Question about Refrigerators
Model #et2ahtxmq00 ice maker just stopped. Bar is on water supply is ok. Tom
  • 721 Answers
Check the hoses going to the ice maker. If good check for power to th ice maker.
Posted on Jun 23, 2009
How do I shut off a Frigidaire ice maker?
Hello Russell:
My name is peter. I am a retired field service refrigeration technician.
You did not provide any information on your unit. Your model number is on a label on the side wall of your fresh food section.
Depending on the type of ice maker that you have the shut off is different. Some ice makers have a lever are that you lift up. Others have a shut off button.
The normal cycle is 8-10 ice dispenser deposits a day.
Tell me what the problem is. Give me the model number. You have one of those nasty bottom freezers?
Feb 27, 2015 | Frigidaire Refrigerators
Ice Maker bar won't come down
I have not worked on this model before but on the whirlpool they have a bar as well. you can turn off ice maker by pushing it up and it locks in place to stop ice production. if u want it to make ice u push it up slightly and it should move down. also check the ice maker tray to be sure u are getting water to the tray. if u get the bar to go down and no water comes in then check that u have water at the back of fridge.. if u have water there but not in the tray then you may have a bad water inlet valve on back of fridge.
Apr 15, 2014 | Maytag MFX2570AEM French Door Freestanding...
My ice maker doesn't work. Where do I start? Model number 561
HI.FIRST MAKE SURE U HAVE TURNED IT ON.SWITCH OR LEAVER.2- WATER ON 3-WATER IN ICE TRAY.4 IF EMPTY PUT SOME ON MANUALY.AND TRY.IF IT WORKS ONCE AND STOPS THEN U HAVE A WATER SUPPLY PROBLEM.CHECK PIPE;WATER VALVE.IF ALL OK THENNNN...ICE MACHINE?HOPE THIS HELPS.ALI
Jun 30, 2012 | Sub-Zero Refrigerators
MSD2356 side by side, we just hooked the water hoses up and there is no water coming through lines?
Here is a link that explains how to test the ice maker
Ice Maker Test
Here is a link that explains how to check the water in the door.
Water through door test
If you require further assistance you can always post in our forums
Forum
Feb 26, 2011 | Maytag MSD2756G Side by Side Refrigerator
My ice maker has stop working .mod FRT21TNGD3/FRIGIDAIRE
First need to determine water supply. Water filter and or inlet screen fouled? I know this is assuming the water supply is open..
Check the ice level bar to be sure it is in the correct position for making ice. If it is incorrect poition, the ice maker "thinks" the ice bin is full. I would start there with the water supply though. Most likely...
Jul 21, 2010 | Frigidaire Refrigerators
Ice Maker stopped working -- new fridge 3 months old.
Good day,
Icing could be one problem. The first thing to test is the water supply to the machine. Shut the house off at the meter. Remove the line from the water valve at the machine. Insert the line into a bucket while someone else turns on the water at the meter for a 15 second count. It should come out forcefully, not weak or just dribbling.
If it's bad, then the line and the fittings where it connects to the house supply should be inspected, and cleaned or replaced as needed.
If it is O.K. and the machine is under one year of age, it is under warranty and you should call your selling dealer for a free service call.
Jun 30, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker not working water working
somtimes the line to the ice maker frezes.you could test by putting 110 volts to the water valve direct[or inspect]water should then enter ice maker .your post dosent say your brand but most ice makers you can start by pulling on the harvest rake till starts.[mechanical only] if water valve good and line not frozen .then could be loss of power to ice maker[check at ice maker plug in at frezer] if thats ok then ice maker has failed,replace God bless,tom
Jan 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
