Question about Sony Audio Players & Recorders
Haw do i connect sony sava 55speakers and subwoofer to my home theater
SOURCE: Sony KF50we60 hdmi-dvi sound cuts when plugging into a ht-sf2300
DVI = HDMI without the audio connectors. So basically you need to connect your audio in some different way, PS3s allow you to keep your video signal as HDMI and change the Audio signal to component, so that is one way or doing it, not sure if the blue ray players allow you to do this though.
Posted on Jan 11, 2009
  • 77 Answers
SOURCE: Connect Altec Lansing ADA745 to HD TV RCA output for home theater
hiya
actually yes you can.....providing you get adapter cables 3.5mm jack to phono rca
Rik
Posted on Feb 25, 2009
ginko
  • 19396 Answers
SOURCE: sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
  • 3 Answers
SOURCE: No Audio with home theater system
have you tried infra red link?
Posted on May 07, 2009
SOURCE: Remote code for Sony Home Theater
This works for ALL Sony Home Theater Systems
Remote Code: 21232 (a Sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Function = 44750
Mute = 33743
Posted on Jun 25, 2009
Sava 500
Make sure it's getting sufficient power to function, and that your polarity switch is in the correct space. Be careful with this, you might blow up the unit if you don't know what you are doing.
Jun 08, 2013 | Audio Players & Recorders
I have a pair of SONY SAVA-500 speakers I have had 5 years and have lost the the square 4 pin wire that connects them. 3 round and 1 square. Any input on these would be gtreatly appreciated!
Google Sony sava 500 look at images it always shows the 4 pin connector the reason for not leaving a link is that everytime I look for that part someone else stocks the part it runs around 35 bucks shipping inc.
Aug 28, 2010 | Sony Audio Players & Recorders
Ihave a sava-500 home theater speaker system i dont have the cord to connect the 2 tower speakers will this affect the sound from the main speaker using the av input
With not all the speakers hooked up, it will definitly effect the sound. The unit is designed to channel different sounds to certain speakers. That's what makes you feel like "you are there" If you have lost the cords to the tower speakers, you can buy replacements. Go to where you bought the unit, a Radio Shack, or other store that sells home theater systems. Enjoy your system like it was designed .
Apr 16, 2010 | Sony SA-VAD900 System
Connect powered subwoofer to system with no pre-out connector?
You will require a Line level converter... usually reserved for car audio applications - but it should work in yours as well.
It converts the speaker wires to RCAs.
45679e7.jpg There are ones made for home audio - but harder to find and a little pricier.
01259e7.jpg Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | Sony HT-DDW660 Home Theater System System
REAR AND CENTER SPEAKERS WILL NOT PLAY
rear and center speakers will not play...................are you in the 5.1 channel input, or one of the others? either way, start by making sure that your center channel is set for normal mode (instead of a wide or a phantom mode) this silly setting can cause all kinds of trouble shooting nightmares especially particular to the 5.1 input setting. best reccommended to select the 5.1 input option and do a "t.test" on the system to ensure that all speakers are indeed wired and properly recieving some signal..... the rest will flow from there..... I have also noticed that in particular sound modes, the system is extremely finicky about the connections..... if you are using the 5.1 option, you need to be sure that something is plugged into the inputs on the back (regardless if they are connected to anything) the system seems to prefer when all ports are filled. hope this helps..... i realize that it has been a while since this question has been posted, but let me assure you, that some of us are still rockin those sava systems..... still by today's comparison, it is difficult to beat the sound quality and oh my the bass!!
May 09, 2009 | Sony HOME THEATER SYSTEM System
I need help
it could be that the wires on the back of speaker are not fully connected or the speaker is blown and maybe try and swap some of the speakers around to see if its the speaker or the amp
Mar 18, 2008 | Sony HOME THEATER SYSTEM System
27 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
