.
HUNGARIAN PAPRIKA PASTA
To a regular full load of pasta add 2 tablespoons of paprika to the liquid
and stir well before adding to the flour as it mixes.
SPINACH FETTUCCINE IN CREAMY DILL SAUCE
Pasta: Fettuccine, Linguine or Rigatoni
Great with any pasta, but this is very tasty with spinach pasta! Make your liquid for the pasta with fresh spinach juice or mix spinach with a small amount of water in a blender and strain before adding to the egg and oil mixture.
1 Tbsp.
Butter
1 tsp.
1 cup
Heavy cream
1/4 cup
Parmesan cheese
2 Tbsp.
Fresh dill
1/2 cup
Tomatoes - diced
Salt & pepper to taste
Melt butter with garlic in pan. Add cream, salt, pepper, and Parmesan cheese. Stir until cheese is melted. Reduce heat, add fresh dill and diced tomatoes. Remove from heat and gently pour over pasta.
RUSSIAN BORSCHT P ASTA
Measure 2 cups of flour. To your liquid ingredients add oil plus egg. Use beet juice instead of water and 1 teaspoon ground sour salt. Serve as a side dish with sour cream.
PASTA WITH SUN DRIED TOMATOES & PINE NUTS
Pasta: Spaghetti, Fettuccini or Linguine
1/4 cup
Olive oil
1 clove
2 Tbsp.
Italian herbs
1/4 cup
Sun dried tomato - cut tomatoes in 1/8" slices
1/4 cup
Pine nuts
Saute garlic in olive oil, then add herbs. Remove from heat and stir in sun dried tomatoes. Toss lightly with cooked pasta. Top with pine nuts. Serve with Parmesan cheese.
BASIC PASTA WITH FRESH TOMATOES
Pasta: Any of your favorites
6 Tbsp.
Olive oil
2 Tbsp.
Garlic - minced
2 Tbsp.
Basil - fresh, minced
1 cup
Ripe tomatoes - diced
Parmesan cheese
Saute garlic. Add basil to hot skillet. Remove from heat and stir in fresh diced tomatoes. Pour lightly over fresh pasta. Serve with Parmesan cheese.
ARTICHOKE & BUTTER PASTA
Use 2 measuring cups of flour. Fill to "Oil+Egg+Liquid" line with: 1 egg, 2 tablespoons melted butter and fill to top of "Oil+Egg+Liquid" line with liquefied (pureed) artichoke hearts (cooked, or cooked and marinated) after straining artichoke juice through sieve. Serve with remaining artichoke hearts.
SOUTHWEST CHILI PASTA
Use 2 cups of bread or semolina flour. For your liquid, use: 1 egg, 2 teaspoons oil, 1 tablespoon chili powder, 1 teaspoon salt, 1 teaspoon onion powder and fill with tomato juice to top of "Oil+Egg+Liquid" line on your measuring cup.
LEMON PEPPER PASTA & SHRIMP
Pasta: Lemon Pepper Linguine, Spaghetti or Fettuccine
1/4 cup
Olive oil
1 lb.
Fresh shrimp - peeled, deveined and butterflied
2 Tbsp.
Garlic - minced
2 Tbsp.
Oregano
1 Tbsp.
Lemon pepper
1 tsp.
Minced parsley
1 cup
2 Tbsp.
Jan 07, 2015 | Cook's Essentials CooksEssentials Pasta...
I bought this of line it's a dellinspiron duo and it didn't come with a DEVOBJ.dill cd
You can download this file from this WEB site.
http://www.dllme.com/dll/files/devobj_dll.html
Mar 07, 2013 | Computers & Internet
Are there herbs that donot freeze well? I heard that not all types of herbs respond well to being put in the freezer?
You are right. Soft herbs such as mint, basil, dill and verbena are very delicate and don't freeze well. Their flavor changes in the freezing process. So with those herbs I just stick to fresh.
Feb 18, 2013 | Home
What is a good vegetable dill dip?
My all time favourite is http://allrecipes.com/recipe/vegetable-dill-dip/detail.aspx
Jan 10, 2013 | Cooking
My dill is not sprouting in my aerogarden. Do they need dark to germinate?
The dill should require roughly the same parameters to sprout as the other plants in the AreoGarden. Perhaps fresh seed would help.
Sep 04, 2011 | Aerogrow AeroGarden
Acer Arcade Deluxe,, this application failed to start because MSVCR71.DILL was not found. Reinstalling the application may fix the problem,,,,,, how do i re-install????
Go to the web site below and download and install do as Administrator. ptf.com/acer/acer+arcade+deluxe+2.1.6319/ -
First though go to add/remove programs, locate it in the list, and click, uninstall sometimes programs will give you the option to "Repair" try this first, if no repair uninstall anyway so you'r fresh for the new install of DLed one.
Mar 05, 2010 | Acer Aspire 5500 5570-2609 Laptop
I cammot get my master 2 to open from my desktop. it comes up with ollymuse.dill problem. It then says i have to install the program again. i cannot find the disc to install and the master two has over a...
If you have Windows XP you don't need any software from the camera maker. Make sure you have fresh batteries, turn on the camera and use your cable that came with the camera to plug into the USB of you computer. It should find it as a drive and you then should be able to transfer the pics to your computer. Failing that? Take your camera / sd card to Walmart and have then transfer the pics to a CD
Dec 20, 2009 | Olympus FE-230 Digital Camera
Dill & basil not growing
Hi kadoolittle, some pods do not sprout but can be return for a replacement.
Check out the Dill article on the Aerogardeners Wiki for more info on growing it in the Aerogarden.
http://aerogardeners.wikia.com/wiki/Dill
Jan 21, 2009 | Aerogrow AeroGarden
Hello
http://www.usersmanualguide.com/philips/monitors_and_pc_peripherals__webcams/dmvc300k_00
Nov 10, 2007 | Philips FunCam DMVC300K/00 Digital Camera
Home Logo
446 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
