Question about Bulova Watch
Turning off hourly beep on unlisted mode? - Bulova Watch
I have a lot of questions about this watch. I can't seem to figure out how to turn off the beeping every hour and how to change the day of the week. Please help!It's a really cool watch and I want to
On my watch, if I pull out the winder half way I can change the date. `Fulling it out fully enables me to alter the time. However all watches are different
Jan 08, 2015 | Unlisted Watch, Mens Analog Digital Brown...
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
Unlisted watch beeps on the hour. Cannot get it to stop!!!
simultaneously click on the left side two buttons together.that time it will get stop
Jan 29, 2011 | Watches
How to turn off hourly alarm for a n unlisted
While holding the bottom right button down, press
the bottom left button. When all
7 day flags show,
the hourly chime is
on. When no day
flags show, the
chime is off.
Dec 06, 2009 | Watches
I want to shut off the hourly chime on my Unlisted mens watch
this is usually done by pressing two of the buttons together, I cant say which two, but you can try combinations. The watch should give a short beep when successful
Jun 20, 2009 | Watches
Can't shut off beep going off every hour
Hold down all four buttons to reset the watch. My time didn't reset but the beeping FINALLY stopped.
Mar 01, 2009 | Casio G-Shock G510D-1AV Wrist Watch
How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
Sep 28, 2008 | Watches
Watch settings
Press MODE and it jumps to Timer. Press mode again and jumps to ALARM set. press MODE quickly and jumps to time set. press START/STOP to reset and press RESET to change to minutes or hours. press RESET again and changes to Date Set...
Sep 17, 2008 | Watches
Bulova Watch Logo
16 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
