Question about DeLonghi EO1251 Toaster Oven with Convection Cooking
Karups setting time - DeLonghi EO1251 Toaster Oven with Convection Cooking
How do I set a farberware t490c commercial tabletop convection oven to work
Try calling or emailing Farberware (distributed by Salton/MAXIM Housewares): faberware-electric@saltonusa.com OR 1-888-881-8101. Ask for Operating Manual
Dec 29, 2014 | Farberware T490C 1500 Watts Toaster Oven...
What ever setting I use Toaster, Pizza etc the oven runs for 3 minutes and stops and in the read out window E 1 comes on the screen
Unplug the unit for at least 30 seconds. Plug in, set clock. When making pizza punch in the time you wish it to run, such as "7:30" then "start". Watch carefully the first time to see how much time it takes to cook to your liking.
Sep 03, 2014 | Oster Digital Countertop Oven With...
How to set the clock on classic 110 oven
Push the clock button. Either use the timer up down to set a time. Push the clock button again. Should lock in the new time..
Oct 30, 2011 | Toaster Ovens
How do i set clock
You can get the manual on the link below page 9
http://www.krupsusa.com/NR/rdonlyres/932350FD-628D-4959-879A-AC006C96E9B9/7106/FBC4FBC5.pdf
• When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
Feb 20, 2011 | Krups FBC5 1600 Watts Toaster Oven with...
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
Setting clock on krups toaster oven
buttons.
May 28, 2010 | Krups FBC5 1600 Watts Toaster Oven with...
Setting time
I own the exact same toaster oven. Can't locate the manual. Also,
tried to set the time,which was off by 2 hours,and no luck,either.
Try to Google the instruction manual pdf. Good luck.
Mar 31, 2010 | Krups FBC412 1600 Watts Toaster Oven with...
Need to activater self-clean
Every self-cleaning oven is different. It's best to consult the owner's manual for the correct procedure for your oven. But often the steps are:
  1. Set the Start time for the time you want the cleaning to begin.
  2. Set the Stop time to a time 2-3 hours after the start time.
  3. Close and latch the oven door.
  4. Set the selector switch and/or thermostat to "Clean."
Jan 09, 2009 | Farberware FAC900R Toaster Oven with...
Oven does not turn on
These ovens have a timer switch that lasts just about a year. Mine did the same thing and you cannot find the timer switch anywhere in the USA. The switch is likely a DKJ/1-60. There is a switch made by Delonghi that will work. The part # is 05XDE5218104600. You can get one at "The Gourmet Depot" website for $10 + shipping.
Jan 23, 2008 | Black & Decker CTO6300 Toaster Oven with...
DeLonghi EO1251 Toaster Oven with Convection Cooking Logo
26 people viewed this question
Top DeLonghi Toaster Ovens Experts
Dave
Dave
Angel Joseph Jr.
Angel Joseph Jr.
Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
