Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
My john deere 210 LE parking brake comes on while operating,
There appears to be a short somewhere, but I can't determine where to look.
  • 57 Answers
SOURCE: my john deere 210 LE just dies out
If this problem exists mainly when the engine is hot it may be the coil.
Posted on May 19, 2009
  • 73 Answers
SOURCE: my 1979 111 john deere lawn tractor deck blades shut off
If it has a clutch, that would be the problem. An electric clutch will kick on and off when it is hot if it is bad.
Posted on Oct 02, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 4210 brakes are locked up
On both sides of trans housing just in front of axles is where brake shafts go into trans.To fix this you have to spray alot of lube between shaft and housing while trying to rotate shaft.This may take hours to free up and also check for the return springs to still be hooked up to lower roll bar frame.I have seen this alot in the 4000 series tractors.
Posted on Nov 14, 2009
  • 8404 Answers
SOURCE: John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
Posted on May 02, 2010
SOURCE: Won't start John Deere 310D Rubber tire backhoe
wont go forward or back
Posted on Jun 24, 2010
How to determine if there is a PTO clutch problem on Craftsman Model 917.275900 ? Have replace PTO switch twice recently. Second switch appears to show some melting inside when button came out !
You have something shorting out somewhere if switches are melting. I would trace these wires to see if they are rubbing on frame and grounding out somewhere. If your not sure I would take this on in to a repair faculity.
Aug 06, 2013 | Garden
I have a Kenwood KDC-116S in my truck and found that it is causing my battery to drain . When I disconnect the battery it draws a spark. When I disconnect the radio lead I no longer get the spark. Can...
Yes.
The YELLOW wire is connected to 'constant' 12v power. This is necessary for the receiver to retain the memory settings (i.e. station presets etc).
So, yes... your unit will draw power, but this will be very minimal.
Try disconnecting the Yellow wire for a few days and see if this makes any difference. If not, you will need to inspect the wiring loom to determine if there is another short somewhere. If everything looks ok, then the short must be somewhere else, within the vehicle.
Feb 17, 2013 | Kenwood KDC-116S CD Player
My stereo sysytem is a mini stereo: serial number 10200055. It currently says "protect", what is this and how do we return our system to normal operations?
When the word PROTECT appears on this display, this means the unit has detected a critical fault which could potentially cause harm to your stereo system.
The most common cause is a short circuit somewhere - something even as simple as loose speaker wiring could cause a short, triggering the Protect message.
You will need to determine if there is a possible short somewhere, so I recommend you start by firstly turning power OFF, disconnecting all speaker wires, then turn unit back ON.
Operate the stereo (without speakers) and turn volume up:
  • If Protect message appears when turning volume up, then stereo unit itself has an internal fault
  • If no Protect message appears, then suspect the speakers may be causing the issue.
  • Reduce volume and turn unit OFF
Re-connect speakers (ensure the connections are secure), turn unit ON:
  • If turning volume up triggers the Protect message again, there is an issue with the speakers or connections
Hope this helps.....
Sep 04, 2011 | Kenwood Audio Players & Recorders
I have a 99 VW Golf and the battery went totally dead. When I tried to jump it the cables started smoking and the wires melted. A volatage meter registers zero when the battery is connected to the car...
At 5 Volts the battery is totally cactus (a fully charged battery should read above 12.6 V) and from the description of hot melting wires appears the battery has a dead short between cells. Try a new battery and check battery terminal voltage before and after connection, with every thing turned off. If terminal voltage drops more than 0.2 V it would indicate excessive current draw by a faulty component. You may have to have the electrical system checked by an auto electrician to determine if there is any other faukts in the system.
Dec 11, 2010 | 1998 Volkswagen Golf
Dashlights, console light, rear tail lights, all do not come on when I turn headlights on with the dash headlight switch. I changed the fuse (was blown out) and it blew as well, suspect short in the...
Short somewhere or go in dash and make sure plugs are pluged in Cluster Panal or where fuse keep blowing put a piece of there where ever the short is you should smoke.
Mar 08, 2010 | 1996 Jeep Cherokee
Signals on mercury sable 2002
I think that it could be a short somewhere along the circuit. Your front turn indicators, your dash blinkers, and your rear turn indicators are all on one circuit. Maybe a wire rubbed on a piece of metal or got too hot and the plastic housing melted off. Electrical problems are nothing to toy with as they can lead to your car burning to the ground. I'd take it in so a technician can run some tests to determine if there is a short somewhere along the line.
Nov 28, 2009 | 2002 Mercury Sable
TV shuts off randomly along with lights on front of TV
Check ur power source,like the outlet?Check change the A/C cord?Still happened it ur tv power supply board have short somewhere,must change the whole board.Intermition prob.very hard to determin to troubleshoot,by parts to parts to changes.
Nov 04, 2009 | Samsung HL-S5087W 50" HDTV
Electrical problems vehicle goes completely dead then after jump appears fine as if there was a short somewhere.
Or more accurately: an open somewhere...
Be certain to full charge and load test the battery, clean battery connections with rough sandpaper.....
It is these items that are perhaps 95% of this type of complaint are found.
Oct 10, 2009 | 2002 GMC Envoy
Bush toaster is blowing fuses when switched on
It appears that there is a short in the toaster somewhere. Many times it is the cord. See if you can remove the cord and then test to see if the two leads of the cord are shorted with an ohmeter.
Bob Janelli
Oct 01, 2009 | Toaster Ovens
RCA 55" HDTV
Sometimes a part can go shorted, and an over voltage occures somewheres thus causing another part to blow. This can be anywhere from in the power supply to any of the other boards.
The set would have to be serviced to determine the cause and what was damaged. Most likely there will be the need to change some boards. Most of the service is done by a combination of board replacement and some component replacement depending on the exact type of fault.
Jerry G.
Apr 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
73 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
