Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Frigidaire water filter cartridge ejecting - Frigidaire FRS26H5AS Side by Side Refrigerator
Filter on a Whirlpool WRS965CIAE is jammed. Filter is supposed to pop when filter housing is opened. Any suggestions? Thank you.
The filter should auto eject as you open the filter door.
However, maybe the cartridge is weighed down by water still in the cartridge. Try shutting off the water supply line and drain out any remaining water in the system at the dispenser.
Try closing it and reopening it- make sure that portion of the compartment didn't freeze up.
If you have a putty knife or something similar- perhaps a bit of persuasion with the putty knife- jiggling the filter will help release the cartridge.
Mar 04, 2015 | Whirlpool Dryers
I replace filter, each time the water dispenser is push the filter ejects
It sounds like you may not be getting the filter fully locked into position. Push it in firmly until it clicks.
Feb 28, 2015 | Frigidaire PureSource2 Water Filter WF2CB
How do I change the water filter on a Frigidaire FRS6R5EMB
If it's the model I'm thinking of, it has a screw in filter cup up in the rear, upper right corner of the fresh foods section. Just twist that weird shaped cup on the bottom counter-clockwise and then pull down on it. It should come out with the filter in it. Then, just take out the filter, put a new one in, and then screw the filter cup back into place.
From a manual of a similar model to yours:
To change filter:
It is not necessary to turn the water supply off to change the filter.
1. Open freezer door and leave open until filter change is
complete.
2. Turn OFF side mounted ice maker by raising wire signal
arm to the UP position. Turn OFF rear mounted ice maker
by pressing ON/OFF power switch to the "O" position.
3. Hold filter cup firmly, and unscrew towards left (Some water
could leak out as you remove cup. This is normaL). Filter
cartridge should come down with cup. If cartridge remains in
housing, puli down gentl_; while twisting filter back and forth.
4. Rinse out cup under running water.
5. The large o-ring that seals the filter system fits in the o-ring
groove inside the cup. Should the o-ring fail out during filter
cartridge replacement, simply place it back in the groove
prior to screwing the cup back in place. If the o-ring becomes
damaged, you wiIIneed to order one from the Flectmtux
Solutions Hottine.
6. Discard old filter cartridge.
7. Remove new filter cartridge from packaging. Place in cup. The
end with the small o-ring should be up, out of the cup.
8. Screw cup, with filter, back onto housing. Do Not Use Wrench
To Reinstall Cup= Filter cartridge will self-align as cup is
tightened. Be sure cup is completely tightened with
PureSource TM logo facing outward. Do Not Tighten Past Stop.
9. Turn ON side mounted ice maker by lowering wire signal
arm to the DOWN position. Turn ON rear mounted ice
maker by pressing ON/OFF power switch to the 'T' position.
10. Check for Ieaks. Open refrigerator door. Wipe any water droplets
from the filter cup. Fi[Ia glass with water. If there is a leak,
unscrew filter cup, and reinsert the filter cartridge. Check
placement of large O-ring. Reinstall filter cup, making certain it is
tightened complete!_,_
11= To prime filter system and purge air from water line,
continue flushing the system for approximately 3 minutes
to assure that the purest water possible is stored in the
water tank. There win be noticeab[e spurts and sputters
as the system pushes air out through the system and
out the dispenser nozzle,This is normal.
Oct 18, 2014 | Frigidaire Refrigerators
WATER FILTER WILL NOT ENGAGE
Hi friend, I appreciate your post!
I see your question is labeled under Frigidaire refrigerator, FGHB2844LF, and you are having difficulty engaging the water filter. Based off that model you should be able to push on the face of the water filter and slide the old cartridge out. First, to install the new cartridge you would need to remove the caps off of it. Secondly, using the alignment guide slide the new filter into the housing until it stops against the snap-in connector. Thirdly, push firmly until you hear the click which indicates that your filter has been engaged. Lastly press a glass against the water dispenser to verify no leaks are present at the filter housing. Hope this helps. -Matt
Aug 02, 2014 | Frigidaire Gallery FGHB2844LF 27.8 cu. ft....
Where is the water filter frs24wscb
Good Afternoon Friend,
I understand you want to know where the water filter is located on your Frigidaire refrigerator, model# FRS24WSCB. The water filter is located in the top back right-hand corner. To change filter follow the instructions below:
1. Set ice maker lever (wire signal arm) to the OFF (up) position.
2. Hold filter cup firmly, and unscrew counter clockwise. (Some water could leak out as you remove cup. This is normal.) Filter cartridge should come down with cup. If cartridge remains in housing, pull down gently, while twisting filter back and forth.
3. Empty cup of any substance.
4. The large o-ring that seals the filter system sets in the o-ring groove down inside the cup. Should the o-ring fall out during filter cartridge replacement, simply place it back in the groove prior to screwing the cup back in place. If the o-ring becomes damaged, you will need to order a new one from the Consumer Assistance Center.
5. Discard old filter cartridge.
6. Remove new filter cartridge from packaging, and install.
7. Place filter cartridge in cup. The end with the small o-ring should be up, out of the cup.
8. Screw cup, with filter, back onto housing. Do Not Use Wrench To Reinstall Cup. Filter cartridge will self-align as cup is tightened. Be sure cup is completely tightened with PureSource Plus Logo facing outward. Do Not Tighten Past Stop.
9. Set ice maker level on the ON (down) position.
10. Check for leaks. Open refrigerator door. Wipe any water drops from the filter cup. Run a glass of water. If there is a leak, unscrew filter cup, and reinsert the filter cartridge. Check placement of large O-ring. Reinstall filter cup, making certain it is tightened completely.
11. To condition filter system and purge air from water line, run several glasses of water through water dispenser. This will also assure that the purest water possible is stored in water tank.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire FRS26R4A Side by Side...
Where is the water filter on frs24wscb?
Good Afternoon Teresa,
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Refrigerators
Were is water filter in refrigerator
The water filter is located inside the fresh food section. In the top right hand up front as soon as you open the door it has a push button to eject the cartridge or it is in the back of fridge section in a plastic cup that easily unscrews. A new filter can be purchased at a hardware store or local appliance repair store. they can also be ordered online.
Oct 26, 2010 | Frigidaire FRS6R5EMB Side by Side...
How can I change the water filter on a frigidaire fridge
Hi, The filter is in the upper right hand corner of the fresh food section. Turn the filter cup counter clockwise to remove it. There will be a filter cartridge in the cup that you replace.
Please let me know if this has been helpfull or if I can assist you further
Thanks
Vic
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water dispenser and ice-maker do not work
open ice maker cover buy pass T_H will move if still water not come in ice maker change fill valve
Sep 03, 2017 | Refrigerators
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
27 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
