Question about JVC KD-PDR30 Car CD/ MP3 Player
Gm corvett radio has no AM receiption for is good
My corvett radio 986281 has good FM receiption but has no am receiption
Security system reset
You may need to check the owners manual for a Corvette. Most GM models can be set by leaving the key in the on position for a few minutes with the engine off, or by locking and unlocking the drivers door with the key.
Jun 08, 2013 | 1999 Chevrolet Corvette
Ineed unlock code for chevy suburban 2004
must go to a gm dealer they will plug in with mdi and call gm for a unlock code
May 12, 2012 | Ac Delco AM-FM Radio Cassette
How do i turn off the anti-theft in my 2000 Malibu, without the original factory stock radio?
all gm vehicles from 97-2005 contain an system called passlock. how to deactivate system on chevy malibu, turn key to on,do not start car! let it stay on 10-15 minutes, then turn key off, take out key from ignition. after 1 minute start the car. good-day !
Aug 27, 2011 | Corvette Chevy Malibu 90-04 Car Radio...
I changed the battery in my 2000 corvette and now the radio does not work.
This is a problem with the Theft-Loc system. I believe you will have to take it to the dealer to have the radio unlocked. I found this procedure on the web, but I don't know if it will work. Good luck.
1. Turn the ignition ON (The radio should display "LOC")
2. Hold down the Radio Presets 2 and 3 buttons for six seconds
3. The radio display changes from LOC to a three-digit number. Write this number down. You now have fifteen seconds to complete the next step.
4. Press the AM/FM button
5. The radio display changes to another three-digit number. Write this number to the right of the first one.
6. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
7. Call 1-800-537-5140
8. Press 1 then # (pound). You'll hear "Invalid Code, try again"
9. Press 139010 or 106010 or 206010 or 202107 then # (pound). You will be asked to enter your four or six digit code followed by *
10. Enter the number from STEP 6 then *
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to "SEC". Your radio is now "un-locked" and usable.
Mar 27, 2011 | 2000 Chevrolet Corvette
My Grundig 300PE was a Christmas gift, 2009. One week later, it won't turn on. I've installed new batteries and it won't work on the external power source either. The "light" works, but nothing else will...
Lets find that receipt and get it fixed under warranty pronto. as it's a gift and you may not be able to get the receipt, go back to the place of purchase and plead plead plead!
Good Luck
Jan 14, 2010 | Grundig YB 300PE AM/FM/SW Radio
Unlock radio for a 1996 monta carlo?
hi friend,
Your car has a anti theft radio in it . What has happened is at one time some one entered a code into the radio. What you are going to need to do is stop at your GM dealer and have them unlock the radio. The charge will be approx 30$ (that's what my dealer charges) Make sure you specify that you want the old code removed. Also ask them for the four digit backup code they get when they call GM. They will press numbers 2 and 3 on your radio and get digits then they will press am fm button and get two more digits and with those digits they will call a 1-800 number that only GM can call and they will get the unlock code. Sorry but I cannot divulge the number. Big TROUBLE!!! Hope I have helped
UNLOCK Code is:
1761
Ignition ON
Hold Minutes for first numbers
Hold Hours for last numbers
Press AM/FM Button
Turn ON Radio
hope this helps u
please rate me.................
thank u for using fixya
regards
sivaranjini
Nov 24, 2009 | 1996 Chevrolet Monte Carlo
How do I unlock my radio if I forgot my password
Sorry bud,
gonna have to a GM dealership to have them reset it.
good luck,
Jay
Oct 04, 2009 | 1999 Chevrolet Corvette
The factory xm volume to low in 2006 corvette
Separate 'plug and play' XM radios, like the one pictured above, have a "MENU" setup, and you can adjust the "Audio Level" in that menu setting. See if you can access an XM menu. You can also ask your question over at XM411.com or XMfan.com; both are 'fan' websites.
Good luck - nice car too!
Aug 05, 2009 | Delphi SKYFi2 SA10126 XM Radio Receiver
1995 corvette heater core replacement cost estimate
225.00 bucks including parts labor, you might find a local mechanic will do it for 100.00 buck for labor and you buy the part 49.00 buck. lots of GM mechanic are laid off and economy is slow and you might want to advertise on craig list needing GM mechanic. my best secrets is drive back to the GM garage and ask any mechanic who does the side work and you will be surprise. keep in mind dont ask the shop manager, believed me every dealership has one or more does a side job and good price, no shop rate. hope that help some good luck.
Apr 08, 2009 | 1995 Chevrolet Corvette
FM Radio
Are you sure your model has the FM tuner? Not all models have it. If yours does then contact Centon, this device has a 1 year warranty. You will need your receipt to return it.
Jan 21, 2008 | Centon Electronics 1GBMP3-001 MP3 Player
JVC KD-PDR30 Car CD/ MP3 Player Logo
23 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
