Question about Hoover U6485-900 Windtunnel Bagged Upright
How do I replace the idler arm assembly for hoover u6485-900 vacuum?
The plastic piece around the tension pulley broke so the assembly needs to be replaced.
4 Suggested Answers
  • 30 Answers
SOURCE: Actuator arm for Hoover U6473-900 vacuum's drive broke
I just changed the actuator arm on my girlfriend's 6437-900 and it's pretty straight forward. Not certain how you got the transmission out, but here's what I did:
-unplug the vacuum
-remove the 4 screws and the plate over the roller brush as well as the roller brush
-remove the two screws and the plastic cover over the end of the hose on the right side.
-remove the 2 screws down in the bottom of the housing on either side of the drive wheels
-remove the single screw in the middle/bottom of the housing
-push the two tabs on the inside of the outer edge of the housing to remove the top cover
-flip the vacuum over, you'll see an "e" clip holding the actuator arm in place being careful not to lose it
-use a torx bit to remove the old cable hold down
-gently bend the metal piece over the arm back far enough to remove the old arm. Note the slot in the metal piece, you'll need to make sure you get the metal tab in the slot when you reassemble everything.
-put the new arm in, about $8 at a Hoover repair store
-put the metal piece over the rod that the e-clip fits into, making certain the tab and slot are aligned
-press down on the metal piece once it's on the rod with the tip of your screwdriver so it snaps in place, carefully put the e-clip back in it's slot on the rod.
-put the cover back on, lay the vacuum flat, put the cable end in it's channel on the arm, tighten the hold down.
-flip the vacuum over, plug it in and turn it on, being careful to keep hands, fingers, ties, hair, small children, pets, etc away from the spinning roller brush
-move the handle, still in the off position, up and down to make certain the drive wheels don't move. If they do then readjust the position of the cable on the end of the arm. The wheels should not move at all with the handle in the off position.
-enjoy
Posted on Dec 21, 2008
  • 294 Answers
SOURCE: Hoover self propelled U6630900 idler arm lock
Remove the bottom plate (4 screws), remove belts and brush roller. There may be 1 small screw in the center front of the vac under the brush roller. remove this one. If this is a bagless model you will also need to remove all of the back screws (torx) that hold the lower hose on. This needs to be removed to take the hood off. underneath on each side of the power drive assembly you will have 1 screw, remove them. there is a clip on each side that snaps the front on, push them out with a screwdriver. Then the hood is removed.
Posted on Feb 28, 2009
Vac Belts
  • 701 Answers
SOURCE: the brushes will not rotate on my hoover vacuum.
Did you order the correct size of belt? These are the belts you should have:
Hoover Windtunnel Belts
Posted on Nov 08, 2009
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
Hoover model U6425-900 brushes do not roll
-- Make sure slide switch is in carpet position
-- The idler arn which tensions the brush belt may be broken
-- The idler arm override which is attached to the carpet slide switch may be broken
The second one is common.
Oct 30, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Hello! Hoover WindTunnel broken! aRGGHHH
I would definitely check out the epoxy route.
Jun 14, 2017 | Hoover U6630-900 WindTunnel Bagless...
Feb 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
-unplug the vacuum
-enjoy
Dec 15, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Floor Mate
There is a black shaft with a black circular arm at a right angle to the shaft. The black plastic arm that sticks out of the front ( farthest away from the hinge) of the roller assembly plugs into the circular arm so that moving the scrub/vacuum slider causes the roller assembly to move up and down. I can do it with my finger, or use a flat blade screwdriver. I'm assuming you mean the black plastic thing with the little rollers on it.
Kirk Thompson
San Juan, PR
Sep 03, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Valve actuator, arm & spring assembly
Could not find a picture of this installed, I have replaced this spring and it is hard to do. You have to put the straight prong of the spring unto the valve arm, you will see a spot for it to be at, then wind the other end of the spring around until it goes into a slot, then get it all together on the agi housing before it comes apart. Hope this makes sense.
Feb 15, 2008 | Hoover U6660-900 WindTunnel Bagless...
Hoover savvy changeing belt
There some screws on the bottom to take off, then turn vac upright, under the round Hoover logo sticker is another screw. It is just a sticker, so will peel off. You can work the belt onto the motor pulley, or unscrew the motor, put the belt on the pulley, then reinstall the screws to hold down the motor.
Jan 06, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover U6485-900 Windtunnel Bagged Upright Logo
236 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
