Question about Check Point Safe@Office 500 Router (CPSB5005US)
Bittorrent not working
I have enalbed port forwarding on the firewall but when i run the testspeed for bittorrent it replys that the port 6881 is not open.
Need help.
I am using Windows Vista, i have installed bittorent but it is not downloading any file, pls suggest
Posted on Sep 18, 2009
    Problem Solver:
  • 9 Answers
Find other people on the same ISP and see if it works for them, Some ISP's block bittorrent traffic for legal reasons.
Posted on Jun 23, 2009
How to block torrent download in sonicwall tz190
BitTorrent is a torrent downloading client used to download
music, video and game files for free.
BitTorrent can really eat up bandwidth, which can be mighty
frustrating, especially if you're sharing a computer and an Internet connection
with someone who's using BitTorrent.
If he's not willing to stop using BitTorrent, there are a
few steps you can take to block this demanding program.
Switch your Internet service to an Internet service provider (ISP) that is
hostile to BitTorrent. RCN, for example, is known to block BitTorrent traffic.
Try blocking all ports from 6881 to 6999 on your system.
You must first add a port before you can block it. Click
"Control Panel" and then "Network and Internet
Connections."
Click "Firewall Settings," and select the
"Exceptions" tab.
Click the "Add Ports" button. Enter the port
number you want to block, and click "OK" to save your changes.
Navigate to the "General" tab in the "Windows
Firewall" section, and remove the check mark from the port you just
created.
That port is now blocked and cannot be used by BitTorrent.
Unfortunately, performing this procedure 118 times is
somewhat time consuming, but it is one of the few ways known to block
BitTorrent.
If someone is using BitTorrent on your computer, don't
allow him access to it.
If he's using BitTorrent on his own computer, you may have
to buy your own machine to avoid conflict.
If the Internet is slow on your computer because
he's downloading via BitTorrent on his own machine, consider using a public
Wi-Fi point such as a library or coffeehouse.
Nov 11, 2013 | SonicWALL TZ170 (01-ssc-5740) Firewall
I want to disable bittrorrent
Depending on the type of router you have, you will need to block a certain amount of ports to block Bittorrent from connecting.
Bit Torrent starts at Port 6881 to Port 6999
Figure out what brand of router you have and visit their website. They will have support options available to help you do this.
Mar 29, 2011 | Computers & Internet
Hangs with Bittorrent
That is because you need to open a port on router with the same number assigned to your torrent client.
You need to check port number on bittorrent configuration, then access router control panel typing router IP on internet explorer address bar and configure the router to open the port.
Read the following articles.
How to configure your router to allow fast BitTorrent downloads
Brian's BitTorrent FAQ and Guide: What ports does BitTorrent use
Slow Bit Torrent downloads? Router configuration tips.
Opening port BitTorrent |
forum.bittorrent.com / how to open firewall/router port
Guide to Open or Forward Ports for Utorrent and Azureus BitTorrent
Port Forwarding for the Netgear WGR614
Tweaking your system to get the most out of BitTorrent
Apr 13, 2009 | Computers & Internet
Network connection?
Log into your router. You should have a manual on accessing it. Find a selection called port forwarding. What your going to do it set port 6881 to be forwarded to your computer to get your IP address by going into /Start/Run/ type cmd.
Once the prompt is open type ipconfig /all and retrieve your IP address. once that port is forwarded to your computer you should be good to go.
Jan 15, 2009 | Zyxel P660HW-D1 Router
I need to configure my d-link for wow downloader
To configure D-Link DI-624 Wi-Fi access point to work with BitTorrent you have several options. One of them is to use trigger ports.
Steps to follow:
  1. Open web control panel of D-Link DI-624 by connecting to http://192.168.0.1 (this is default direction, which can be changed by administrator).
  2. Enter login and password for administrator. Default login for administrator is admin.
  3. Go to Advanced, select Applications.
  4. In Applications screen:
    1. Check Enabled.
    2. Fill BitTorrent in Name.
    3. In Trigger Port put 6881 and 6999.
    4. In Trigger Type select TCP.
    5. In Public Port put 6881-6999.
    6. In Public Type select TCP.
    7. Press Apply.
  5. The DI-624 will reboot.
Now you can use BitTorrent from any computer on both LAN and WLAN local networks in automatic way.
BitTornado Setup If you use latest experimental BitTornado client you can give a good use toUniversal Plug and Play (UPnP). You just need to enable UPnP on D-Link DI-624 and BitTornado will work on any computer in your local network without any requiered intervention from your part.
In BitTornado:
  1. Run BitTornado
  2. Click on Prefs
  3. Locate UPnP Port Forwarding and select type1 (fast)
In DI-624:
  1. Log in as administrator
  2. Open Tools (main menu)
  3. Select Misc. on the left
  4. Locate UPNP Settings and select Enabled
Jun 30, 2008 | D-Link 802.11g Wireless Router WBR-1310...
How do i reprogram a 2wire 2071-A
Do you have your instructions? I can tell you but it would be easier for you if you can just look at the guide and take your time. You can do a reset and then reprogram. If that's all you want to know I can do that. Would you want me to get you athe manual or tell you specifically how to do something?
May 03, 2008 | Computers & Internet
Downloading music to widows media, with vista
you have a router and modem or combo? youll need to forward the ports in order to download. same with any firewalls your running. ports 6881-6999
Nov 12, 2007 | Microsoft Office Outlook 2003 for PC
Check Point Safe@Office 500 Router (CPSB5005US) Logo
255 people viewed this question
Top Check Point Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Gil Shultz
ray gallant
Are you a Check Point Computer and Internet Expert? Answer questions, earn points and help others
